Old 11-03-2020, 03:56 PM   #1
thekevinvo
Drives: 2014 Scion FRS
DIY: Spark Plug Change
The dreaded spark plug change simplified without needing to jack up the engine.
thekevinvo is offline   Reply With Quote
The Following 6 Users Say Thank You to thekevinvo For This Useful Post:
bcj (11-04-2020), Busybee (10-13-2022), Kaotic Lazagna (11-05-2020), Lonewolf (12-06-2020), MJones_RB (11-06-2020), PerCompLLC (08-14-2022)
Old 11-03-2020, 04:07 PM   #2
Tokay444
I did spark plugs in under half an hour, and it couldn't be any easier. Jacking up the engine is a piece of cake. I don't know why anyone wouldn't do it.
Old 11-03-2020, 05:22 PM   #3
Ohio Enthusiast
Drives: 2018 BRZ
Lots of conflicting info about how to jack the engine, especially around how much disassembly is needed before jacking it. @Tokay444 did you just loosen the engine mounts and jacked it up? Did you jack the oil pan?
Old 11-03-2020, 07:25 PM   #4
Tokay444
Both engine mounts and the tranny mount in the tunnel.
I jacked it up on the factory heat shied of the header. That was 30,000kms ago. I fully expected to be yanking that heatshield off due to vibrations by now, but it's still fully intact.
The Following User Says Thank You to Tokay444 For This Useful Post:
Ohio Enthusiast (11-03-2020)
Old 11-04-2020, 07:09 AM   #5
TRAKRAVN
Drives: 2015 Scion FRS - Raven
It’s takes more patience and the right tools to do it without lifting the engine. If you have lots of time and love working on the car, try it with the engine in place. If you just want to get it done and back to driving do the Tokay444 method. I’ve personally only done it wwhile doing a clutch at the same time with the engine “moveable”.
TRAKRAVN is offline   Reply With Quote
Old 11-04-2020, 08:41 PM   #6
daniloneil8
Wow, excellent production and lighting. Well done, Kevin. You're not going to get a million views, but the 86 community will truly appreciate you hard work
daniloneil8 is offline   Reply With Quote
Old 11-04-2020, 08:43 PM   #7
daniloneil8
Is there a decent spark plug video that shows how to lower the engine?
Old 11-05-2020, 12:43 PM   #8
Tokay444
You don't lower it.
You tilt it up one side at a time.
Old 12-06-2020, 07:46 PM   #9
86TOYO2k17
Drives: 2017 toyota 86
With the 37 diy spark plug threads I’m surprised people are still doing it the longer harder way, by not jacking the engine up.
I’ll just leave this here to hopefully save the next guy the headache of trying without jacking engine up.
https://www.ft86club.com/forums/show...3&postcount=11
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
Tokay444 (12-07-2020)
Old 12-07-2020, 04:24 PM   #10
thekevinvo
I was able to change all 4 spark plugs well under half an hour without having to jack up the engine. Wouldn't say this is the longer or harder way.
Old 12-07-2020, 05:56 PM   #11
86TOYO2k17
Film it no cuts start to finish or it didn’t happen.
What did you torque the plugs and coils too?
Maybe you have small barbie doll hands?
Majority of people who have done it without jacking engine up say its a solid 3hours and your hands look like they lost a fight with a cheese grater.
Doing it by Jacking the engine up takes less than two hours and your hands look like they got a manicure at your favorite spa.
The Following 2 Users Say Thank You to 86TOYO2k17 For This Useful Post:
pope (12-07-2020), Tokay444 (12-08-2020)
Old 12-08-2020, 04:05 PM   #12
Tokay444
Bullshit.
Old 12-10-2020, 11:49 AM   #13
thekevinvo
Originally Posted by Tokay444 View Post
Bullshit.
Well it took me a little over an hour to do the install which included the filming so that's already under what some people are saying it took them while jacking the engine up
Old 12-10-2020, 12:40 PM   #14
Tokay444
Exactly. So you've already more than doubled your bullshit claim from, "...well under half an hour..." to, "...a little over an hour..."
Just stop.
Helpful DIY Spark plug change video DTMdreaming Engine, Exhaust, Transmission 13 10-17-2020 08:55 PM
Oil in Spark Plug Wells? BaBaFlyingSheep Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 07-01-2020 10:51 AM
P1261 and 1262 after spark plug change Remmenator Issues | Warranty | Recalls / TSB 2 05-20-2020 04:09 PM
Issues with white smoke after spark plug change Japanese_Carbon Issues | Warranty | Recalls / TSB 1 01-23-2020 09:37 AM
Spark plug change - dealership price? wparsons CANADA 47 05-08-2019 06:48 AM
