Old 05-13-2017, 07:17 AM   #1
wally
SosMula
wally's Avatar
Drives: 2013 DD White pearl
Squeaky Breaks
Hi guys, so i've noticed that my GT86 are having a issue with squealing brakes. Can anyone recommend a good setup of breaking pads for regular street driving?
I live in south part of Sweden where it is around 18-22 celcius, 64-72 fahrenheit. So it shouldn't be a issue with it being to cold.
Rota Grid 18x9,5 ET+38 Valenti CBW GCS Shark Antenna Acrylic Headlight Covers
wally is offline   Reply With Quote
Old 05-13-2017, 01:37 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
Are your stock pads squeaking? Are you sure they are stock pads?
humfrz (05-13-2017)
Old 05-13-2017, 01:38 PM   #3
humfrz
Originally Posted by wally View Post
Hi guys, so i've noticed that my GT86 are having a issue with squealing breaks. Can anyone recommend a good setup of breaking pads for regular street driving?
So, wally, I see that your car is new to you ....... but is it new.
If it's new, I'd suggest you take it back to the dealer ...... because, the brakes shouldn't be squealing.
If it's not a new car ....... how many miles on the car .. ??
If it has several thousands of miles on it ...... it could be the pads are worn down to the metal wear indicators (making a metallic squealing sound when applied).
Also, a brake inspection may be in order, there could be a lose caliper or a rock stuck between the pad and rotor.
If the pads are wore out ....... for normal driving, I would suggest they be replaced with the OEM pads.
humfrz
Old 05-13-2017, 02:17 PM   #4
wally
SosMula
wally's Avatar
Not sure if they're stock but im counting on that they are, got any tips for what brand would be a good replacement?
Old 05-13-2017, 02:18 PM   #5
wally
SosMula
wally's Avatar
humfrz
Hi Humfrz, the car got 4,500 on the meter so its not brand new and have apperently been driven once in the winter. Do you recommend any pads?
Old 05-13-2017, 02:23 PM   #6
Ultramaroon
not playing cards
Just get a set of stock pads.
humfrz (05-13-2017), wally (05-13-2017)
Old 05-13-2017, 02:29 PM   #7
humfrz
What I would recommend is that you have the brakes inspected at any brake shop ..... just to make sure there isn't something wrong with the brake system.
If the calipers and rotors are in good shape ...... maybe the pads are just glazed over.
If so, I would recommend they be replaced with the OEM (Original Equipment Manufactured) brake pads.
Back-in-the-day ....... we would just take the brake shoes off, blow out the brake dust - which was asbestos - not using a respirator - , sand off the glazed part from the shoes and reinstall them.
(dang, it's a wonder any of us can still breath)
humfrz
wally (05-13-2017)
Old 05-13-2017, 02:30 PM   #8
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Before replacing the pads you should hit them with some brake cleaner and re-grease the rear of the pads and shims.
While doing this, also check the thickness of the pads and if the rotor has any grooves or cracks.
I'm at 40k miles on stock rotors and pads and I brake pretty hard since I live in an area with pretty bad drivers.
I'm at roughly 70% brake pad material left but it's squeaking every so often, so I'm pretty sure it's the hardness of the pad (Semi-metallic?)
N1rve
The Following 2 Users Say Thank You to N1rve For This Useful Post:
Old 05-13-2017, 02:39 PM   #9
wally
SosMula
wally's Avatar
humfrz
Thanks for the tips guys, ill see if it turns out any better
The Following User Says Thank You to wally For This Useful Post:
humfrz (05-13-2017)
Old 05-13-2017, 02:40 PM   #10
JD001
JD001's Avatar
Drives: Subaru BRZ
Squeaky breaks = Dirty weekends..
The Following 2 Users Say Thank You to JD001 For This Useful Post:
Ultramaroon (05-13-2017), wally (05-13-2017)
Old 05-13-2017, 02:58 PM   #11
wally
SosMula
wally's Avatar
wow not sure how I missed that ofcourse I mean BRAKES
JD001 (05-13-2017)
Old 05-13-2017, 03:09 PM   #12
Ultramaroon
not playing cards
JD001 (05-13-2017)
Old 05-13-2017, 06:08 PM   #13
stevesnj
stevesnj's Avatar
Take the wheels off and squirt the brakes down with a hose, could be dirt and brake dust all in the works.
My 2016 Build thread
Turn Signal and breaks Chen Electronics | Audio | NAV | Infotainment 2 12-11-2015 09:09 AM
Evasive FR-S breaks 300 WHP on HKS GT Supercharger Evasive Motorsports Forced Induction 127 07-16-2013 08:23 AM
