Old 07-25-2012, 09:40 PM   #99
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Originally Posted by Marrk View Post
I have read through this entire thread.
1) Are the plugs in this post the solution to the OP's problem?
2) Do the plugs in this post only work with OEM or non-adjusting shocks?
3) With regard to the tow holes on the bottom of the car: A grommet is not a plug, so how does a grommet keep dirt and water out?
1) Should be, at least with them the water/dirt/crap has no way of entering the car.
2) Not sure yet. I plan on ordering them, so we'll see how they work on mine.
3) Technically the tow holes are plugs, not grommets. But I wasnt going to bring that up
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 07-25-2012, 09:46 PM   #100
Zgrinch
Zgrinch's Avatar
Drives: 2013 Limited DGM BRZ
Nice, I'll check mine and get it fixed if they aren't there.
Opie installed mine, bet yours is installed as well. Thank goodness Opie knows his stuff and is on top of things.
BRZGrincherhood
Zgrinch is offline   Reply With Quote
Old 07-25-2012, 11:23 PM   #101
whataboutbob
AutoX-10/10ths every run
Fixed the links. Sorry about that, have a self-singed cert on my webserver. New links are to flickr.
Old 07-25-2012, 11:37 PM   #102
Marrk
Drives: Honda Fit
Please see Post 42 of this thread.
Marrk is offline   Reply With Quote
Old 07-26-2012, 09:00 AM   #103
cto424
So I only have one one plug covering the tow hole on the drivers side, and I don't have any of the plugs for the suspension....
Are the plugs for the suspension part of the PDI too?
cto424 is offline   Reply With Quote
Old 07-26-2012, 08:06 PM   #104
sho
Drives: s2000
I'm so glad a stumbled across this thread.
I had a look at mine as well and as expected, no grommets and so went to the dealership as I just picked it up 2 days ago and wanted to know why they didn't install it. I was told that its usually not install because its not really required but salesman tracked it down for me.
Funny enough the instructions on the packet is quite clear to install the grommets for the pre delivery inspector
sho is offline   Reply With Quote
Old 07-26-2012, 08:07 PM   #105
sho
Drives: s2000
I couldn't find it in the PDI but i'm curious about this as well
Old 07-26-2012, 08:27 PM   #106
Lonewolf
Lonewolf's Avatar
Drives: Moped
Why would Subaru/Toyota go to all the trouble of spending the time and money to make, package, and insert these things into the glove box of every car if it's not required? Seems like a waste of money to me...a waste that the bean counters in the finance and accounting department would not have approved.
Old 07-26-2012, 09:25 PM   #107
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I get that the PDI document calls it a document, but a grommet is something you'd use to protect a cable or pipe from a sharp edge when it passes through a wall. This plugs a hole so nothing can pass through. Does it matter? Nope.
Parting out HERE
Old 07-26-2012, 09:25 PM   #108
sho
Drives: s2000
totally agree with you on that one and not to mention the instructions on the package and on the PDI too lol
Old 07-26-2012, 11:00 PM   #109
Marrk
Drives: Honda Fit
Evidently, you do not know what a grommet is. If you look at Post 42, you will see in the diagram of the item that it is oblong in shape and open in the middle. That is where something "can pass through."
The picture in Post 104 is not very clear, but I believe the grommet on the right shows that it has an open center. If this part is a plug and not a grommet, please show me some evidence to support your claim.
Next Question: Why do forum jockeys insist on presenting themselves as know-it-alls? Isn't it enough for you to be annoying without the pretense of omniscience?
Old 07-26-2012, 11:53 PM   #110
OrbitalEllipses
Drives: Attitude
PRETENSE? Bitch, I AM omniscient!
Old 07-27-2012, 12:57 AM   #111
nix
nix's Avatar
Drives: AVO BRZ
This is one of the more confusing threads I've read in a while. There are two separate discussions going on (subframe tow holes/plugs and boot strut top holes/plugs).
It seems unlikely that the forward subframe holes would cause this, and if it is caused by splash back from the wheel arch, plugging the strut top hole doesn't look like it would help as the actual strut top will just sit full of water below it.
If it is coming in around the strut you might have to seal it somehow, maybe cut a big washer fom some rubber.
But I'd install the two sets of plugs and hit both areas with a pressure hose to see what happens.
nix is offline   Reply With Quote
Old 07-27-2012, 02:41 PM   #112
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Yes, because basing your argument on an outlined drawing on the computer makes you an expert on the part in question
Right back at you, big guy.
Im done arguing semantics.
Parting out HERE
Basic tech info: spring rates, rear suspension, motion ratios, and you. Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 77 07-08-2022 02:56 PM
water temp driver01 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 30 04-11-2013 02:57 AM
Impressive boot space! BD AUSTRALIA 14 08-24-2012 04:30 AM
Fatal FRS Flaw!! Skin Scion FR-S / Toyota 86 GT86 General Forum 4 07-12-2012 04:21 PM
Pics of rear passenger area with plastic removed JRitt Cosmetic Modification (Interior/Exterior/Lighting) 20 06-12-2012 08:17 AM
