Old 06-30-2020, 09:36 PM   #1
raz.sofer
raz.sofer's Avatar
Drives: Subaru BRZ 2015
"Tink" Noise when turning right
Hi!
I have getting this weird issue lately. I have a "tink" noise when turning right, and when turning left it does it only sometimes.
Also, when turning the steering wheel at low speeds, I hear "clunks" every half turn, sounds like a damaged top hat (I have camber plates).
The noise is only when the suspension is "warmed up" after a few minutes of driving.
The weird thing is that I had this noise a couple of weeks ago and it disappeared after a day or two (I talked to my mechanic and when he had time I drove to him and it was gone.)
Video:
Sorry for the bad video a friend filmed it :/ Didn't have a better one.
Suspension setup:
Cusco Sport S coilovers
Cusco Strut Tower
Powerflex control arm bushings with camber & caster adjustment
Hardrace Balljoints & Tie rod ends (extended)
RacerX Front End Links
raz.sofer is offline   Reply With Quote
Old 07-03-2020, 02:25 AM   #2
Setgo
Setgo's Avatar
Drives: '13 Subaru BRZ Crystal Black Silica
So I have a couple things to look at:
Check wheel clearance
Check top hats
Check wheel bearings
Check steering rack
It is definitely a rotational noise. Check rotating components.
Setgo is offline   Reply With Quote
Old 11-15-2020, 02:00 PM   #3
raz.sofer
raz.sofer's Avatar
Solved.
Wheel bearing was fucked.
The Following 4 Users Say Thank You to raz.sofer For This Useful Post:
bcj (11-15-2020), norcalpb (11-15-2020), TheBRZsKnees (07-09-2023), Wally86 (11-16-2020)
Old 11-17-2020, 02:24 PM   #4
Jonboy73
Jonboy73's Avatar
Drives: Toyota GT86 GTS
On a side note what side skirts do you have fitted please??
Jonboy73 is offline   Reply With Quote
Old 11-17-2020, 02:29 PM   #5
raz.sofer
raz.sofer's Avatar
Ikon replica rocket bunny v1
DIY - Fix your Rear Deck "popping/clicking/tapping/ticking" noise. Mikepage DIY (Do-It-Yourself) Guides 54 10-21-2020 02:34 PM
Rear Deck "popping/clicking/tapping/ticking" noise. Sigh-on-Rice Issues | Warranty | Recalls / TSB 637 04-28-2020 04:55 AM
tink, tink noise comes from rear for first ten minutes when car is cold. Wise Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-21-2017 12:51 AM
On-throttle under-load "Dieseling" type noise... Header gaskets? Kostamojen Engine, Exhaust, Transmission 5 03-18-2016 07:50 PM
"Tink" noise, What torque spec do you use for rear axle nut? Vmax911 Engine, Exhaust, Transmission 7 09-15-2015 07:01 PM
