Old 12-27-2020, 07:52 PM   #57
new2subaru
Weight Weenie
Drives: 15 FR-S
Originally Posted by 86TOYO2k17 View Post
Header for weight reduction and not HP?
What’s next, “I need help deciding what battery to get, i want something that looks cool, I don’t care about weight or CCA or Amp hours. Just want something to make the red on my car really pop?”
In all honesty I think the power is a given. The lightest header is still a bit of a ? mark. It's been written that your average header will give you 85-90% of the more expensive headers. I want it all, power and weight reduction and limited noise.
I may give the WRX/BRZ/FRS Willwood kit a shot though. I know the rotors are thinner but stock holds up fine. Only one way to find out!
Old 12-27-2020, 08:07 PM   #58
86TOYO2k17
Drives: 2017 toyota 86
Maybe, Removing the cat nets at least 50% of the total potential gains. Pipe diameter, runner length, EL vs UEL, and merge collector design will also contribute to the remaining gains.. Quality of welds and flanges etc... may differ with cheaper vs more expensive too, just things too consider. But Weight would be the least of my concerns when swapping headers, cost, hp gains, sound would be my greatest concerns, At that point you can’t really care about a 1-2lbs difference with aftermarket headers. I’m sure almost all are 7-10lbs lighter with no cats or heat shield.
The WW 4R are thinner, and less mass, so will heat up quicker but should cooldown quicker as well. This is why i think brake ducts would pair well with it.
Old 12-27-2020, 09:26 PM   #59
churchx
churchx's Avatar
Drives: 2014 GT86
Even stock brakes may benefit a lot from brake ducts and often result in something most consider BBK for. Not in lightening area, but at least one will keep great compatibility with different wheels & good wearables selection. Verus did well with their duct kit.
JIM THEO (12-28-2020)
Old 12-27-2020, 09:40 PM   #60
DarkSunrise
DarkSunrise's Avatar
Originally Posted by solidONE View Post
And I'm over here adding weight in the trunk cause it feels better balanced...
If it makes you feel better, the flywheel is closer to the front than the rear of the car!
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
solidONE (12-28-2020)
Old 12-28-2020, 12:06 AM   #61
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Battery relocation would work quite nicely to that effect, but trunk space.
Intent > Content
Old 12-28-2020, 12:10 AM   #62
solidONE
solidONE's Avatar
As far as headers go and sound. I think the better approach would be to pick the best power, then tune the sound and sound level via the front pipe and catback. Slap a carbon or titanium tip on any old muffler and it looks nice. lol
Intent > Content
Old 12-28-2020, 11:32 AM   #63
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It drives like it needs less to get the tail to rotate. I prefer leaving the spare in the trunk on the track as well.
and by adding weight I mean the amp for my sound system. lol
Should do the opposite but practical application=/=theory on normal use scale
Old 12-28-2020, 05:00 PM   #64
solidONE
solidONE's Avatar
There's more of a pendulum feel going on. Tail justs come around easier than without the weight.
I recall a friend of mine putting 50lbs of plates in place of his spare on his mazda 3 (fwd). That thing was drifting like a rwd in the canyons. lmao
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
NoHaveMSG (12-28-2020)
VVT Tuning Noise - ADDED: Comparison Video Dezoris Software Tuning 349 01-27-2020 03:46 AM
Swoosh noise headers NoobBRZ Engine, Exhaust, Transmission 18 01-31-2018 02:12 PM
Exhaust Cabin Noise, MXP UEL Headers and OP, Tsudo Catback HachiEnam Engine, Exhaust, Transmission 25 12-15-2015 05:47 AM
Road and Track: Tune + headers + axleback added to long term BRZ tennisfreak Engine, Exhaust, Transmission 42 01-07-2014 03:31 PM
[Bought] Borla (or lighter) headers Anthony Want-To-Buy Requests 4 08-28-2013 11:55 AM
