More fuel trim questions.
Back again guys.
Been on my final tune for my SC for a few months everything running smooth. Decided to hook up my oft to data log the other day and noticed that my fuel trims are doing some strange things. At idle everything is nominal and of course at higher throttle range they go into closed loop, no issues there. But starting at about 10% throttle (before boost) and all the way until open loop my LTFTs run to around - 15% and STFTs run up to +15%. Everything bounces back to normal when I drop back down to idle. Afr and command afr are within a few tenths of each other at all times. Never seen anything like this, is it a software issue a reflash will fix or anyone know where I should start looking? There are no running issues, just this data point. |
wouldn't that mean your fuel trims are technically at 0
Turns out it solved its self, this morning everything went back to normal. Maybe bad gas? No idea. |
| All times are GMT -4. The time now is 02:00 PM. |
User Alert System provided by
