Old 12-17-2020, 07:32 AM   #1
Gloonge
Drives: 2013 frs raven
More fuel trim questions.
Back again guys.
Been on my final tune for my SC for a few months everything running smooth. Decided to hook up my oft to data log the other day and noticed that my fuel trims are doing some strange things.
At idle everything is nominal and of course at higher throttle range they go into closed loop, no issues there. But starting at about 10% throttle (before boost) and all the way until open loop my LTFTs run to around - 15% and STFTs run up to +15%. Everything bounces back to normal when I drop back down to idle. Afr and command afr are within a few tenths of each other at all times.
Never seen anything like this, is it a software issue a reflash will fix or anyone know where I should start looking?
There are no running issues, just this data point.
Gloonge is offline   Reply With Quote
Old 12-18-2020, 11:25 AM   #2
FR_STEEZ
Drives: 2017 toyota 86
wouldn't that mean your fuel trims are technically at 0
FR_STEEZ is offline   Reply With Quote
Old 12-18-2020, 11:30 AM   #3
Gloonge
I guess technically. Just never seen anything like it.
Turns out it solved its self, this morning everything went back to normal. Maybe bad gas? No idea.
Anyone else with ECUTEK having fuel trim issues. Shit Luck Software Tuning 12 11-14-2021 10:58 PM
Torque data log interpretation - Fuel Trim, AFR, Timing Etc Butterballz Issues | Warranty | Recalls / TSB 6 07-31-2019 11:02 PM
fuel trim John27 Scion FR-S / Toyota 86 GT86 General Forum 2 04-21-2017 04:08 PM
UPDATED!! OFT E85 EL map, high LT fuel trim zmz0305 Software Tuning 24 09-10-2016 03:32 PM
Fuel system questions. Boost-A-pump/stock fuel lines for engine swap Toxicmilk45 Engine, Exhaust, Transmission 4 12-14-2015 03:52 PM
