Fast enough
Drives: 2013 Subaru BRZ AT
Rear diff cover question
Does anyone know if I have to drop the pumpkin to take off the rear diff cover? I have a slight oil leak from the cover flange.
I was planning on dropping it to take the back cover off and reseal, but if I can do it with it on the car, even better! Thanks! |
It doesn't look like you have to remove the differential from the car.
I suggest you read .... on down in this thread. http://blog.perrinperformance.com/pr...-gets-rolling/ Did you try to tighten the nuts to see if that would stop the leak .. ?? humfrz |
| Which is better? Reaplcing rear diff bushings? or installing rear diff brace? | Frs30 | Engine, Exhaust, Transmission | 22 | 04-13-2020 10:23 AM |
| Safe to jack car from rear diff (while potentially touching the cover)? | bloomy116 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 05-29-2014 11:18 PM |
| diff cover, Greddy or Cusco? | puma | Engine, Exhaust, Transmission | 1 | 04-06-2014 05:21 PM |
| Rear diff LSD question | Dephective | Engine, Exhaust, Transmission | 15 | 09-01-2013 05:30 PM |
