Old 10-20-2019, 07:26 PM   #1
dazbrz
Torque App not reading Oil temp properly
Hi Guys,
Having a issue where I can get the oil temp but it seems to drop off after 30 seconds or so and doesn't come back unless I restart the torque app. I triple checked the config for oil temp and all but I'm not sure why its dropping off. Everything else is reading perfectly.
Ive checked the forums for the settings and it looks all correct but I cant figure out why it would read fine and then drop off. Any ideas? Or is it possible the OBD2 dongle I have is faulty?
Using a ELM327 Mini
dazbrz is offline   Reply With Quote
Old 01-08-2021, 10:40 AM   #2
86GP
Drives: 2013 Toyota 86
I have the same issue. I assume its the readers . I used one and it does not read oil temps at all but reads everything else . I tried a new reader , it works fine but has the same issue as yours . I will try another reader and see of that works. I guess due the these readers being clones , they either work or dont. Its a luck of the draw.
86GP is offline   Reply With Quote
Old 01-08-2021, 07:33 PM   #3
hifiguy99
Drives: 19' Toyota 86 TRD
Originally Posted by dazbrz View Post
Hi Guys,
Using a ELM327 Mini
You can always get a tactrix or any other reader that's compatible with techstream and view it there too.
It could be the app or the reader. I have had better luck using this one over torque:
https://play.google.com/store/apps/d...hl=en_US&gl=US
hifiguy99 is offline   Reply With Quote
Old 01-08-2021, 09:20 PM   #4
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
My OBD2 scanner itself doesnt work for oil temp too*. I'm assuming its the cheaply made unit's fault.
Someone mentioned in the "official torque app" thread that uninstalled, reinstalling, and inputting the oil temp immediately got it to work - who knows, give it a shot
Old 01-09-2021, 02:34 AM   #5
Compelica
Compelica's Avatar
Drives: 86 GT
Is your ELM327 version a 1.5, or 2.0? 1.5 apparently had better compatibility, you can also use this app to check.
https://play.google.com/store/apps/d...m327identifier
Compelica is offline   Reply With Quote
The Following User Says Thank You to Compelica For This Useful Post:
Bonburner (01-09-2021)
Old 01-09-2021, 09:04 AM   #6
SCFD
I'm using Car Scanner app with this OBDII reader (https://www.instagram.com/p/Bo1UAmXjKwB/) and have no problems reading oil temps on both my Impreza and BRZ.
SCFD is offline   Reply With Quote
Old 01-15-2021, 02:03 AM   #7
86GP
I am currently using the Vgate OBD reader works perfectly now for both the Fuel and Oil Temp pids .
See pics bellow , the Vgate i am currently using is the older firmware 1.5 and the Orange reader has the newer 2.0 firmware . so maybe that was the issue .
Old 01-15-2021, 05:37 AM   #8
54fighting
Drives: 2020 toyota 86
its a shame these cars do not come with a better gauge package..
54fighting is offline   Reply With Quote
Old 01-15-2021, 07:03 AM   #9
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Subaru "fixed" it with the BRZ. You get oil and coolant temp on the dash. I say " fixed" because I think the implementation is kind of ugly
Oil temp reading via OBDLINK? ysu Engine, Exhaust, Transmission 21 12-14-2019 05:34 PM
Oil galley temp reading low Tomita San Engine, Exhaust, Transmission 19 03-14-2017 05:22 PM
Fuel gauge not reading properly FR-S Hot Lava Issues | Warranty | Recalls / TSB 27 10-29-2014 10:33 AM
Torque app with oil temp aaronsadventures Electronics | Audio | NAV | Infotainment 0 09-08-2014 09:14 AM
The Case of The Missing Oil Temp Reading Fastbrew Electronics | Audio | NAV | Infotainment 3 08-06-2014 11:25 AM
