Old 04-02-2015, 01:48 PM   #1
Shit Luck
Drives: red frs
Anyone else with ECUTEK having fuel trim issues.
I am having issues with fuel trims.
long term goes full negative and short term goes full positive.
I have been told its a glitch with ecutek causing it to happen to my car. They instructed me to try reloading my tune a few times and to this point I have had no luck in resolving the issues.
anyone else had or seen this issue?
Shit Luck is offline   Reply With Quote
Old 04-02-2015, 01:54 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
Is it just a logging issue perhaps rather than a ROM problem? What's your cal ID, RaceROM version etc? I've not logged mine recently so can't confirm.
Have you shot ECUtek or your Master Tuner an email?
If it's only done it since an update to ProECU then maybe try rolling back to the last known version. It's in the ECUtek directory on your laptop.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-02-2015, 01:57 PM   #3
Koa
define full positive and full negative
post a log
can't help you without adequate info
Old 04-02-2015, 02:35 PM   #4
xxscaxx
Drives: 2013 SWP BRZ
damn man, i guess your user name really is fitting. Is this the reason why your car hasn't been running correctly? Saw your posts in the JDL thread, just wondering if its all related or if the BOV spring helped correct issues (or its been this the whole time).
I'm very surprised that this wasn't picked up on a data log that i'm sure you had sent to Bill.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
Shit Luck (04-02-2015)
Old 04-02-2015, 04:17 PM   #5
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
We have seen this issue in a couple cars over the past two years. What we will notice is the long term fuel trims will max out (-35%) and because of that the short term fuel trims will then try to max out in the opposite direction because it is too lean (+25%).
Problem is we have shut off all long term fuel trims and it should not be correcting for long term at all yet the ECU still corrects.
Now we did experience one car with this exact same issue and they had after market HID's (made in China). The aftermarket ballasts were only sealed in plastic, not metal like they should be. Well these ballasts give off a lot of RF signals (plastic does not protect against that) and therefore interrupt the signals to the ECU, especially on the CAN lines.
When this was removed it fixed the problem in that one car. Do you have any electronics aftermarket parts in the vehicle?
Cheers,
William Knose
The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post:
gpvecchi (11-10-2021), xxscaxx (04-02-2015)
Old 04-02-2015, 10:01 PM   #6
Shit Luck
Drives: red frs
Cheers,
William Knose
As we discussed previously I have no aftermarket parts in my car other than suspension, clutch and motor mods. I only have a manual boost gauge. For now.
Old 11-10-2021, 01:25 AM   #7
bokehmon
Drives: 2014 DMG BRZ
Necro'd thread post - I'm having a similar issue, but with an edelbrock supercharger on.
Here's a quick log:
https://datazap.me/u/bokehmon/log-16...&data=31-34-35
bokehmon is offline   Reply With Quote
Old 11-10-2021, 02:26 AM   #8
tomm.brz
Drives: brz 2017 hksv2
not too bad but it needs a fix to not let fuel trims fight each other
Old 11-10-2021, 02:26 AM   #9
tomm.brz
Cheers,
William Knose
Set closed loop target to 14.7 and ltft will go disabled
Old 11-10-2021, 05:56 AM   #10
steve99
I think it might be the maf scaling is not good
when it goes open loop the target AFR is way leaner then measured ( and only scaled to 11 afr max rich. ( and it just maxes out sensor) the target seems way lean for boost as well assuming it petrol. I say they tuned it on tailpipe wideband.
also the manifold pressure is weird maxes at 1.17 bar so only reading to 0.17 bar boost strange, i thought it was relative but looks absolute.
Old 11-10-2021, 05:58 AM   #11
steve99
Here's a quick log:
that looks unusual fuel trims high. Target afr vs actual afr way different in open loop and manifold pressure maxing out at 0.17 bar boost .
Old 11-12-2021, 06:28 PM   #12
bokehmon
With throttle / going into boost, it's hitting a high of 1.17 bar - most of the log is pretty much just cruise to get open loop, found a .93 bar~ in the log here:
https://datazap.me/u/bokehmon/log-16...zoom=5525-5850
Is that an abnormal manifold pressure for an edelbrock supercharger with stock everything?
Thanks for the help! I'm pretty new to this stuff, so anything to help me read it correctly is much appreciated!
Old 11-14-2021, 11:58 PM   #13
steve99
manifold pressure at idle does seem low
does it read 1 bar with ignition on but motor stopped ?
messaged you
Fuel pump issues jamesm Software Tuning 17 07-10-2018 06:46 AM
Fuelling Issues (ECUtek ROM) Kodename47 Software Tuning 4 03-17-2014 05:13 AM
Fuel Starvation issues? YAY OR NAY? track_warrior Tracking / Autocross / HPDE / Drifting 23 10-22-2013 12:19 PM
ECUtek issues 20firestorm13 Engine, Exhaust, Transmission 12 05-24-2013 12:09 AM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 10:36 AM
