Old 12-15-2020, 09:14 PM   #15
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
@Racecomp Engineering Are there any particular springs that pair best with these shocks? I may eventually move back to a spring/shock combo when my coilovers are ready to be replaced. If I end up not getting them rebuilt anyway.
smg1138 is offline   Reply With Quote
Old 12-15-2020, 09:32 PM   #16
churchx
churchx's Avatar
Drives: 2014 GT86
Spring choice .. imho just as with stock shocks, as B6 are marketed as OE damper replacement and thus should work sufficiently well with both stock springs and aftermarket ones that don't differ too drastically from them.
Imho RCE yellow springs that are slightly lower and slightly stiffer then stock should work well and seem popular/safe choice. Not option for me, as i don't wish for even slight lowering/ground clearance reduction, but many spoke well of RCE yellows.
Old 12-16-2020, 03:17 AM   #17
sygfrid
FT8Syg
sygfrid's Avatar
Drives: `12 FRS & `17 BRZ Inazuma
I have B6 but with TRD lowering springs. Though Bilstein B6 is marketed as built with OEM quality standards, they are very much different from stock! B6 are gas pressured, while OEM's are oil-based.
If you'll use the B6 with the stock springs, you may notice that it may sit just a little higher. It's because the B6 is resisting the compression more than the stock shocks. If you're gonna install the B6 anyways, I highly suggest that you take advantage of the sprotiness of the TRD's in both handling & aesthetics that the mild drop of 1" that the TRD brings. Wheel-it -fit even says that there's plenty of suspension clearance if you drop by 1". Also, take advantage of the opportunity that you're working on your suspension as changing springs & dampers is not an easy task. This combo is quite stiff BUT not HARSH unlike the stock setup especially for daily driving. I can even say that it's more comfortable than stock even on uneven roads.
For my winters, I have the TRD 18x7.5J +35 w/ 225/40 on all 4's & they are -3mm from flush. I have recently bought a new set of 18x8.5J +45 that'll have 225/40 which, according to wheel-it-fit, will be -2mm from flush. I'll have the latter installed in the summer though so I can't verify the fitment. Nevertheless, IMO, you don't need spacers anymore as even at -3mm, it looks already flushed. Besides, adding spacers will add unsprung weight.
And wheel weight does matter!
I also have Enkei PF01 18x7.5 +x45 with 225/40 that weighs 17.65 lbs vs the TRD's 24 lbs, & I have tried them both for summers. Lifting them both alone, I can already notice the huge difference in weight (considering I've been lifting weights for 8 yrs now). Handling-wise the PF01 is more agile too & easier to accelerate.
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
sygfrid is offline   Reply With Quote
The Following User Says Thank You to sygfrid For This Useful Post:
Thefalls (12-17-2020)
Old 12-16-2020, 09:20 AM   #18
Biased of course but Bilstein B6 and RCE Yellows is one of my favorite all around set ups. It's a great street and light auto-x/track combo. Simple and fun.
Most springs work well including stock...milder drops almost always work better.
- Andrew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
RToyo86 (12-16-2020), smg1138 (12-16-2020), Ultramaroon (12-16-2020)
Old 12-16-2020, 12:22 PM   #19
ZDan
ZDan's Avatar
Drives: '23 BRZ
Very very pleased with Bilstein B8s (same damping as B6, only difference is less droop travel) with Swift Spec-R springs, which have the same front rate as RCE Yellow and slightly stiffer rear rate. No lie, I think the damping for these springs is as good or better vs damping I had with Ohlins Road & Track on my FD RX-7. I highly highly recommend the Bilstein B6/B8 with RCE Yellows, and I think they'd be good with RCE Tarmacs as well. Or for more lowering, with Swift Sport or Spec-R springs.
The Following 4 Users Say Thank You to ZDan For This Useful Post:
holeeray (12-18-2020), Racecomp Engineering (12-16-2020), RToyo86 (12-16-2020), Thefalls (12-17-2020)
Bilstein B16 wheel fitment Canehda Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 05-30-2016 12:09 PM
Front wheel clearance. Nigelr32 Cosmetic Modification (Interior/Exterior/Lighting) 7 01-04-2015 06:52 AM
Wheel/tire clearance noob Border7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 11-02-2014 06:37 PM
Left and right wheel fender clearance shirouxkamui Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 04-14-2013 06:42 AM
Inner wheel clearance at the front spiller Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 06-27-2012 12:40 PM
