Old 11-24-2020, 10:56 PM   #15
Var
Drives: 2017 Subaru BRZ PP
I have 6k/6k on Tein Flex A and the ride quality is glorious. My friend has 12k/12k on his Tein 2-ways and it's more than acceptable, perfectly good ride. I had 4.5k/4.5k with stock PP struts and the ride quality was horrendous. Point being, shocks matter more
Var is offline   Reply With Quote
The Following 3 Users Say Thank You to Var For This Useful Post:
gpvecchi (11-25-2020), Ohio Enthusiast (11-25-2020), smg1138 (12-21-2020)
Old 12-09-2020, 10:15 PM   #16
r3myx626
r3myx626's Avatar
Drives: 2015 Subaru BRZ Limited ISM
I also have Flex As but I find them just okay. What damper settings do you use? At recommended 8 (out of 16) clicks from full hard they were too stiff for my roads and I finally settled around 10 clicks from full hard. It's a compromise but not even super comfortable and not responsive enough either at high speed.
r3myx626 is offline   Reply With Quote
Old 12-11-2020, 04:00 AM   #17
MrSkubi
MrSkubi's Avatar
Drives: 24 GR Yaris, 23 GR86
This is exactly my experience with them.
MrSkubi is offline   Reply With Quote
Old 12-11-2020, 08:48 AM   #18
ZDan
ZDan's Avatar
Drives: '23 BRZ
I've found lower-end to middle-range single-adjustables often kinda lacking. Despite adjustability, my old Tein SS coilovers on my FD were always way too harsh in high-speed damping. Replaced them with Ohlins Road & Track which were a *massive* improvement, but weirdly enough I found them to blow off a bit *too* much and would have liked to dial *in* some high- (or maybe mid-)-speed compression damping (which was pretty much unaffected by the single adjuster).
Really happy with the Bilstein B8 I got for the BRZ. Very good balance of high- and low-speed rebound and compression damping.
I think at the low/midrange of adjustables they might leave off a bit of development and/or have looser tolerances knowing that if customer thinks they're too stiff or too soft, they can at least twiddle a knob and make some kind of difference. But that doesn't mean they can get anywhere near ideal overall damping for their setup...
One reason I went with the non-adjustable Bilsteins was due to how good the "normal" factory-replacement KYBs we got for wife's Mazda3 were when its struts/shocks were all blown, and how impressed I was with the balance between high-/low- and rebound/compression damping. I thought they were better dialed-in than my adjustable Ohlins Road&Track dampers on the FD! That put it in my mind that I might rather have known-good non-adjustable performance-oriented dampers than even "good" midrange single-adjustables.
Old 12-14-2020, 03:54 PM   #19
Var
I have the CSG Tein Flex A. I don't know if the valving is different, but I use 9/12 for cruising around, and 8/8 for more uneven mountain roads, and 5/5 for track and smooth mountain roads
Old 12-15-2020, 01:54 PM   #20
r3myx626
r3myx626's Avatar
I haven't tried different settings front and rear. Will try messing it it. I also don't know if valving is different but I do know the adjustment range is different on CSG spec.
Old 12-21-2020, 04:16 PM   #21
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
For an everyday sporty setup you can't go wrong with RCE Yellows paired with Bilstein B6 dampers. If I didn't autocross and do track day stuff, I'd go that route myself.
smg1138 is offline   Reply With Quote
The Following User Says Thank You to smg1138 For This Useful Post:
Racecomp Engineering (12-21-2020)
Old 12-21-2020, 05:47 PM   #22
new2subaru
Weight Weenie
Drives: 15 FR-S
I has the RCE yellows on stock suspension and was happy with them. There's no need to run coils on the street IMO unless you want to lower more.
The Following User Says Thank You to new2subaru For This Useful Post:
gpvecchi (12-22-2020)
Old 12-23-2020, 01:37 AM   #23
Decep
Drives: 2013 FR-S Series 10
i liked rce yellows but not on bad roads. i might try em again with bilsteins at some point.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 12-23-2020, 04:18 PM   #24
gpvecchi
gpvecchi's Avatar
Finished with coilovers with 5k springs. Car is a little too flat for my tastes, perhaps 4-4.5k would be better...
Old 12-23-2020, 05:02 PM   #25
new2subaru
Weight Weenie
Drives: 15 FR-S
It'll feel like that at first but give it some time before making a change.
gpvecchi (12-24-2020)
Old 12-25-2020, 12:31 PM   #26
FeRS
bruh
FeRS's Avatar
Drives: Raven 2015 FRS
Anything over ~6k is into the 2hz+ natural frequency range, which is where you should have aero on your car. So under 6k is good imo.
<-- why is this an emote
FeRS is offline   Reply With Quote
The Following User Says Thank You to FeRS For This Useful Post:
gpvecchi (12-26-2020)
Old 12-25-2020, 12:59 PM   #27
JIM THEO
Drives: BRZ 2018
I should have told you my opinion from the beginning, don't choose coilovers for road use, a good road setup is much better imho!
JIM THEO is offline   Reply With Quote
The Following 2 Users Say Thank You to JIM THEO For This Useful Post:
gpvecchi (12-26-2020), Thefalls (12-25-2020)
Old 12-25-2020, 01:38 PM   #28
ZDan
ZDan's Avatar
Drives: '23 BRZ
6 front, 8 rear, yeah, that's what I get for 2 hz.
IMO that's a great place to be for a street/track car without aero. As you add significant aero downforce you'll begin to want/need to go stiffer from there....
Recommended Spring Rate? fuxkyou4you Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 01-06-2020 01:33 PM
spring rate of 2017 BRZ / 86 mokinbird87 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 03-31-2017 06:25 PM
BC extreme spring rate zachseidy39 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 08-26-2014 04:27 PM
Gazoo 86 spring rate ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 01-19-2013 09:47 AM
Best Spring Rate please help whitefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 09-30-2012 09:02 PM
