#15 | |
Drives: 2019 Toyota 86 TRD SE
Ah it’s not my daily so I don’t drive it much. The cars 2 years old and I only have 4K miles on it. Sent from my iPhone using Tapatalk |
#16 | |
The Bilsteins are IMO a solid upgrade over the PP sachs struts, but up to you if you want to replace them so early! - Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Drifter X (12-22-2020) |
#17 | |
Thanks so much for the info! I’m not quite sure I want to replace them so early. As for the roads here.... they’re terrible lol. Lots of potholes. I try my best to avoid them but sometimes that’s just not possible. There no track here... yet. But now the B6 is now on the top of the list of options. Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to Drifter X For This Useful Post: | Racecomp Engineering (12-22-2020) |
#18 | |
Drives: '23 BRZ
| The Following 3 Users Say Thank You to ZDan For This Useful Post: |
#19 |
Drives: BRZ 2018
#21 |
Andrew,
I went through the entire RCE SS1 thread and wanted to get your thoughts on the b6 vs the ss1? Sent from my iPhone using Tapatalk |
#22 | |
stiffer springs (better for the track) camber plates (if you do need more camber) wheel clearance (if running wider wheels/tires) adjustable damping (if you like adjusting things) adjustable ride height (and can go a little lower) Bilstein B6 used with softer springs (slightly better ride at least when paired with OEM springs) simple (easy set up) little bit cheaper Both are durable and fairly comfortable. The SS1s are about as "easy" as it can get in terms of living with a coilover, but there is still more set up getting the little things right (which we can help with). The camber plates are quiet, they ride well, and they have a warranty. But...B6 are just super simple which can be a good thing for some people. Nothing to mess with other than getting a proper alignment. More adjustability can be nice, but simplicity is actually a big priority for a lot of people (and sometimes you have a rulebook making those decisions for you). Depends on what you're looking for... - Andrew |
#23 |
I am 57k. When I hit 80k, I see yellows and B6 in my future. I thought about the super streets but no track for this car, just DD and some spirited runs here or there.
| The Following 2 Users Say Thank You to Ernest72 For This Useful Post: | Racecomp Engineering (12-23-2020), RToyo86 (03-12-2021) |
#24 |
Drives: '15 BRZ RA
Good option!
| The Following User Says Thank You to nikitopo For This Useful Post: | Racecomp Engineering (03-12-2021) |
#25 |
Persona Non Grata
Drives: '15 BRZ (WRB)
I have BidenBucks/KamalaCash melting a hole in my checking account. So, it may be down to a coin flip - B6s with comfy springs or a flexfuel kit/tune.
Slow is smooth, and smooth is fast
| The Following User Says Thank You to Capt Spaulding For This Useful Post: | pope (03-15-2021) |
#26 |
Drives: 13 BRZ, 17 Focus RS
The only thing I’ve wondered is if there’s a difference in the front B6 vs B8 compressed length at which bumpstop(Bilstein internal) contact is made and if that would have a noticeable handling difference. I think RCE may have brought that up in other threads. Overall I’ve been happy with SpecR/B6 on an Evo and the BRZ. Will probably get a set for the FiST soon too.
#27 |
Photo dump from the weekend. Bear with me, lots going on over here.
You can see a few small differences here between B6 fronts and stock. The B6 is kind of shifted downwards, but things do line up in terms of attachment points and where the spring sits. Overall stroke is roughly the same. ![]() I did not take apart the fronts to measure the internal bumpstop. ![]() The rear spring seats for the BRZ are a separate piece. ![]() This is a crap picture, sorry. The rears line up with each other pretty closely. OEM rear bumpstop and dustboot get transferred over to the Bilsteins. ![]() I wish they had the nice blue Bilstein dustboots, but they don't do that anymore. ![]() ![]() Installed with some nice adjustable endlinks (OEM work fine too) ![]() - Andrew |
| The Following 6 Users Say Thank You to Racecomp Engineering For This Useful Post: | bhmax (03-16-2021), Ohio Enthusiast (03-16-2021), RToyo86 (03-24-2021), SCFD (03-17-2021), Spankopotomous (03-17-2021), Thefalls (03-16-2021) |
#28 |
Drives: Corolla GT
Thats very nice Andrew.
Now go have a nice drive and let us have a nice detailed review from you. ![]() I would have loved red springs, to look like the STI Bilstein kit. Also, can you post pictures of the car to show the ride height change from stock? Im curious about the drop and if the forward rake is still maintained. Thanks a lot. |
| Koni Yellow vs. Bilstein B6 vs. Bilstein B8 | shattered_memory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 01-04-2017 11:22 AM |
| AVCS Explained | Rennmeister | Engine, Exhaust, Transmission | 3 | 03-15-2016 03:12 AM |
| STX Bilstein Double Adjustable Package - Bilstein PSS with Dual Bleed Shafts | FRSport.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 02-25-2016 12:50 PM |
| Ok, who has stories that can't be explained? | husker741 | Off-Topic Lounge [WARNING: NO POLITICS] | 143 | 11-26-2014 05:25 AM |
| Part of the problem explained. | Suberman | CANADA | 95 | 01-28-2014 01:26 PM |
