Old 08-11-2020, 07:24 AM   #15
Joveen
Joveen's Avatar
Drives: Bone stock
Here you go.
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
Old 08-11-2020, 07:24 AM   #16
Koba
Drives: 2020 BRZ
Originally Posted by 86TOYO2k17 View Post
Been using an ebay one for a while with no issues. Aluminum-Rear-Differential-Cover-for-FT86-GT86-Subaru-BRZ-Scion-FR-S-13-Black. Was 120$ now 130$. Looks 100% identical to cusco probably made at same production facility after hours. It’s a somewhat “basic” part so I’m not too concerned with “quality” the flat surface where gasket seals was flawless for a perfect seal. The rest of it looked perfect as well. I know how some people are with Chinese knock offs though, depending on the part/price I’m the same way. But I don’t see 800$ of value in one of these for how simple it is. 350-400$ would have been a good price point for “name” brand.
ha-ha! Thank you! Even the description is almost verbatim.
For $130 It's worth a try. Thanks again, dude!
Koba is offline   Reply With Quote
Old 08-11-2020, 03:22 PM   #17
ROADRACER
Drives: unlimited cheap build N/A track car
I just got one of those for my track car. It is a damn fine looking part for $130!
I recently installed a thermocouple on the diff and it was heating up above 300 deg in around 20 min. I am hoping the extra surface area of the aftermarket cover will help keep things cool.
I wouldnt trust the rubber o rings on the oil cooler fitting plugs. Use a good thread sealer instead.
ROADRACER is offline   Reply With Quote
Old 08-11-2020, 03:53 PM   #18
ls1ac
ls1ac's Avatar
Let us know what difference it makes on the track. I would think capacity and fins might slow the temperature rise.
Glad to see someone has put a thermocouple on one.
Old 08-25-2020, 08:27 AM   #19
ROADRACER
I would expect the extra capacity to slow the temp increase rate, but only slightly.
I expect the additional surface area to slow the rate of increase and reduce the maximum temp.
Hopefully it will reach an equilibrium point at a reasonable temp. I would like to keep it below 300 deg regardless of the run time.
I hope to get back on track within a month and will post results.
Old 10-21-2020, 03:15 AM   #20
Four_wheel_drifts
Drives: Whiteout track car; lava donor
@ROADRACER do you have an update?
With 4.56 gears, over 3 hours cruising on the highway at 80+ is long enough for my diff to start puking out fluid from the vent hole.
Four_wheel_drifts is offline   Reply With Quote
Old 10-21-2020, 03:13 PM   #21
ROADRACER
I did a day at AMP a couple weeks ago. The diff stayed under 250 degrees but it was a much cooler day and a different track with lower speeds than before. I cant really say how much cooler the diff would be under identical conditions, but the cover does provide a significant increase in surface area and seems like a quality part.
Next summer I will be able to test on another really hot day.
Old 10-21-2020, 04:38 PM   #22
CSG Mike
CSG Mike's Avatar
Without the original innovator, the knockoff can't exist.
It's like the signs some shops have that say "if you keep purchasing all your parts from Amazon, one day, we won't be around to install the parts for you".
That said, the Cusco one was too steep for me, and I use a GReddy diff cover that costs $450 and also increases capacity and adds ports for sensors/coolers.
https://www.counterspacegarage.com/g...iff-cover-gt86
Old 10-21-2020, 05:29 PM   #23
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I’m with Mike on this. I think the Greddy is a superior design internally as the flat back diff covers aren’t designed with the ‘flow’ of the oil in mind (see Banks video).
After running with the heat shields on the exhaust, I couldn’t recommend that solution enough as our exhaust pipe is dumping lots of unnecessary heat into our diffs.
PRO86 | WTCC | STL
Old 10-21-2020, 09:47 PM   #24
nico_rsx
Drives: BRZ 2017 Pure Red, MT
The heat shield, is it something you bought, or DIY?
nico_rsx is offline   Reply With Quote
Old 10-22-2020, 12:14 AM   #25
prandelia
Drives: 2015 FRS
I've been running the FT86 cover for the past year racing as well, figured I would save a few bucks from the Cusco one. Literally every Cusco part I've used is really nice, and works well. I would expect their diff cover (and copies) to be no different. Greddy setup is really nice too. I was honestly just more enticed by the cooling fins, so that's why I went with the FT86 cover.
I run 20min sprint races, and probably change my Giken fluid too often, but it comes out looking fantastic every time. It looks so good that I haven't even bothered putting a temp sensor in.
I'm installing a new R&P this winter, so will get to inspect everything and see if any abnormal wear is present. I don't expect to find any.
'15 FRS - GLTC spec
YouTube channel race vids: https://www.youtube.com/channel/UClU...phsppnA/videos
prandelia is offline   Reply With Quote
Old 10-22-2020, 02:21 AM   #26
rice_classic
DIY. Also keeps the exhaust from boiling the grease out of the axle.
https://www.ft86club.com/forums/show...&postcount=134
PRO86 | WTCC | STL
Old 10-23-2020, 03:37 PM   #27
prandelia
Drives: 2015 FRS
+1
I mounted up a axle shield as well.
I also re-packed my axles with Redline CV2 grease. Full spare set re-packed as well. The OE grease is junk, even with just street use.
'15 FRS - GLTC spec
Old 10-20-2021, 03:00 PM   #28
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
@ROADRACER any more testing on the temps? Considering a Harrop or Greddy version for the diff I'm building. Cusco is just too expensive.
B T is offline   Reply With Quote
Rear diff cover question xsnapshot Engine, Exhaust, Transmission 1 12-22-2015 05:00 PM
Ripoff Cusco diff cover? Thorpedo Scion FR-S / Toyota 86 GT86 General Forum 6 01-16-2015 07:25 PM
HOLIDAY SALE: GREDDY TURBO KIT w/ FREE DIFF COVER!!!! Speed Element Forced Induction 1 12-22-2014 05:21 PM
diff cover, Greddy or Cusco? puma Engine, Exhaust, Transmission 1 04-06-2014 05:21 PM
