Old 04-25-2020, 08:15 PM   #1
BaBaFlyingSheep
Drives: 2015 BRZ Ltd 6MT
Oil in Spark Plug Wells?
Not sure if I'm just bad at searching, but couldn't find a thread on this.
I'm at 79k miles, changing my spark plugs and noticed the wells were oily.
I'm hoping it's just the O-rings on the spark plugs, in which it's good that I'm finally changing the plugs, hoping it's not a valve cover leak or something more serious.
Combustion chamber seems normal?
Attached is some pics of cylinder wells 1 and 3 and piston head.
Anyone else seen this or have this issue before?
BaBaFlyingSheep is offline   Reply With Quote
Old 04-25-2020, 08:44 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Is there oil on the plug itself? Where?
Oil present in spark plug hole most likely is a bad spark plug well gasket. It can only be replaced by taking off the valve cover.
If you have oil on either electrode itself, you have a much bigger problem.
The Following User Says Thank You to mav1178 For This Useful Post:
Opie (05-05-2020)
Old 04-25-2020, 09:28 PM   #3
BaBaFlyingSheep
In the well, combustion chamber and spark electrode is dry.
Old 04-26-2020, 06:50 AM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
As already posted. Valve cover has to come off and be resealed. NOT A FUN JOB.
Old 04-26-2020, 12:57 PM   #5
mav1178
mav1178's Avatar
Spark plug well gasket. You have to pull valve cover to replace it.
Might as well do other maintenance work if you're doing this... if not, leave it. The oil is only a problem if it pools up enough to interfere with the spark plug. Much easier to dry out the oil periodically (every other oil change) than the pull the VC and replace two gaskets...
Opie (05-05-2020)
Old 07-01-2020, 10:51 AM   #6
chipmunk
Drives: _
Recently did this on my wife's car (inline 4, but same principle). The valve cover gasket became too brittle from nearby exhaust, and caused leakage. Took about 15 minutes for inline 4. For the Boxer... well... good luck anyway!
chipmunk is offline   Reply With Quote
SPARK PLUG GUiDE! Kojiap1 Engine, Exhaust, Transmission 15 04-13-2022 01:30 PM
Spark Plug Options? BRZach Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 27 08-18-2017 12:14 AM
P0351 bad spark plug... Jaden Engine, Exhaust, Transmission 3 01-02-2016 10:19 AM
Spark Plug Time !!!! RFB Scion FR-S / Toyota 86 GT86 General Forum 26 11-24-2014 07:46 PM
Spark plug question Wilsonk227 BRZ First-Gen (2012+) — General Topics 19 07-03-2013 12:57 AM
