Old 07-25-2012, 08:52 PM   #1
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
I slip my rear tires on a daily basis....
And it's hilarious! My family insists that some part of my car is scraping on the driveway when I pull in and I thought that too until the second time when I actively noticed the noise coming from the rear. Lately the traction light has been coming on now too. I'm going to replace the VSC/Sport button with a "Driveway mode" button
[ame="http://www.youtube.com/watch?v=1SfGmM1sbu0&feature=plcp"]Subaru BRZ torsen LSD in action - YouTube[/ame]
I'd probably be worried about wearing out my rear left tire prematurely if I didn't slip the tires elsewhere anyways.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 07-25-2012, 09:15 PM   #2
sho220
sho220's Avatar
Drives: FR-S MT & FJ Cruiser
Mine does the same thing leaving the entrance at work...every time...
sho220 is offline   Reply With Quote
Old 07-25-2012, 09:29 PM   #3
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Torque-sensing (torsen) diffs do that. If one tire is in the air the diff is essentially open. But if the spinning tire has even a little bit of grip, the diff will lock up and get you moving.
The Following 2 Users Say Thank You to Draco-REX For This Useful Post:
dori. (07-27-2012), Laika (07-25-2012)
Old 07-25-2012, 09:51 PM   #4
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Hmm interesting, I didn't know about that. I don't know if the title of my video shows up but I was aware that it had to do with the Torsen LSD
Old 07-25-2012, 10:03 PM   #5
OrbitalEllipses
Drives: Attitude
That's why racers consider clutch type/mechanical differentials vastly superior: they never act as open diffs, even with a wheel in the air.
Old 07-25-2012, 10:15 PM   #6
Draco-REX
Corner Junkie
Draco-REX's Avatar
But OEMs use sealed viscous units or torsen diffs because their maintenance is nearly the same as an open diff and won't require special oil additives.
Old 07-25-2012, 10:17 PM   #7
OrbitalEllipses
Drives: Attitude
And they're not as noisy or problematic at low speeds/parking lots.
Old 07-25-2012, 10:21 PM   #8
Draco-REX
Corner Junkie
Draco-REX's Avatar
No kidding. My tow vehicle is an Ambulance. Those have clutch type LSDs for snow traction. Ever hear a 1-ton LSD in a tight turn? Sounds like someone wailing on the axle with a sledgehammer.
The Following User Says Thank You to Draco-REX For This Useful Post:
bestwheelbase (08-07-2012)
Old 07-25-2012, 11:22 PM   #9
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
dude my car does that all the time when i reverse in my garage, at first i thought it scraped til i found out it was the tire spinning
Old 07-26-2012, 12:35 AM   #10
ranisron
Drives: 2013 SWP BRZ Limited #2344
Try welded diff :-)
ranisron is offline   Reply With Quote
Old 07-27-2012, 06:30 PM   #11
pr086
Drives: fast
it didnt look like 1 wheel was in the air in this vid, what would cause it to slip like that at such a low speed?
pr086 is offline   Reply With Quote
Old 07-27-2012, 06:56 PM   #12
sbxjap
sbxjap's Avatar
Drives: '95 Honda Civic HB/'13 Subaru BRZ
Maybe gravel? Dunno....
sbxjap is offline   Reply With Quote
Old 07-27-2012, 07:22 PM   #13
sandman126
Slide Ways
sandman126's Avatar
Drives: 2013 SWP BRZ, 85 VW Golf
Originally Posted by ranisron View Post
Try welded diff :-)
Haha did that on my old suzuki samurai, tires chirped around every turn
sandman126 is offline   Reply With Quote
Old 07-27-2012, 08:22 PM   #14
OrbitalEllipses
Drives: Attitude
Gravel. No traction under that tire because the surface of the road (gravel) moves as the tire spins.
FS: Gramlights 57d 17x9 +38 5x114.3 w/ tires 1500 miles on tires, $1800 shipped apexsti46 Wheels and Tires 6 09-05-2012 02:54 AM
TEIN Street Basis Coilovers for BRZ/FR-S at Redline360 Redline360 Brakes, Suspension, Chassis 2 07-05-2012 08:36 AM
Scion FR-S, Limited slip dif (LSD)? Dbringer Scion FR-S / Toyota 86 GT86 General Forum 20 06-13-2012 03:02 AM
Torsen limited slip BMWDavid BRZ First-Gen (2012+) — General Topics 41 06-12-2012 09:04 PM
Slip Indicator Light erom BRZ First-Gen (2012+) — General Topics 17 06-10-2012 10:17 PM
