Old 11-08-2020, 12:26 PM   #1
jflogerzi
jflogerzi's Avatar
Bilstein B8+RCE Yellows vs Tien Flex A's
Redline has the Flex A's for 899$ which I am not sure how they do but with tax its just under 1K. Already have stock dampers from 2017 non PP dampers and RCE yellows. One is leaking so I am trying to gauge how much better each setup would be over current setup? Or just to replace the current damper that's leaking and call it a day. Then add peddlers top mounts for extra camber.
Separate question. For the peddlers top mounts, would a good alignment shop be able to use the Peddlers + crash bolts to get an even negative camber of 2 to 2.5 degree's on both sides?
2013 Series 10 FRS #553
Old 11-08-2020, 01:40 PM   #2
Decep
Drives: 2013 FR-S Series 10
I had the RCE yellow + PP shocks and wasn't really happy with em. Thought they kinda rode like shit over bad roads. On decent roads they were ok i guess.
Havent tried pedders top mounts but my RCE SS1s came with nice top hats that are holding up well and haven't made any noise in the 15k i've had them installed. And with the crash bolts you can easily get 3+ degrees if you want it.
Decent coilovers are a good upgrade over lowering springs. Am i saying my car rides like an 80's cadillac over bad roads.. hell no but it doesn't feel like the damping can't keep up with the constant undulations in the road now.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
The Following User Says Thank You to Decep For This Useful Post:
jflogerzi (11-08-2020)
Old 11-08-2020, 02:03 PM   #3
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
Wow that’s a great deal. Hope to see more of that this month. I’d go with the Flex A’s. Heard a lot of good things about them. You’ve had lowering springs already so why not try some highly rated coilovers.
Will BRZ is offline   Reply With Quote
The Following User Says Thank You to Will BRZ For This Useful Post:
Old 11-08-2020, 04:22 PM   #4
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Why pedders? There are malady good top hat or camber bolt options.
I have whiteline camber bolts by themselves and have -2.5 in the front.
Old 11-08-2020, 11:37 PM   #5
jflogerzi
jflogerzi's Avatar
I have decided I rather just get a new OE damper which was under 150$ and save the rest of the money for other small suspension upgrades.
Old 11-09-2020, 02:42 AM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
i'd usually replace dampers at least as pair though, at least if other one has already been through noticeable mileage.
Old 11-09-2020, 10:31 AM   #7
Racecomp Engineering
Use Bilstein B6 with RCE Yellows FYI.
- Andrew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
jflogerzi (11-10-2020), nathand (11-09-2020), Thefalls (11-10-2020)
Old 11-09-2020, 01:58 PM   #8
ZDan
ZDan's Avatar
Drives: '23 BRZ
Did you have camber plates? PP struts have limited bump travel, with RAceseng plates and Swift Rspec springs (-1.25" lowering) I would bottom out the struts over the smallest bumps, BAM! My car rides infinitely better with Bilsteins vs. pp/Sachs dampers.
Old 11-09-2020, 01:59 PM   #9
Decep
At that time i didn't. I didn't bottom them out at all.
Hell when the coilovers crap out i might try the bilstein b6/yellow combo, i have heard good things.
RCE SS-1 Coilovers
Corsa Catback
Old 11-09-2020, 02:40 PM   #10
SCFD
- Andrew
Why do you suggest using the B6 with RCE yellows? Is it because the drop is too mild?
SCFD is offline   Reply With Quote
Old 11-09-2020, 02:44 PM   #11
Valving is the same between the 2, B8 has slightly less droop (extension) travel, presumably for short springs that otherwise would be loose. That's not needed with RCE Yellows or most springs for that matter.
RCE Yellows work well with either one, but droop travel is good to have.
- Andrew
jflogerzi (11-10-2020), Ohio Enthusiast (11-09-2020), SCFD (11-10-2020)
Old 11-10-2020, 12:34 AM   #12
Plumbus
Señor Member
Plumbus's Avatar
Drives: '17 BRZ PP
- Andrew
Excuse my ignorance as I know very little of non-adjustable struts, but wouldn't B6 work well with short springs if you used helper springs with them?
Plumbus is offline   Reply With Quote
Old 11-10-2020, 08:33 AM   #13
In theory yes, but not really possible with an OEM shape or fitment spring...helper springs are only available in the smaller standardized coilover shapes/diameters.
- Andrew
Plumbus (11-10-2020), ZDan (11-10-2020)
Old 11-10-2020, 08:52 AM   #14
ZDan
ZDan's Avatar
Drives: '23 BRZ
What the man said ^^^
I got B8s to go with ~1.25" lowering springs (Swift R-Spec) to ensure they didn't unseat at droop, then found that others have used these springs with B6 without issue. No other differences between B6/B8 other than droop travel. Still it's nice to get tires off the ground with fewer pumps at the handle with the B8s! But unless lowered 1" or more I'd definitely go B6 for droop travel.
The Following 2 Users Say Thank You to ZDan For This Useful Post:
Racecomp Engineering (11-10-2020), SCFD (11-10-2020)
WTB - Performance Package suspension or Koni/bilstein with swift or RCE yellows Jamestl Want-To-Buy Requests 8 01-31-2018 01:52 AM
Tien Flex Z Squeak CatalystPLUR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 12-16-2016 09:15 PM
Switched from RCE Yellows to Bilstein B8/RCE Tarmac Springs was385 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 01-23-2015 11:19 PM
