Drives: Widebody 86/F56 Mini Cooper S
Lowering the Rear
Hey so I bought my '13 86 off of a guy who had the stock coils chopped, and it has aftermarket wheels. I bought Tein advance Z's so I can adjust but now I'm having issues on the rear.
1. I remember reading somewhere that the rear cannot be lowered more than 1.5" from stock in the rear before you get into territory of risk breaking the dif axle connection. Is this true? I'm trying to ever avoid the need of any dif risers of some sort. 2. Now if I need to stay within the 1.5" range, how do I measure the height to compare to stock?? As in, the wheels have an effect on the height so I'm confused that I can't just compare directly? Any help would be greatly appreciated
#2 |
Drives: Toyota 86
Rear stock from hub center to fender is 372mm (14.6in) with gas filled up and spare tire in, I wouldn’t lower the rear more than 1.4in
| The Following User Says Thank You to marco_mc22 For This Useful Post: | Hamza (01-12-2021) |
#3 | |
![]() Was just thinking shouldn't the center of the hub stay the same regardless of the wheel and I just measure that to the fendor? |
#4 | |
Señor Member
Its still gives you a max low point to use.
The lower you go the quicker you will wear out the CV joints in the rear axle and obviously the worse the car will deal with bumps. Are you racing the car or more of a cruiser or daily driver? Are you on stock or near stock power?
1974 TA22 Celica
2013 86 GT |
| The Following User Says Thank You to Turdinator For This Useful Post: | Hamza (01-12-2021) |
#5 | |
And I'm practically stock power. When I bought the car it had a widebody on and I just wanted to get rid of as much fendor gap as I could (I'm not slammed in any way). I sort of daily it, but it's honestly a max of a 20 minute drive a day. Not racing on it. |
#6 | |
Señor Member
Honestly if you are daily driving it just lower it until you are happy with the look and call it a day. Personally I would try and keep about 2 fingers gap from the top of tire to the fender tho. And make sure you get it aligned asap after you have settled on a height.
1974 TA22 Celica
2013 86 GT |
| The Following User Says Thank You to Turdinator For This Useful Post: | Hamza (01-13-2021) |
#7 | |
#8 | |
On the Tein specs, it says the max rear drop is 3". I measured before changing anything and I was at 37 cm from hub to fendor. I've dropped the coil as much as I could in a safe region, but now it's at 2 cm from being completely bottomed out, however the distance from the hub to fendor is still 36ish cm. The numbers don't add up because if I drop 2 cm more (bottom out the coil) I'll be at 34 cm, which isn't nearly 3 inches that the coil is capable of. |
#9 |
LMGTFY
Drives: 13 FRS, 91 Miata
Dumb question.
These have all been measured with the car on the ground right? Please provide pic of what you have it set to. |
#10 | |
#11 | |
Señor Member
1974 TA22 Celica
2013 86 GT |
#12 |
LMGTFY
#13 |
Wheels for Brains
@Hamza Does the installation manual have a reference on how to set-up the preload and height adjustment collars to factory recommendation? If there are, it will also tell you where the car will sit relative to stock when set-up according to the recommendation. This will be part of the total drop the coils are capable of.
Then, you can adjust from there using the lever ratio (1:1 in the front, 1:1.3 in the rear) |
#14 |
| lowering without aftermarket rear control arms | littlealex | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 11-26-2019 02:53 PM |
| Toyota 86/Scion FR-S TRD Lowering Springs & TRD Sway Bar Kit -Front and Rear | burgeralert | Brakes, Suspension, Chassis | 5 | 03-28-2019 10:16 PM |
| Uneven rear camber after lowering springs | Euphues | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 11-11-2015 08:27 PM |
| Any way to lower rear lowering springs further? | BlueDubbinTDI | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 02-03-2014 09:03 PM |
| Rear camber after lowering | mike_ekim1024 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 06-09-2013 04:01 AM |
