Old 10-21-2020, 05:27 PM   #1
kyoshi11
kyoshi11's Avatar
Tap into ECU for brake pedal position
I know there is a TPS on the car and am wondering if there is a brake position sensor? I want to make active aero as a fun project and am wondering if there is a way to access brake and speed data?
kyoshi11 is offline   Reply With Quote
Old 10-21-2020, 05:42 PM   #2
What do you mean by brake position? Brake light switch? I think you can even sample real time brake line pressure. Depends on how deeply you want to dig.
Old 10-21-2020, 06:08 PM   #3
kyoshi11
kyoshi11's Avatar
I want to make the wing actuate when brake pedal position is >50% and I plan to attach an arduino with other commands so the wing moves under certain conditions like if im going over 50 mph with >50% brakes and have it return to original position if I have my foot on the brake for longer than 5 seconds. Would i be looking into ECU for brake line pressure?
Old 10-21-2020, 10:09 PM   #4
anticubus
Drives: 2017 Toyota 86
80% sure you're looking for CAN ID 0xD1. Brake pressure is definitely available and you won't need to do anything directly with the ECU, just get the arduino listening on the CAN.
anticubus is offline   Reply With Quote
The Following User Says Thank You to anticubus For This Useful Post:
Spuds (10-24-2020)
Old 10-21-2020, 10:52 PM   #5
I just added that parameter to my OBDLink app. It's there and works but I don't know dig it out.
Old 10-22-2020, 03:25 AM   #6
bobel
Drives: GT86
As folks have said already your only option is the brake pressure sensor signal, but it is probably a better solution for what your after
I’ve recently mapped some CAN ID to my AIM dash, they might be helpful for you if you going down this route, combo of TPS and Brake pressure should make for a nice active aero solution.
bobel is offline   Reply With Quote
The Following 4 Users Say Thank You to bobel For This Useful Post:
anticubus (10-22-2020), B T (10-30-2020), Spuds (10-24-2020), Ultramaroon (10-22-2020)
Old 10-22-2020, 05:46 PM   #7
Do you know how those values can be translated to parameter IDs for a tactrix logger? I get gain and offset but the rest is a mystery.
Old 10-22-2020, 11:03 PM   #8
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
You might find these useful:
CAN bus: https://github.com/timurrrr/RaceChro...can_db/ft86.md
OBD PIDs: https://racechrono.com/forum/discuss...r-frs-brz-gt86
Old 10-22-2020, 11:37 PM   #9
anticubus
Originally Posted by timurrrr View Post
Ahh hey, you're the last post in that racechrono thread that I dug up looking for this! Lots of good info in these links.
timurrrr (10-22-2020)
Old 10-23-2020, 08:34 PM   #10
ML
ML's Avatar
Drives: 13 White MT FR-S
Why not run the active aero off a accelerometer. Car weight distribution would seem to be more relevant than brake pressure, which could change on the track.
Old 10-23-2020, 08:52 PM   #11
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Accelerometers typically produce pretty noisy data, so you need to use some filtering, which will most likely introduce some delays, making the whole system less effective (aero helps the most when you start braking).
You may also introduce a positive feedback loop, where as you progressively press on the brake pedal you first have low deceleration, and then the aero kicks in as soon as you a certain amount of deceleration. This may make the car respond non-linearly to increasing deceleration rate. The unpredictable delay will only make this effect worse, kinda similar to a turbo lag.
Old 10-24-2020, 05:36 AM   #12
bobel
Drives: GT86
Hi
Been a while since I messed with the OBD PIDs and I’m not familiar with that particular logger if I’m honest. But attached are the standard PID codes for the OBD (not all will be applicable for 86) and I’m afraid I don’t know how your logger takes the PID data addresses so you might have to fiddle about a little.
Anyways hope it’s of some help.
86 Standard PIDs 4.pdf
The Following User Says Thank You to bobel For This Useful Post:
Ultramaroon (10-24-2020)
Old 10-24-2020, 01:04 PM   #13
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Hi
Attachment 194116
He was talking about mapping CAN PIDs, not OBD PIDs. The doc you've attached doesn't mention anything about brakes.
Old 10-29-2020, 03:36 PM   #14
Icecreamtruk
Drives: Track preped NA FRS
If you want active aero, best way is to have it driver controller. Add a button or switch to change wing position. Have your normal cornering position as your default, and then reduce angle (or open wing if multielement) on the straights. Dont do the other way around (increase angle during braking), air becomes turbulent as the wing moves, you dont want that to happen midcorner and you will loose the downforce as you step off the brakes and onto the gas, when you still need it a lot.
Icecreamtruk is offline   Reply With Quote
Cusco Pedal Install & Pedal Lateral Stiffening (Sideways Loose Pedal) BOND007_LTK DIY (Do-It-Yourself) Guides 5 05-20-2022 04:12 PM
Brake Pedal adjustment help Elliotw Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 06-18-2020 05:50 PM
Brake pedal sound wt??? misterfly Issues | Warranty | Recalls / TSB 8 07-13-2017 12:32 PM
clicky/loose brake pedal? nyfries Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-26-2014 10:59 PM
Gas pedal dance brake thing.??? gdrider77 Software Tuning 9 12-22-2013 08:43 AM
