Drives: 2013 FRS
Zeta Performance Exhaust Install and Review (Pics)
First off, I want to give major props and thanks to @F1point4 for providing his expertise in how to actually go about doing the exhaust install in the comfort of my garage space. @F1point4 was gracious enough to assist, provide instructions and walk me through the parts list to make sure I had everything I needed to make the install as painless as possible.
The exact exhaust I purchased is the @ZetaPerformance Catback Exhaust - Stainless with Titanium Tips. My car is an automatic. First Impressions - The exhaust is very nicely made and has a nice stainless shine to it. I have the titanium tips and the coloring is even on both exhaust tips and the blue is perfect and was something that I was looking for in an exhaust. I think Zeta did a good job on the titanium tips. They are welded on the exhaust for those who are curious. I think their Carbon Fiber ones go over the regular stainless steel tips. - The tubing diameter is 2.37" per Zeta and the exhaust tips have a 4.5" diameter. - The welding overall on the exhaust looks pretty good to my amateur eyes and @F1point4 agreed as well. This was a plus for an exhaust that sells for just a hair over $600. - The weight of the exhaust is around 35 lbs so it weights around 3.5 lbs less than the stock exhaust - They did provide three gaskets and 6 nuts and bolts in order to install the exhaust. You have to use the two spring bolts and nuts and the 5 hangers that are on the stock exhaust to install. Day of Install Steps (Quick Listing) - Used a low profile 2.5 ton floor jack on the front then the rear to get the car on 4, 3 ton capacity each jack stands. - Used PB Blaster on the bolts and nuts of the stock exhaust so loosen the bolts - Loosened all the bolts and nuts and put them to the side. At this point, the front pipe comes off as it is not held on my hangers. - For the hangers we used to a soap and water mixture and sprayed it on the hangers to take them off. It was much easier to take the hanger off the car on all 5 of the hangers that I took off. - At this point, the stock exhaust is off the car - The old hangers were taken off the stock exhaust and put on the Zeta exhaust pieces. @F1point4 then helped me in getting the Zeta muffler hooked on by the 4 hangers on the muffler piece. This was much easier than it was to take them off but the soapy water did help tremendously. - The Y pipe was now hooked onto car via the hanger and the bolts were tightened with the gaskets between the connectors. - The front pipe was then connected to the Y pipe and we adjusted slightly to connect up the front of the front pipe to the stock donut gasket. - Tighten up all the bolts one last time - Turn the car on and check for any leaks - Done! This process for someone who knows what they are doing like @F1point4 would take 45 minutes without the time to get the car on the jacks. I believe the install time was a tad over 2 hours and 15 minutes for us because of the fact that I am a noob when it comes to this install. Even then, a very good experience and definitely not a difficult install. Driving Impressions - @F1point4 and I were able to take the car for a short drive (15 miles) right after the exhaust was installed to pick up my Zeta Performance Carbon Fiber Spoiler from the UPS warehouse (more details/info to follow). - The exhaust sounds great at start up, has nice deep exhaust tone as @F1point4 pointed out. - When you start cruising it does quite up a bit but not too much. As soon as you do step on the accelerator, it does wake up with a nice exhaust note. - I did have a 500 mile drive that weekend ahead of me so I knew Id get to hear the exhaust for a longer period of time and here is what I noted. - The exhaust on the lower RPM's is easier to notice while in the car and definitely can be heard by people around you. - On the higher RPM's it does quiet down a bit but from cars driving near me, it is noticeable. Not extremely loud but enough to where there is no constant drone from the exhaust. - For a period of time, I was going around 90mph and the exhaust did get a bit louder but nothing that would give me a headache. - Overall, two thumbs up for someone who, like me, is looking for an exhaust that won't break the bank but that would be put together well, have a nice deeper exhaust note but also something that wouldn't wake up the neighbors every morning or give you a headache while driving on the highway. Thanks again to @F1point4 for the pictures, the assistance and all the help in getting this done. Last edited by firestormriot; 04-22-2013 at 11:27 AM. |
Photo Specialist
Drives: 2013 Toyota 86 DGM 6MT
Zeta Performance Catback Exhaust Quick look
![]() 20130419-NabilZetaCatbackExhaust-045 by VictorN07, on Flickr Back with another quick look at more parts for the EightSix. Recently I walked @firestormriot through his first major car mod...catback exhaust. I advised him to get a catback exhaust because it is one of the best feel good mods you can do to this car. He researched and let me know he got the new Zeta Performance Catback Exhaust. While we were working I took some photos to share with everyone. I'll let him give the main feedback. Here we go Before: Stock exhuast with DC Sports tips ![]() 20130419-NabilZetaCatbackExhaust-008 by VictorN07, on Flickr First time to have his car in the air. ![]() 20130419-NabilZetaCatbackExhaust-009-Edit by VictorN07, on Flickr ![]() 20130419-NabilZetaCatbackExhaust-018-Edit by VictorN07, on Flickr The OEM catback exhaust compared to the Zeta Performance catback exhaust. The Zeta exhaust splits into two parts via the Y-pipe and feeds into a "dual" can style muffler. ![]() 20130419-NabilZetaCatbackExhaust-021 by VictorN07, on Flickr ![]() 20130419-NabilZetaCatbackExhaust-023 by VictorN07, on Flickr ![]() 20130419-NabilZetaCatbackExhaust-024 by VictorN07, on Flickr The muffler. The entire exhaust is stainless steel. There are some big ol tips on this bad boy. I think @firestormriot said they were 4.5 inches. ![]() 20130419-NabilZetaCatbackExhaust-028 by VictorN07, on Flickr He mentioned this exhaust was inexpensive. His selection made sense given his goals for his car are less aggressive than my direction. The welds actually were neat ![]() 20130419-NabilZetaCatbackExhaust-033 by VictorN07, on Flickr More welds ![]() 20130419-NabilZetaCatbackExhaust-034 by VictorN07, on Flickr ![]() 20130419-NabilZetaCatbackExhaust-036 by VictorN07, on Flickr Everything you need to install the system was included. Six nuts and bolts and three gaskets. You reuse the donut gasket on the front pipe ![]() 20130419-NabilZetaCatbackExhaust-039 by VictorN07, on Flickr ![]() 20130419-NabilZetaCatbackExhaust-044 by VictorN07, on Flickr The Y Pipe ![]() 20130419-NabilZetaCatbackExhaust-048 by VictorN07, on Flickr More neat welding ![]() 20130419-NabilZetaCatbackExhaust-052 by VictorN07, on Flickr The flanges were not thick on this exhaust. It shouldn't be a big deal, but I enjoyed the thick flanges on the Perrin headerback components and the Borla Header ![]() 20130419-NabilZetaCatbackExhaust-058 by VictorN07, on Flickr ![]() 20130419-NabilZetaCatbackExhaust-060 by VictorN07, on Flickr The welding was only on the outside of the pipes. The inside was not welded ![]() 20130419-NabilZetaCatbackExhaust-059 by VictorN07, on Flickr The Y-Pipe had a plate stamped with the date of manufacture ![]() 20130419-NabilZetaCatbackExhaust-067 by VictorN07, on Flickr Example of the gasket that is included ![]() 20130419-NabilZetaCatbackExhaust-068 by VictorN07, on Flickr Welds around the resonated pipe. @firestormriot in the background ![]() 20130419-NabilZetaCatbackExhaust-070 by VictorN07, on Flickr ![]() 20130419-NabilZetaCatbackExhaust-071 by VictorN07, on Flickr This is the flange that bolts up to the OEM front pipe. As you can see they mimic the OEM design quite a bit. Very thin flange designed to use a donut gasket and use the two OEM spring bolts ![]() 20130419-NabilZetaCatbackExhaust-073 by VictorN07, on Flickr ![]() 20130419-NabilZetaCatbackExhaust-076 by VictorN07, on Flickr Inside of the resonator. ![]() 20130419-NabilZetaCatbackExhaust-079 by VictorN07, on Flickr Zeta Burnt tips ![]() 20130419-NabilZetaCatbackExhaust-080 by VictorN07, on Flickr Nice touch on the muffler ![]() 20130419-NabilZetaCatbackExhaust-083 by VictorN07, on Flickr Final fitment on the car. Given that the entire exhaust has so many connection points, the fitment is bang on. We didn't have to fidget at all to get the alignment right. @firestormriot said Zeta test fits each exhaust to make sure it all fits together. ![]() 20130419-NabilZetaCatbackExhaust-088 by VictorN07, on Flickr Long shot under the car. I like this one ![]() 20130419-NabilZetaCatbackExhaust-093 by VictorN07, on Flickr SHot of installed Y-Pipe ![]() 20130419-NabilZetaCatbackExhaust-094 by VictorN07, on Flickr Dem pipes ![]() 20130419-NabilZetaCatbackExhaust-096 by VictorN07, on Flickr ![]() 20130419-NabilZetaCatbackExhaust-098 by VictorN07, on Flickr ![]() 20130419-NabilZetaCatbackExhaust-099 by VictorN07, on Flickr Quick Thoughts + The exhaust was very easy to install. Did not have to continually mess about to get good alignment + They fill in the bumper cutout nicely. They also fill the hole made by the bumper and diffuser together + Wasn't a big fan of the thin flanges + Welds were pleasing aesthetically + @firestormriot told me there is a 3lbs weight savings. Not super impressive + Fits an automatic gearbox so that is great. + The exhaust note was very smooth and there was no drone or rasp. Just like my Perrin headerback it gets out of the way when you want to cruise or go forth gentle. Apply throttle and it wakes up + It does have a deep tone. + I think it does its job well. Overall it was nice to be able to show someone new to cars how to mod it. I basically told him what tools he needed and told him what to do. I think he is very pleased with the way things came out. He'll update the first post with this detailed thoughts. Video With each review I strive to get better and better. OEM Exhaust [ame="http://www.youtube.com/watch?v=wjpEK2HlsgM"]Toyota 86 OEM exhaust - Zeta Performance Catback Exhaust Comparison - YouTube[/ame] Zeta Catback [ame="http://www.youtube.com/watch?v=476b-bdG3e8"]Zeta Performance Catback Exhaust Comparison - YouTube[/ame] Driving Review Part 1 of 2 This my first attempt at recording in car driving video. Let me know how I did. [ame="http://www.youtube.com/watch?v=Iaz0pS0S6kk"]Zeta Performance Catback Review - YouTube[/ame] Driving Review Part 2 of 2 [ame="http://www.youtube.com/watch?v=PZn_Du2yw0U"]Zeta Performance Catback Exhaust Review Part 2 - YouTube[/ame] Near Miss. Dammit Other drivers [ame="http://www.youtube.com/watch?v=RKkt3TnD-6o"]Zeta Performance Catback Goof - YouTube[/ame]
RedBunny w/ Wing
@firestormriot @F1point4 are you able to post some vid of the exhaust while driving???...want to hear how it sounds.
#4 | |
Photo Specialist
Drives: 2020 BRZ tS #54
Nice and clean.. Looking for exhaust for mine.. I want something that's not loud when driving normal and something that growls when I open it up ..
RedBunny w/ Wing
that is what I am looking at too..
Looks like we in the same boat :happy0180:
Yeah I'm not a fan of something that's loud when driving at normal rpm.. I'm sure it will annoy me if its loud... Its like them civic fart cans.. Loud AF but going slow.. Can't wait for the video upload.. |
Drives: 2013 Scion FR-S AT Asphalt
I've always thought that Zeta exhaust was VERY good-looking! Nice write up and thanks for taking the time to share!
Honestly I'm surprised that it still came out slightly lighter than stock. I would have thought it would have been heavier. Scott
#10 |
RedBunny w/ Wing
Yea man..on other hand, I was looking into the Nameless Axleback exhaust too. Heard lots good things about Nameless over the forum.
#11 |
Spun
Drives: 23' Supra
Hmm, great pics and install, but that exhaust just doesn't do it for me. So many unnecessary bends and twists. Exhaust seems like a great spot to cut weight out on the car and this is not the ticket for that. Also, the exhaust tips are blue, not sure what happened there? Is the single tube diameter 2.37"? That seems like the stock size, am I correct?
#12 |
Drives: Raven Black FR-S
interested in the sound clip as well.
And to the OP which setup for perrin headerback did you have? (i.e. nonres/cat) |
#13 |
Drives: SWP BRZ
nice and deep review
#14 | |
Drives: 2013 FRS
The 2.37 diameter is for the front pipe. Not exactly sure what the stock size is. |
| Tags |
| f1point4, zeta performance exhaust |
| Zeta Performance - Full Stainless Steel Cat-Back Exhaust System | ZetaPerformance | Engine, Exhaust, Transmission | 142 | 05-06-2015 12:38 AM |
| Zeta Performance Intake Review/Install | fmsida | Engine, Exhaust, Transmission | 20 | 08-15-2013 12:11 PM |
| ZETA Performance Cat-back Exhaust System - Stainless Steel, Titanium & Carbon Fiber | ZetaPerformance | Engine, Exhaust, Bolt-Ons | 30 | 07-18-2013 12:53 AM |
| FS: Zeta Performance Radiator Kit New | Asphalt~86 | Engine, Exhaust, Bolt-Ons | 0 | 04-15-2013 10:49 PM |
