Old 12-11-2020, 03:38 PM   #1
holeeray
holeeray's Avatar
Drives: 2015 BRZ Limited
Wheel clearance with Bilstein B6?
I was planning on going going a bit bigger with aftermarket wheels. I've read that the stock suspension spring perches kinda limit you on size. I purchased Bilstein B6s and was wondering if that gave me any more room under there for larger wheels/tires?
For reference I'm thinking 18x8.5 +45 with 225/45ish tires.
Bone stock
holeeray is offline   Reply With Quote
Old 12-11-2020, 04:21 PM   #2
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
This is a useful tool.
www.ft86motorsports.com/wheelitfit
That setup will be quite tight to the strut. I have 17x8 + 46 with stock tire sizing and this is the clearance for reference.
https://imgur.com/a/TFXrsER
The Following User Says Thank You to RToyo86 For This Useful Post:
holeeray (12-11-2020)
Old 12-11-2020, 05:26 PM   #3
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
No.
The large OE springs and spring perch are what limits clearance.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
holeeray (12-11-2020), Racecomp Engineering (12-11-2020)
Old 12-11-2020, 07:12 PM   #4
holeeray
holeeray's Avatar
Thanks! Does that whelitfit website account for the strut size?
:edit: Nevermind, I see where it tells you suspension distance.
Bone stock
Old 12-11-2020, 08:21 PM   #5
TommyW
TommyW's Avatar
Drives: '13 Whiteout
I think the B6 is out of stock everywhere
TommyW is offline   Reply With Quote
Old 12-11-2020, 08:32 PM   #6
holeeray
holeeray's Avatar
I actually already got the B6's.
The wheelitfit website is saying I'll have about 2mm of space between tire and suspension. Should I consider a spacer?
Bone stock
Old 12-11-2020, 09:59 PM   #7
TommyW
TommyW's Avatar
try it and see. How are your wheel wells looking. Would spacers help in that area?
The Following User Says Thank You to TommyW For This Useful Post:
holeeray (12-12-2020)
Old 12-11-2020, 10:36 PM   #8
We have a couple sets in stock.
- Andrew
The Following 5 Users Say Thank You to Racecomp Engineering For This Useful Post:
holeeray (12-12-2020), RToyo86 (12-12-2020), smg1138 (12-15-2020), Tanstin (12-12-2020), TommyW (12-11-2020)
Old 12-12-2020, 07:26 AM   #9
RToyo86
RToyo86's Avatar
Worth a try to see, but a spacer wouldn't hurt. 3mm is about all you can do without extended wheel studs. It's possible to fit 2.5" ARP studs on the rear if you can't get the hub off. Minor Dremel work.
If you want to add camber bolts at any point, that gap will be even Tighter.
Old 12-12-2020, 08:59 AM   #10
holeeray
holeeray's Avatar
Worth a try to see, but a spacer wouldn't hurt. 3mm is about all you can do without extended wheel studs. It's possible to fit 2.5" ARP studs on the rear stud if you can't get the hub off. Minor Dremel work.
I'm only seeing a minimum of 5mm spacers from "reputable" brands. Any recommendations on 3mm spacers? I've found a couple, but I don't recognize the brands and can't seem to find any reviews on them.
Bone stock
Old 12-12-2020, 09:38 AM   #11
RToyo86
RToyo86's Avatar
3mm is pretty minor, so long as it's hub centric at 56mm any should work.
I have a set of FT86MS 3mm aluminum spacers on my girlfriends 2020 Impreza for caliper clearance. They are hub centric.
I run their old design 10mm slip on spacers. New design has 56mm hub rings added to center the wheel on the spacer.
Old 12-12-2020, 11:33 AM   #12
TommyW
TommyW's Avatar
- Andrew
How are those compared to the stock dampers?
Old 12-12-2020, 01:07 PM   #13
ZDan
ZDan's Avatar
Drives: '23 BRZ
I got a set of 3mm spacers from Counterspace Garage earlier this year.
Old 12-14-2020, 08:56 AM   #14
They're better in every way. The OEM dampers kinda go overboard on the "feel stiff to feel sporty" approach which isn't necessarily good for handling and definitely not good for ride quality. Just a much more advanced shock with the Bilsteins and a better overall valving profile.
Really looking forward to putting the set next to me on my car, but waiting on a certain set of springs.
- Andrew
Bilstein B16 wheel fitment Canehda Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 05-30-2016 12:09 PM
Front wheel clearance. Nigelr32 Cosmetic Modification (Interior/Exterior/Lighting) 7 01-04-2015 06:52 AM
Wheel/tire clearance noob Border7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 11-02-2014 06:37 PM
Left and right wheel fender clearance shirouxkamui Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 04-14-2013 06:42 AM
Inner wheel clearance at the front spiller Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 06-27-2012 12:40 PM
