Old 01-29-2018, 03:57 PM   #1
NoobBRZ
Drives: Blue brz
Swoosh noise headers
So i installed my headerback exhaust around 12 days ago. Install took a while but thats just because of inexperience. Anyway there was one bolt that I had trouble reaching so I hand tightened it as much as i could and i couldn't fit my wrench or ratchet so i found some tiny vice grips and tried to tighten it further with that. No leaks everything was fine.
But now im starting to hear swoosh noises as if air was escaping. I've read that its normal for the tomei uel headers to make this noise because of the thinner metal used, but im so paranoid.
So, whenever im free im going to attempt to tighten everything again, but im wondering if you guys have any tips or suggestions on reaching that one bolt?
NoobBRZ is offline   Reply With Quote
Old 01-29-2018, 04:00 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
As they heat cycle you usually need to retighten them a couple times.
Old 01-29-2018, 04:06 PM   #3
NoobBRZ
Drives: Blue brz
Will do!
Old 01-30-2018, 06:38 AM   #4
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Thumbs down
Don't use vice grips
Get a socket extension get back up there and do it right. Torque those bolts where the header bolts into the block. Do it in the right pattern too (look for a YT video on how to do this). You WILL have CELs and all sorts of issues if you get it wrong.
Old 01-30-2018, 08:39 AM   #5
Submarinesonce
Drives: Frs
I used a universal and a wobble extension to get to that nut. a crows foot would be better, but I didn't have one.
JDL UEL Turbo GT2860RS, AP Racing BBK, Verus Splitter/diffuser/canards, Sard rep carbon wing, TFF bash bar, HKS hi power, Tein Flex A, Hotchkiss FSB, Radium MCB, Konig Hypergram 17x8, FS Indy 500, 6k HID, Whiteline trans bushing insert, Verus AOS, grimmspeed strut brace, Racerx oil cooler w/ setrab 619, ES steering rack bushings, Whiteline subframe bushings, Toms tails, STi mirror caps, IRP shifter, TRD Steering wheel
Submarinesonce is offline   Reply With Quote
Old 01-30-2018, 10:32 AM   #6
gtengr
Drives: 2017 BRZ
Yep. When I installed headers I heat cycled the engine a few times while everything was apart before doing final torque checks.
This.
gtengr is offline   Reply With Quote
Old 01-30-2018, 11:15 AM   #7
guybo
Huge E85 fan!
guybo's Avatar
I love me some wobble extensions!
Old 01-30-2018, 09:01 PM   #8
humfrz
Yes boss ...... yes boss .......right away boss .........
humfrz
guybo (01-30-2018)
Old 01-31-2018, 12:09 AM   #9
Ultramaroon
fabulous
Ultramaroon's Avatar
Make sure the flange nuts at the exhaust ports are properly torqued... but that's not the problem. Exhaust leaks at the ports make a popping sound.
I've only heard the whoosh in 2 situations, The first was when the flange nuts between my mid and rear pipe fell out. The other is the normal sound that every thin-walled header makes.
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
Cole (01-31-2018), D_Thissen (01-31-2018), FRSBRZGT86FAN (02-02-2018), strat61caster (01-31-2018)
Old 01-31-2018, 01:45 AM   #10
humfrz
So, @Ultramaroon , I reckon you wouldn't think much of my tool box .......
humfrz
Cole (01-31-2018), Ultramaroon (01-31-2018)
Old 01-31-2018, 01:51 AM   #11
humfrz
Are you saying you can get ahold of that bolt with a pair of vice grips but can't get one of these on it .........??
I ......
humfrz
Old 01-31-2018, 09:58 AM   #12
ermax
ermax's Avatar
What "one bolt" are we talking about? All the bolts to the block are super easy to reach with just a ratchet with extension. The bolts I have a hard time with are the ones on both ends of of the over pipe. I would love to get a torque wrench on them but there isn't enough clearance. I hate torquing on swivels because it throws off the spec. At least with a crowfoot you can do the math to get the correct torque spec on the bolt. I need to get a some crowfoots for my tool box.
Old 01-31-2018, 12:04 PM   #13
NoobBRZ
Drives: Blue brz
Yea excuse me noob habits lol, I have an extension I think I’m going to go buy some of those flexible joints bcuz it’s at a really weird angle
Old 01-31-2018, 12:06 PM   #14
NoobBRZ
Drives: Blue brz
Passengers side it’s between the Tomei pipes so it’s at a really weird angle. I just bought a torque wrench and some of those flexible joints. Hopefully I can reach it.
Can anyone direct me to a thread that has the proper spec I should torque all the exhaust bolts and nuts to?
Road noise? Tread Noise? zERoTu Issues | Warranty | Recalls / TSB 21 10-07-2020 11:21 PM
Exhaust Cabin Noise, MXP UEL Headers and OP, Tsudo Catback HachiEnam Engine, Exhaust, Transmission 25 12-15-2015 06:47 AM
Injen SES Headers/ Agency Power headers Choong86 Engine, Exhaust, Transmission 10 12-27-2013 10:51 PM
P&L Catted headers and Nameless catted Front pipe. Also is this cricket noise? Xdragonxb0i Engine, Exhaust, Transmission 23 04-24-2013 01:29 PM
