Old 11-28-2020, 03:16 PM   #1
edrokone
Drives: Subaru BRZ
Exclamation Squeeky breaks!
I have a 2017 BRZ with the brembo package. I started to notice a break squeak at around 10,000 miles. I have taken my car in for servicing 3 times to get it checked out but it appears nothing is wrong? Pads are fine. Have any of you experienced this issue? Driving around town, especially on hills, is becoming a bit embarrassing. Any advice would be nice!
edrokone is offline   Reply With Quote
Old 11-28-2020, 03:21 PM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
'Squeaky breaks' Vs dirty weekends?
The Following User Says Thank You to JD001 For This Useful Post:
Captain Snooze (11-29-2020)
Old 11-28-2020, 03:59 PM   #3
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Give me a break
The Following User Says Thank You to gen3v8 For This Useful Post:
JD001 (11-29-2020)
Old 11-28-2020, 06:19 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
someone passed ingrish class!
they're performance BRAKES. they are going to SQUEAK. if that's undesirable, shoulda gotten the standard non-performance brake package.
Old 11-29-2020, 02:20 AM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
Check pad wear level. If squeaking of brakes is not caused by them worn down close to replacement, then re-bed brakes. Should be lot of nfo/guides/vids out there, how to bed brakes.
Old 11-29-2020, 03:31 AM   #6
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Brake harder
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
soundman98 (11-29-2020)
Old 11-29-2020, 06:47 AM   #7
JD001
JD001's Avatar
Drives: Subaru BRZ
Originally Posted by EndlessAzure View Post
Brake harder
You mean drive faster??
Originally Posted by gen3v8 View Post
Give me a break
You have the brake.. need to get some heat cycles into the disk and pads before you use 'em..
Old 11-30-2020, 11:59 PM   #8
jflogerzi
jflogerzi's Avatar
Maybe warped rotor? If not you could get the rotors turned and try less aggressive brake pads. Carbotech 1521's have been good to me dealing with my own break squeal issues.
2013 Series 10 FRS #553
Old 12-01-2020, 09:33 PM   #9
soundman98
soundman98's Avatar
what if i told you that rotors don't warp?
https://centricparts.com/getmedia/bd...c-8-2018_1.pdf
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
Compelica (12-02-2020), NoHaveMSG (12-02-2020)
Old 12-02-2020, 12:27 AM   #10
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
TLDR:
The metal itself isnt warped. There is uneven pad residue on the disc.
Old 12-02-2020, 01:55 AM   #11
churchx
churchx's Avatar
Drives: 2014 GT86
Oh, brake rotors do warp! Replace ASAP! Every seller selling new replacement disks agree to that /sarcasm
soundman98 (12-02-2020)
Old 12-02-2020, 11:43 AM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Go bed them in again and see if it goes away.
gen3v8 (12-02-2020)
Old 12-07-2020, 02:08 PM   #13
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
JRitt is offline   Reply With Quote
The Following User Says Thank You to JRitt For This Useful Post:
churchx (12-07-2020)
Clutch pedal - "squishy/squeeky" sound? tanner Engine, Exhaust, Transmission 16 07-27-2017 02:59 PM
Squeaky Breaks wally Issues | Warranty | Recalls / TSB 12 05-13-2017 06:08 PM
Squeeky clutch came back in few months bhbnuckle CANADA 9 04-07-2017 01:54 PM
