Old 06-16-2017, 03:02 AM   #57
Dru670
Drives: 2016 Scion FR-S
thank you will check with them.
Dru670 is offline   Reply With Quote
Old 06-16-2017, 08:35 AM   #58
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Originally Posted by Mrc@ptuning View Post
The ECA module uses Bluetooth 2.1 your galaxy S6 might only support Bluetooth 3 and newer.
This is a tuning issue you have to address with your tuner. Your tuner needs to disable this code since the flex fuel 0-5v output is using this pin for input to the ecutek to read the flex fuel reading.
I have the PTuning kit, and I have a Galaxy S6. Picks up just fine.
I'd check Android / Galaxy forums to see if there are features on the phone to make it more flexible. Would make 0 sense for mine to work, and yours not.
I also suggest disabling P0149 for "evap solenoid stuck open." This cel happened to me during a driving event, putting my car into limp mode during a corner. Not what you want to experience.
SpectreRT is offline   Reply With Quote
Old 07-19-2020, 06:11 PM   #59
e30cabrio
e30cabrio's Avatar
Drives: 2017 86
I just installed my kit, ran the tune, drove to the gas station and the car feels great!
Only problem is my S9 scans & finds no module.
I'll ask my tuner if I need the suggestion from mrc@ptuning.
e30cabrio is offline   Reply With Quote
Old 01-18-2021, 03:16 AM   #60
vsAaron
vsAaron's Avatar
Drives: 15' BRZ
Does anyone have an update/fix on Bluetooth not picking up devices within the Ptuning App? I recently installed this kit, it runs great for me as well! However, it can not detect my Galaxy s20+ or my Android Head Unit :/ Both running Android 10+ while one running Bluetooth 5.0, the other 4.0
vsAaron is offline   Reply With Quote
Old 01-18-2021, 09:14 AM   #61
jflogerzi
jflogerzi's Avatar
As a stop gap ecutek app will tell you this data.
2013 Series 10 FRS #553
Old 01-18-2021, 02:26 PM   #62
vsAaron
vsAaron's Avatar
Drives: 15' BRZ
jflogerzi Thank you for the suggestion! I haven't thought of this solution before. Unfortunately for me, I do not have the ecutek Bluetooth OBD sensor. But do have a generic one for the Torq app (no PID for Ethanol content yet). I might have to buy the Ptuning LCD display after all.
Old 01-18-2021, 05:39 PM   #63
jflogerzi
jflogerzi's Avatar
Do you have any multi function gagues? Might be cheaper and cleaner get a sensor to add ethonal %?
Old 01-19-2021, 03:25 AM   #64
vsAaron
vsAaron's Avatar
Drives: 15' BRZ
True, I'll shop around for a clean looking solution. E% is such a simple reading too lol. On the bright side, getting the mini LCD or a Guage will provide ease of access in the long run. Thanks again!
Old 01-19-2021, 11:57 AM   #65
jflogerzi
jflogerzi's Avatar
Originally Posted by vsAaron View Post
True, I'll shop around for a clean looking solution. E% Such a simple reading too lol. On the bright side, getting the mini LCD or a Guage will provide ease of access in the long run. Thanks again!
Look at P3 vent gauges with the E% add-on.
Opensource Flex-Fuel Ethanol Content Analyzer with Bluetooth Fiskafan Software Tuning 26 05-13-2020 01:04 PM
e85 w/o flex fuel kit? zkahle Software Tuning 21 10-16-2015 03:26 PM
Flex Fuel Kit? Khorne Software Tuning 65 02-23-2014 09:13 AM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
Flex Fuel? VenomRush Scion FR-S / Toyota 86 GT86 General Forum 12 01-15-2010 02:55 AM
