Old 10-24-2020, 09:41 AM   #1
uchiha
Drives: BRZ 2020
Is quickly shifting automatic car in manual mode is bad?
Hi guys,
newbie question here:
Let's say Im on 3k rpm in manual mode of an automatic car, and need to quickly gain tourqe, so i need to downshift 2 gears to be at around 6k rpm.
I can quickly achieve this by double press on downshit on the steering wheel shifters.
My question is - is it bad for the transmission to do it on regular basis? Are the gears actually changed (mechanically) during the middle downshift - which i assume will impact transmission wear time, or the gears are changed only after the 2nd downshift so mechanically there won't be any difference between 2 downshifts and 1?
If it does, i'd like to hear how automatic owners here handle cases where sudden acceleration is required?
Thanks
uchiha is offline   Reply With Quote
The Following User Says Thank You to uchiha For This Useful Post:
humfrz (10-25-2020)
Old 10-24-2020, 09:42 AM   #2
Ashikabi
Ashikabi's Avatar
It was built for this, don't worry about it
Sent from my ONEPLUS A5010 using Tapatalk
The Following 5 Users Say Thank You to Ashikabi For This Useful Post:
Dadhawk (10-25-2020), ls1ac (10-24-2020), NWFRS (11-03-2020), Overdrive (10-26-2020), whataboutbob (10-25-2020)
Old 10-24-2020, 10:48 AM   #3
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
The auto is set up so it won't help you to break things.
It won't shift down far enough to over-rev the engine.
You'll need a manual for dumb stuff like that.
The Following 6 Users Say Thank You to bcj For This Useful Post:
alphasaur (10-25-2020), Dadhawk (10-25-2020), Overdrive (10-26-2020), spike021 (11-03-2020), Tcoat (10-25-2020), whataboutbob (10-25-2020)
Old 10-24-2020, 11:56 AM   #4
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
If it feels and sounds like the gears are changed twice then they are. If not, then it skipped a gear. Either way, it will be fine, I highly doubt the transmission will let you do anything to break it.
The Following User Says Thank You to Spuds For This Useful Post:
Tcoat (10-25-2020)
Old 10-25-2020, 12:20 AM   #5
Originally Posted by uchiha View Post
Hi guys,
Thanks
They buy a different car -
The Following 6 Users Say Thank You to humfrz For This Useful Post:
MICHAEL450f (10-29-2020), MuseChaser (10-25-2020), new2subaru (10-25-2020), soundman98 (10-25-2020), spike021 (11-03-2020), Ultramaroon (10-25-2020)
Old 10-25-2020, 01:50 AM   #6
Sam86
Drives: Toyota 86 GTS
As far as I can tell you're fine to down/upshift whenever depending on which arrow(s) is visible next to the gear you're in. I'll admit though I get a little nervous that something will go wrong when I downshift and my car RPM jumps dramatically
Sam86 is offline   Reply With Quote
Old 10-25-2020, 11:51 AM   #7
Spuds
The Dictater
Spuds's Avatar
... That's supposed to happen....
Old 10-25-2020, 11:57 AM   #8
@uchiha, has others have said, the transmission and its software are designed for you to do this. I have over 170K miles on my AT and have done this many, many times, both in automatic and manual modes. I would imagine I've done it at least once in every 50 miles the car has been driven, which would be 3,400 times, but that is an estimate. I have no issues to date.
I've also dropped it down 3 gears on occasion.
soundman98 (10-25-2020), spike021 (11-03-2020), Tcoat (10-25-2020)
Old 10-25-2020, 01:01 PM   #9
Ashikabi
Ashikabi's Avatar
I dunno about some of these kids these days
The Following 2 Users Say Thank You to Ashikabi For This Useful Post:
Old 10-25-2020, 01:23 PM   #10
soundman98
ProCrastinationConsultant
soundman98's Avatar
Hi guys,
Thanks
it's fine!
https://en.wikipedia.org/wiki/Italian_tuneup
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
spike021 (11-03-2020), Turdinator (10-25-2020)
Old 10-25-2020, 07:52 PM   #11
Turdinator
Señor Member
Turdinator's Avatar
Hi guys,
Thanks
If you left the car in auto and suddenly floored it wouldn't it downshift a couple of gears anyway? Gearboxs are designed to change gears
1974 TA22 Celica
2013 86 GT
Old 10-25-2020, 08:17 PM   #12
Ernest72
Honestly, I find that this AT really does most of what I want and I don’t feel the need to go into manual as much. It holds gears on turns, so as not to shift and disrupt the car, but other than shifting a bit too fast on a straight, it’s not bad. I have done some runs on a local mountain road and going manual is only slightly better than AT. Sometimes I don’t use manual for weeks, but I am lazy. It’s no PDK but for a slush box it works well.
The Following User Says Thank You to Ernest72 For This Useful Post:
Old 10-26-2020, 03:13 AM   #13
Sam86
Well yea but with my headers and exhaust when the car suddenly goes from 2k to 7k RPM it's rather loud and unexpected
The Following User Says Thank You to Sam86 For This Useful Post:
Spuds (10-26-2020)
Old 10-26-2020, 07:07 AM   #14
Yes, but it is much faster if you go do it with the paddles even in AT mode, than wait for the computer to interpret you flooring it.
Overdrive (10-26-2020), Turdinator (10-26-2020)
A/T FRS Shifting automatically while in manual mode AfterFXNinja Engine, Exhaust, Transmission 1 10-17-2016 10:01 PM
Auto Shifting in Manual Mode phantasticity Engine, Exhaust, Transmission 22 06-16-2016 09:56 PM
Automatic not downshifting in manual mode VegaX77 Issues | Warranty | Recalls / TSB 7 02-15-2016 10:48 AM
Automatic FRS Surge in Manual Mode N1rve Issues | Warranty | Recalls / TSB 5 02-08-2014 12:28 PM
A Week of A/T Manual Shifting Mode Ocala FR-S Scion FR-S / Toyota 86 GT86 General Forum 98 05-15-2013 02:35 AM
