Drives: BRZ 2020
Is quickly shifting automatic car in manual mode is bad?
Hi guys,
newbie question here: Let's say Im on 3k rpm in manual mode of an automatic car, and need to quickly gain tourqe, so i need to downshift 2 gears to be at around 6k rpm. I can quickly achieve this by double press on downshit on the steering wheel shifters. My question is - is it bad for the transmission to do it on regular basis? Are the gears actually changed (mechanically) during the middle downshift - which i assume will impact transmission wear time, or the gears are changed only after the 2nd downshift so mechanically there won't be any difference between 2 downshifts and 1? If it does, i'd like to hear how automatic owners here handle cases where sudden acceleration is required? Thanks |
#2 |
It was built for this, don't worry about it
Sent from my ONEPLUS A5010 using Tapatalk |
#3 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
The auto is set up so it won't help you to break things.
It won't shift down far enough to over-rev the engine. You'll need a manual for dumb stuff like that.
"I gotta rock." -- Charley Brown |
#4 |
The Dictater
Drives: '13 Red Scion FRS
If it feels and sounds like the gears are changed twice then they are. If not, then it skipped a gear. Either way, it will be fine, I highly doubt the transmission will let you do anything to break it.
#5 | |
#6 |
Drives: Toyota 86 GTS
As far as I can tell you're fine to down/upshift whenever depending on which arrow(s) is visible next to the gear you're in. I'll admit though I get a little nervous that something will go wrong when I downshift and my car RPM jumps dramatically
#7 |
The Dictater
... That's supposed to happen....
#8 |
@uchiha, has others have said, the transmission and its software are designed for you to do this. I have over 170K miles on my AT and have done this many, many times, both in automatic and manual modes. I would imagine I've done it at least once in every 50 miles the car has been driven, which would be 3,400 times, but that is an estimate. I have no issues to date.
I've also dropped it down 3 gears on occasion.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#9 |
I dunno about some of these kids these days
Sent from my ONEPLUS A5010 using Tapatalk Last edited by Ashikabi; 10-25-2020 at 01:25 PM. |
#10 | |
ProCrastinationConsultant
https://en.wikipedia.org/wiki/Italian_tuneup
#11 | |
Señor Member
1974 TA22 Celica
2013 86 GT |
#12 |
Honestly, I find that this AT really does most of what I want and I don’t feel the need to go into manual as much. It holds gears on turns, so as not to shift and disrupt the car, but other than shifting a bit too fast on a straight, it’s not bad. I have done some runs on a local mountain road and going manual is only slightly better than AT. Sometimes I don’t use manual for weeks, but I am lazy. It’s no PDK but for a slush box it works well.
#13 |
#14 |
Yes, but it is much faster if you go do it with the paddles even in AT mode, than wait for the computer to interpret you flooring it.
| A/T FRS Shifting automatically while in manual mode | AfterFXNinja | Engine, Exhaust, Transmission | 1 | 10-17-2016 10:01 PM |
| Auto Shifting in Manual Mode | phantasticity | Engine, Exhaust, Transmission | 22 | 06-16-2016 09:56 PM |
| Automatic not downshifting in manual mode | VegaX77 | Issues | Warranty | Recalls / TSB | 7 | 02-15-2016 10:48 AM |
| Automatic FRS Surge in Manual Mode | N1rve | Issues | Warranty | Recalls / TSB | 5 | 02-08-2014 12:28 PM |
| A Week of A/T Manual Shifting Mode | Ocala FR-S | Scion FR-S / Toyota 86 GT86 General Forum | 98 | 05-15-2013 02:35 AM |
