-   Suspension | Chassis | Brakes -- Sponsored by 949 Racing (https://www.ft86club.com/forums/forumdisplay.php?f=59)
-   -   "Tink" Noise when turning right (https://www.ft86club.com/forums/showthread.php?t=141196)
raz.sofer 06-30-2020 09:36 PM
Hi!
I have getting this weird issue lately. I have a "tink" noise when turning right, and when turning left it does it only sometimes.
Also, when turning the steering wheel at low speeds, I hear "clunks" every half turn, sounds like a damaged top hat (I have camber plates).
The noise is only when the suspension is "warmed up" after a few minutes of driving.
The weird thing is that I had this noise a couple of weeks ago and it disappeared after a day or two (I talked to my mechanic and when he had time I drove to him and it was gone.)
Video:
https://www.youtube.com/watch?v=valaKDcirgA
Sorry for the bad video a friend filmed it :/ Didn't have a better one.
Suspension setup:
Cusco Sport S coilovers
Cusco Strut Tower
Powerflex control arm bushings with camber & caster adjustment
Hardrace Balljoints & Tie rod ends (extended)
RacerX Front End Links
Setgo 07-03-2020 02:25 AM
So I have a couple things to look at:
Check wheel clearance
Check top hats
Check wheel bearings
Check steering rack
It is definitely a rotational noise. Check rotating components.
raz.sofer 11-15-2020 02:00 PM
Solved.
Wheel bearing was fucked.
Jonboy73 11-17-2020 02:24 PM
On a side note what side skirts do you have fitted please??
raz.sofer 11-17-2020 02:29 PM
Ikon replica rocket bunny v1
