#379 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Sprue you!
Yeah, that's the ticket.
"I gotta rock." -- Charley Brown |
| The Following 4 Users Say Thank You to bcj For This Useful Post: |
#380 |
Drives: GR Corolla
#381 | |
Wes
Instagram: @gt86ws
#382 |
Drives: GR Corolla
With the other one I did, I brought the painted parts into the house since I thought there would be higher chances of dust in the garage. Haha. It did smell a little.
#383 |
Drives: GR Corolla
Here we go. One coat of gray primer on. This lays thicker than the pink one I used on the R32. Guessing another quick coat would be enough before laying the color coat.
#384 |
Drives: GR Corolla
First layer of the color. Not a fan of Testors/Model Master spray paints. Might be the nozzle, but it sprays in a splatter kind of pattern. Not uniform and nice like the Tamiya spray cans. The farther I spray the can, the more splatters. So I tried a little closer with the bottom of the chassis, paint clumps together and becomes super thick.
| The Following 2 Users Say Thank You to Kaotic Lazagna For This Useful Post: | JD001 (12-20-2020), Ultramaroon (12-19-2020) |
#385 |
Can get close as long as you also speed up your swing across the work piece. You have to really speed up. Takes practice to time pressing the valve.
There are limits just like there are some really shitty spray nozzles
#386 |
Drives: GR Corolla
I think I read online that that's what people complain about Testor's spray cans; that they use crappy nozzles which leads to the spraying issue that I had. I can also see this will have a lot more orange peel than the Tamiya. I still have the pearl clear coat to spray, but I'll wait a week to do that since I also read that Testor paint takes foooreeeeeeever to cure. Sucks that Tamiya doesn't do pearl purple. Well, at least now I know to avoid Testor. lol. I guess that's also why there were so many Testor cans left at the hobby shop I went to, and barely had any Tamiya cans.
| The Following User Says Thank You to Kaotic Lazagna For This Useful Post: | Ultramaroon (12-19-2020) |
#387 | |
I'm more of a tool hound than I am a modeler but I've had excellent results mixing my own paint.
#388 | |
Drives: GR Corolla
![]() So I just noticed that the Testors color I used is an enamel. I'm pretty sure the Tamiya pearl clear I plan on using is a lacquer. Does anyone know if this will be an issue? Edit: googled it, and found mix reviews. Some people did say they just let the enamel dry for at least a week or two, and then used Tamiya clear on it by using very light coats. Looks like the R33 body won't be done for a long time since I think I have to spray another coat of the pearl grape since it doesn't adhere to edges very well (another reason why I won't ever buy Testors/Model Master again). Edit #2: didn't want to waste my effort, plus the Tamiya pearl clear, so I went ahead and ordered a can of Model Master enamel gloss top coat. I'll just save the pearl clear for another model. Now I'm debating on if I should try spraying on another layer of the pearl grape since the edges of panels are much lighter since it doesn't seem like this paint adheres well to edges. Last edited by Kaotic Lazagna; 12-20-2020 at 07:22 PM. |
#389 | |
ProCrastinationConsultant
it's why harbor freight sells $20 HVLP auto spray guns. guy's will spray their real car and toss the gun in the end. cheaper and easier.
| The Following User Says Thank You to soundman98 For This Useful Post: | Ultramaroon (12-20-2020) |
#390 | |
Although I still have the original gun and now have all the supporting tools, I've only used rattle cans since then because lazy. Even the best nozzles are shit compared to the real deal.
| The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
#391 |
Drives: GR Corolla
Since I can't touch the R33 due to the enamel paint still not being cured, I decided to start working on the R34. Sanded down the mold lines, and cut out the hood (much easier than the R33's hood). I think it's expected to rain starting tomorrow, so can't really do anything else to the R34. I still gotta finish scribing the panel lines though.
| The Following 3 Users Say Thank You to Kaotic Lazagna For This Useful Post: |
#392 |
Drives: GR Corolla
Scribing done. Put on the black accent lines. Dry fitted the spoiler and wheels to see how it will look. Can't wait to paint everything and get it done now!
| TRD ABS Plastic Kit? | Shims | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 07-19-2015 07:31 PM |
| Front lip - abs plastic | _frs | Want-To-Buy Requests | 0 | 09-21-2014 11:11 AM |
| Trade my black dash plastic for your silver dash plastic thread. | F3dzo | Southeast | 0 | 07-17-2012 10:06 PM |
| plastic interior | lancie | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 10-16-2011 01:02 PM |
