Old 10-01-2020, 04:54 PM   #1
gpvecchi
gpvecchi's Avatar
Which spring rate for road?
What do you suggest as spring rate for sprty use on windy roads?
I saw everything, from 3k to 8k...
gpvecchi is offline   Reply With Quote
Old 10-01-2020, 06:16 PM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
windy roads, canyon runs and so on .. are much closer to street .. those still are public roads, public roads, that usually get speed limits fit for even less sporty cars. And public roads where are way more uncontrolled variables and thus where safety margin should be wider. Hence i always considered such driving way closer to normal daily driving then to track .. and probably would choose spring rates similar to DD. There won't be driving on 8-10/10 limit as on track, most probably, if DD is 3/10, then eg. 4-5/10. No big side-Gs, no speed at traction/grip limit at every turn. Hence why compromise comfort if you don't gain for that what pros stiffer springrates may bring, just cons.
The Following User Says Thank You to churchx For This Useful Post:
nikitopo (10-02-2020)
Old 10-01-2020, 06:18 PM   #3
ZDan
ZDan's Avatar
Drives: '23 BRZ
~3-4 front, ~4-5 rear would be good...
I ran 3.8F/4.5R Swift BRZ Sport springs and I think they're a very good spring rate for spirited/sporty street duty.
Addendum:
I should add that these springs combined with front camber plates (Raceseng) lowered the car more than advertised, by 1.5" front and 1.25" rear. This had the car *hard* on the front bump stops and resulted in an intolerable ride on the street. I cut down the front bump stops and had spring spacers machined to raise the front by 0.25". This improved the ride a lot, but still intolerable over the smallest bumps on the street.
I *think* that without the camber plates (which reduce bump travel by ~15-20mm) these springs would be fine with stock struts.
But RCE Yellows at 4.5F/4.5R and 0.8" lower than stock are probably a safer bet...
The Following 2 Users Say Thank You to ZDan For This Useful Post:
gpvecchi (10-02-2020), strat61caster (10-01-2020)
Old 10-02-2020, 01:57 AM   #4
marco_mc22
Drives: Toyota 86
4K 5K or 5k square
marco_mc22 is offline   Reply With Quote
The Following User Says Thank You to marco_mc22 For This Useful Post:
gpvecchi (10-03-2020)
Old 10-02-2020, 05:40 AM   #5
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I'm satisfied with 4.5k front and rear with 20mm drop.
RCE yellows. Feels extremely balanced for street/canyon.
RToyo86 is online now   Reply With Quote
The Following 7 Users Say Thank You to RToyo86 For This Useful Post:
Dzmitry (10-02-2020), gpvecchi (10-03-2020), Racecomp Engineering (10-02-2020), sato (12-17-2020), smg1138 (12-17-2020), Spankopotomous (12-11-2020), ZDan (10-02-2020)
Old 10-02-2020, 10:13 AM   #6
ZDan
ZDan's Avatar
Drives: '23 BRZ
^^^ For stock struts/shocks, IMO RCE Yellows are the way to go. -0.8" (20mm) lower than stock and about 50% stiffer spring rates. Fun with no worries
Lower than that, you'll want to get Bilsteins for additional front bump travel and better damping than stock.
The Following 3 Users Say Thank You to ZDan For This Useful Post:
gpvecchi (10-03-2020), Racecomp Engineering (10-02-2020), smg1138 (12-17-2020)
Old 10-02-2020, 10:58 AM   #7
StraightOuttaCanadaEh
Wes
I find 5K too soft and will likely be going to 6K with my next coils, albeit with vastly better damping so there is no trade off in terms of comfort
Also keep in mind that the soft/hard adjustment has so much variability that you can make even 5K coilovers unlivable on anything but a smooth road and at the opposite end of the adjustment range make them so wafty that you feel like you're in a Rolls
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
Old 10-03-2020, 01:29 AM   #8
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Damping > spring rate.
The Following 7 Users Say Thank You to Captain Snooze For This Useful Post:
gpvecchi (10-03-2020), MrSkubi (11-25-2020), Racecomp Engineering (10-03-2020), SCFD (12-14-2020), Spankopotomous (12-11-2020), StraightOuttaCanadaEh (10-03-2020), Var (11-24-2020)
Old 10-03-2020, 07:53 AM   #9
Captain Snooze
Drives: Red Herring
uh oh, I can feel it on its way... oh no, it's
[serious mode]
You have noticed there is a wide variation in suggested spring rates. That's because there is no "best" answer. Different people have need wants and importantly, different impressions of how a particular rate feels. 6k with good damping might be acceptable to you but might too firm for someone else. The general condition of the roads you drive on will also have a bearing on this. The best solution would be to get rides in cars with differing set ups. If you can't do that, have a chat to either Andrew at RaceCompEngineering or Mike at CounterSpaceGarage. Explain what you are after, what you wanting to achieve and take their advice. I would suggest purchasing from who ever is closest to your home.
Axiom: quality costs.
[/serious mode]
The Following 5 Users Say Thank You to Captain Snooze For This Useful Post:
DarkPira7e (10-03-2020), gpvecchi (10-03-2020), Racecomp Engineering (10-03-2020), strat61caster (10-03-2020), Turdinator (11-26-2020)
Old 10-09-2020, 10:10 PM   #10
Decep
Drives: 2013 FR-S Series 10
depends on road conditions etc near you but 6k has been good to me. on bad roads its a bit too firm.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
The Following User Says Thank You to Decep For This Useful Post:
gpvecchi (10-10-2020)
Old 11-22-2020, 10:13 AM   #11
gpvecchi
gpvecchi's Avatar
Sorry to re-up, I almost made up my mind...
As lack of coilovers with reasonable price in Europe, I reduced my choices between 3 types of HKS (F6/R4, F5/R5, F4/R4) and ST XTA (F6/R5).
Suggestions?
Old 11-22-2020, 10:16 AM   #12
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I've ridden in a car with the STs, feels OEM+, they're amazing. I have no experience with the HKS, but they seem popular.
DarkPira7e is online now   Reply With Quote
The Following User Says Thank You to DarkPira7e For This Useful Post:
gpvecchi (11-23-2020)
Old 11-22-2020, 10:37 AM   #13
new2subaru
Weight Weenie
Drives: 15 FR-S
I have Ohlins which had the 4k F and 3K rear. I replaced the rear with a 4K spring and am now going to 5K F and 5K rear. I may go 6K alll around in the future.
I've also had the stock dampers with RCE yellows which felt good.
Good news is springs are relatively cheap to change out. I'm learning a lot by changing things up.
The Following User Says Thank You to new2subaru For This Useful Post:
Old 11-22-2020, 11:35 AM   #14
marco_mc22
Drives: Toyota 86
I would say St with flipped springs or 5k springs up front.
Recommended Spring Rate? fuxkyou4you Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 01-06-2020 01:33 PM
spring rate of 2017 BRZ / 86 mokinbird87 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 03-31-2017 06:25 PM
BC extreme spring rate zachseidy39 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 08-26-2014 04:27 PM
Gazoo 86 spring rate ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 01-19-2013 09:47 AM
Best Spring Rate please help whitefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 09-30-2012 09:02 PM
