Old 12-02-2016, 01:19 PM   #1
CatalystPLUR
That Auto Guy
CatalystPLUR's Avatar
Drives: Ultramarine FRS
Tien Flex Z Squeak
I have a weird squeak coming from the front driver side suspension. I just installed my Tiens and had them aligned the first 2 weeks I had them on no squeak. Slowly I started hearing a squeak I have no idea what it is my guess is the spring rate but again I have no clue. It only happens at >7 miles an hour and only when I am barely turning the wheel when I turn even slightly hard the squeak doesn't appear. Any clues? anyone have this problem before?
CatalystPLUR is offline   Reply With Quote
Old 12-02-2016, 03:05 PM   #2
CatalystPLUR
That Auto Guy
Revalaton The squeak only occurs when im turning the wheel counter-clockwise at a full stop
Old 12-02-2016, 03:48 PM   #3
Whats that smell?
Whats that smell?'s Avatar
Drives: 2013 Asphalt FR-S
How wide are you running your wheel set up?
Whats that smell? is offline   Reply With Quote
Old 12-02-2016, 03:53 PM   #4
CatalystPLUR
That Auto Guy
Completely stock beside Buddy Club Front LCA's
Old 12-02-2016, 03:58 PM   #5
Whats that smell?
Hmm I was going to say it was your tire rubbing at full lock lol. But idk I would call tein and see if they've had problems like this before.
Sent from my SM-G920V using Tapatalk
Old 12-02-2016, 04:42 PM   #6
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I have no idea but i would remove wheel and see all locks are tight. mine has 0 sounds
Old 12-02-2016, 08:53 PM   #7
shellslinger
Drives: Whiteout FRS
When I had the Flex Z's, there were random squeaks here and there. I just learned to live with it
shellslinger is offline   Reply With Quote
Old 12-02-2016, 11:45 PM   #8
Kaotic Lazagna
Drives: GR Corolla
I have mine on max low in the front (removed locking ring and twisting the bottom bracket all the way up) and level rear (so max shock length plus some pre-load shortening). No squeaks at all.
Old 12-16-2016, 08:47 AM   #9
zc06_kisstherain
Drives: SWP BRZ
I heard mine like OP today... whether is too cold to check it out. I am guessing it's spring rate since my wheel is stock as well as used default setting on lowering.
any idea?
Old 12-16-2016, 09:15 PM   #10
zc06_kisstherain
Drives: SWP BRZ
any idea?
i think it's cold weather causes it. i had soft setting and dialed to stiffest setting and sound is reduced much. i almost had no noise when weather was warm. so i guess it's temperature related.
Lowering Springs or tien z Sherb Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 08-14-2016 10:39 AM
Front Right Squeak djliquidsteele Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 09-28-2015 09:46 PM
Help wanted: Tein Street Flex for $950 or Flex Z or $820? chezzy79 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-01-2015 09:33 PM
Bad suspension squeak teamturbo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 04-19-2015 01:51 PM
Rear squeak norcal_brz Issues | Warranty | Recalls / TSB 0 08-12-2014 07:29 PM
