go_a_way1
Old 11-27-2020, 09:21 PM   #4327
AKITA
AKITA's Avatar
Drives: 2016 Scion FRS Halo
Originally Posted by Madara808 View Post
Ah might have to buy rack limiters or something then. We’ll see
I wouldn't rack limit, how about less offset .. if you dead set on those wheels then spacers but I prefer less offset.. I say it will probably rub since I run 17x9 with 45 offset and get just a smidge of rub on full deflect lowered just over an inch, so 9.5 might be more than a smidge. Every car is different and I'm not using Ohlin's, I have HKS but don't think that matters or the amount lowered for that matter.
AKITA is offline   Reply With Quote
Old 11-27-2020, 09:54 PM   #4328
Madara808
Drives: PP WRB BRZ
What sized tires are you running on those wheels?
Madara808 is offline   Reply With Quote
Old 11-28-2020, 06:36 PM   #4329
AKITA
AKITA's Avatar
245/40 all around .. a 255/40 will fit on a 17x9 fine without a lot of buldge depending on tire.. in the front would be close to rub at 45 offset like having a 9.5.. you could stagger with the smaller tire up front but I don't like stagger on this car
Old 12-22-2020, 03:08 AM   #4330
zhanym0981
Drives: 2016 Scion FR-S
Hey guys. I have a stock 2016 FRS with stock tire (215 45R17, 48mm offset) and I'm looking to get the TRD forged rims for 86: https://parts.toyota.com/p/Toyota_20...2018160GR.html
Reading from the rims' specs (17x7.5, 43mm), it looks like they should fit my stock tires. But the Toyota dealer told me they don't fit according to the fit calculator on the Toyota website. Can someone help to confirm this, please?
Also I might consider switching to 225 45R17 in the future, I think they should fit as well but good to get some confirmation here
zhanym0981 is offline   Reply With Quote
Old 12-22-2020, 03:40 AM   #4331
churchx
churchx's Avatar
Drives: 2014 GT86
Stock sized tires 215mm wide should definitely fit on 7.5 wide wheels, and even within "ideal" range of that wheel width. Sounds like BS
Old 12-22-2020, 01:29 PM   #4332
Vital
Drives: 2015 BRZ
Yea as Churchx said they definitely fit. That dealership has no clue of what they're talking about.
Old 12-22-2020, 05:58 PM   #4333
holeeray
holeeray's Avatar
Drives: 2015 BRZ Limited
Didn't even notice this thread. Any input on this setup?
225/40r18
18x8.5 +44
Bilstein B6 + RCE Yellows
Bone stock
holeeray is offline   Reply With Quote
Old 12-22-2020, 06:18 PM   #4334
zhanym0981
Thanks guys That's what I thought. That dealership was probably told to just repeat what the website says
Old 12-22-2020, 07:37 PM   #4335
Vital
Drives: 2015 BRZ
225/40r18
18x8.5 +44
From what i understand the clearance on the B6 is similar to stock shocks so that should fit. There are threads on here with people using 235/40 tire size on stock shocks with that wheel size so your 225/40 should fit.
The Following User Says Thank You to Vital For This Useful Post:
holeeray (12-23-2020)
Old 01-26-2021, 02:49 AM   #4336
meWant
Drives: '16 BRZ Limited
Hi all, planning on getting new wheels that are 18x9.5 +38 and plan on getting Michelin Pilot Sport 4 S tires in 245/35/18. The car is currently lowered on RaceComp Engineering Yellow Springs with stock struts. Will the wheels and tires fit? I have read mixed comments regarding that, I don't mind a little rub at full lock so long as its not scraping against the wheel.
Thanks in advance to everyone.
meWant is offline   Reply With Quote
Old 01-26-2021, 12:20 PM   #4337
Vital
Drives: 2015 BRZ
People here seem to have done this wheel and tire size on TRD Springs and Sportline springs and say it works. I think tire is going to be key and with that size it should fit. Just keep in mind you wont be able to add much camber at all, if any. Rear wont be an issue.
meWant (01-26-2021)
Old 01-26-2021, 02:11 PM   #4338
DarkSideFRS
Drives: 2013 pearl white FR-S
u could fit, but u'd have to run minimal camber (-1 degree at most).. also depends on what tires u are running
DarkSideFRS is offline   Reply With Quote
The Following User Says Thank You to DarkSideFRS For This Useful Post:
meWant (01-26-2021)
Old 01-26-2021, 07:20 PM   #4339
meWant
I plan on going with 245/35/18 Pilot Sport 4S tires.
I think the car is currently around -1.4 to -1.6 deg up front right now, so it should be good. I wasn't really worried about the rear since I've seen that people are running 275 with stock body in rear lol.
The Following User Says Thank You to meWant For This Useful Post:
Vital (01-27-2021)
Old 01-26-2021, 07:26 PM   #4340
DarkSideFRS
-1.6 will prob hit. -1.4 is cutting it close.
For your reference, i had 17x9 +38 rims with 245/40R17 tires. Max camber i could run was -1.7 before the rims hit the shock perch
meWant (01-26-2021)
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
