Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
12-11-2020, 03:38 PM | #1 |
Drives: 2015 BRZ Limited
Wheel clearance with Bilstein B6?
I was planning on going going a bit bigger with aftermarket wheels. I've read that the stock suspension spring perches kinda limit you on size. I purchased Bilstein B6s and was wondering if that gave me any more room under there for larger wheels/tires?
For reference I'm thinking 18x8.5 +45 with 225/45ish tires.
Bone stock
12-11-2020, 04:21 PM | #2 |
Drives: 17 Asphalt 86
This is a useful tool.
www.ft86motorsports.com/wheelitfit That setup will be quite tight to the strut. I have 17x8 + 46 with stock tire sizing and this is the clearance for reference. https://imgur.com/a/TFXrsER |
The Following User Says Thank You to RToyo86 For This Useful Post: | holeeray (12-11-2020) |
12-11-2020, 05:26 PM | #3 |
Drives: '13 FRS - STX
No.
The large OE springs and spring perch are what limits clearance. |
The Following 2 Users Say Thank You to strat61caster For This Useful Post: | holeeray (12-11-2020), Racecomp Engineering (12-11-2020) |
12-11-2020, 07:12 PM | #4 | |
Thanks! Does that whelitfit website account for the strut size? :edit: Nevermind, I see where it tells you suspension distance.
Bone stock
12-11-2020, 08:21 PM | #5 |
Drives: '13 Whiteout
I think the B6 is out of stock everywhere
12-11-2020, 08:32 PM | #6 |
I actually already got the B6's. The wheelitfit website is saying I'll have about 2mm of space between tire and suspension. Should I consider a spacer?
Bone stock
12-11-2020, 10:36 PM | #8 |
12-12-2020, 07:26 AM | #9 | |
If you want to add camber bolts at any point, that gap will be even Tighter. Last edited by RToyo86; 12-12-2020 at 09:31 AM. |
The Following User Says Thank You to RToyo86 For This Useful Post: | holeeray (12-12-2020) |
12-12-2020, 08:59 AM | #10 | |
Bone stock
12-12-2020, 09:38 AM | #11 | |
I have a set of FT86MS 3mm aluminum spacers on my girlfriends 2020 Impreza for caliper clearance. They are hub centric. I run their old design 10mm slip on spacers. New design has 56mm hub rings added to center the wheel on the spacer. |
12-12-2020, 11:33 AM | #12 |
12-12-2020, 01:07 PM | #13 |
Drives: '23 BRZ
I got a set of 3mm spacers from Counterspace Garage earlier this year.
The Following User Says Thank You to ZDan For This Useful Post: | holeeray (12-12-2020) |
12-14-2020, 08:56 AM | #14 |
They're better in every way. The OEM dampers kinda go overboard on the "feel stiff to feel sporty" approach which isn't necessarily good for handling and definitely not good for ride quality. Just a much more advanced shock with the Bilsteins and a better overall valving profile.
Really looking forward to putting the set next to me on my car, but waiting on a certain set of springs. - Andrew |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | smg1138 (12-15-2020) |
Similar Threads | ||||
Bilstein B16 wheel fitment | Canehda | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 05-30-2016 12:09 PM |
Front wheel clearance. | Nigelr32 | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 01-04-2015 06:52 AM |
Wheel/tire clearance noob | Border7 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 11-02-2014 06:37 PM |
Left and right wheel fender clearance | shirouxkamui | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 04-14-2013 06:42 AM |
Inner wheel clearance at the front | spiller | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 06-27-2012 12:40 PM |
