#71 | |
Famous Potatoes
Drives: '15 ultramarine
| The Following User Says Thank You to Sapphireho For This Useful Post: | MrDinkleman (01-03-2019) |
#72 |
Drives: 2016 Oceanic, "base" model
#73 |
Drives: WRB LMTD '13
Sorry to revive old thread.
Is this possible to pass? I have this exhaust installed including midpipe with cat https://www.ft86club.com/forums/showthread.php?t=34386
#74 | |
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
| The Following User Says Thank You to jflogerzi For This Useful Post: | hanabie (01-21-2019) |
#75 |
Drives: FR-S Release Series 2.0 #349
Sorry to bring up this old thread but do you pass on a stock E-85 tune with all stock parts (Exhaust, over pipe, front pipe, mid-pipe, and headers)?
Thanks!
#76 |
you can't pass on an aftermarket tune at all most likely. "stock" e85 is an aftermarket tune obviously the car doesn't run e85 stock.
#77 |
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
The dude earlier in the thread who runs a shop said if all the Readiness Monitors are Ready/complete and the CEL is off, it will pass the scan.
Most of the off the shelf tunes like OFT turn off the CEL. The question is whether the tune allows the readiness monitors to be "complete".
NARFALICIOUS
Noob Poster 1988 | 2016 |
#78 |
flash back to stock and run 91. Easy to pass. Now if you have Flex Fuel thats a different story
#79 |
Drives: 2013 Scion FRS
I have just done the test and passed, the older tech failed the visual test at first and passed after spoke with someone on the phone, the reason was the car branded Scion but all the internal parts are made by Subaru......
| The Following User Says Thank You to luluma For This Useful Post: | bcj (12-09-2020) |
#80 | |
| The Following User Says Thank You to jflogerzi For This Useful Post: | bcj (12-09-2020) |
#81 |
Drives: 14 Ultramarine FR-S
My OFT screen is busted... I need to get around to fixing the display but I can't think of why I'd fail with a OFT Stage I tune retaining all cats. Guess I'll find out when the time comes...
2014 Ultramarine Scion FR-S 2000 Integra LS - SOLD ![]() |
#82 |
Drives: Whiteout FRS
Visually assuming stock cats + no modifications to the emission parts, you will pass the visual test. It's the OBD readiness test that you might fail. Not sure if the OFT tune affects the readiness protocols in any way. If it does and it causes certain criteria to show not ready/incomplete, then you will fail.
#83 |
Drives: 2019 BMW ///M4
Not sure how 86 tunes are stored, but if you are in California with a tune and try to pass SMOG be mindful of this:
https://www.bar.ca.gov/pdf/On_Board_...n_10.17.19.pdf And mainly focus on this: Calibration Verification Number (CVN): a number set by OEMs to verify the integrity of the vehicle software Calibration Identification (Cal-ID): an ID for the software installed on the Electronic Control Unit (ECU)
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
| The Following User Says Thank You to N1rve For This Useful Post: | Decimus (01-21-2021) |
#84 | |
| Smog check for out of state people? | goshem | Southern California | 4 | 09-25-2015 06:20 PM |
| CA Smog Check?? | JG | Southern California | 22 | 06-08-2015 11:05 AM |
| WARNING!!!! Monday 1/26 CHP SMOG check in Orange County-Cross streets-Lambert/Idaho | continuecrushing | Southern California | 13 | 01-26-2015 11:19 PM |
| Need advice on passing smog in California | rmak321 | Northern California | 7 | 07-12-2014 12:52 AM |
| Smog check and visual inspection help | Corradooo | Northern California | 24 | 05-19-2014 11:57 PM |
