Old 10-16-2020, 09:51 AM   #1
CG3TZ
Drives: 2013 SBD Turbo FRS
Exclamation FRS Wont Start
So recently I blew a coolant line to the turbo and the car overheated reaching around 260°. I pulled over and let the car cool down before I drove home 5 minutes closely watching the temperatures. After I replaced the coolant line the car refused to start. When the Key is in the ON position it seems to have full power but when I turn the key to try and start it the car seems to just die. I replaced the battery and am still having the same issue. Does anyone know a fix?
CG3TZ is offline   Reply With Quote
Old 10-16-2020, 12:16 PM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
AFAIK the the coolant temp only works if ther is coolant in the system.
Otherwise its just hot air.
Get a socket and breaker bar and see if you can turn the motor over manually.
No? Seized the engine.
Yes?
Something else.
Old 10-16-2020, 12:18 PM   #3
CG3TZ
Yes?
Something else.
The engine is turning over but only on jumper cables and it’s just trying to catch the whole time. Key in all the way it just cranks and cranks but won’t catch. I don’t think it would crank if it was seized. It just won’t catch and start
Old 10-16-2020, 12:39 PM   #4
Old school asking here, what do you mean when you say the engine won't "catch"? Are you saying it won't "fire"?
Sorry to ask, but are sure you have gas in the tank?
Old 10-16-2020, 12:41 PM   #5
CG3TZ
Yes I have gas in the tank it’s about 1/2 full. It’s turning over but not firing and running. It only cranks on jumper cables though. Not by itself.
Old 10-16-2020, 12:52 PM   #6
pope
has a funny hat
Drives: 2014 BRZ Limited
sounds like the engine is seized.
It seems that you are saying there is so much load on the starter that it can only turn the engine with the additional amperage from jumping it. If the starter is struggling to turn the engine it will not build enough speed and compression to fire the engine.
pope is offline   Reply With Quote
Old 10-16-2020, 01:11 PM   #7
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Do a compression test and you'll know for sure. Sounds like you have probably lost compression from warping the heads
Old 10-16-2020, 05:46 PM   #8
CG3TZ
I just got it to spin The crankshaft With a socket in a breaker bar. Pushing the Pistons therefore I don’t believe it to be welded to the block or anything wrong with the motor being seized
Old 10-16-2020, 09:45 PM   #9
OK, so, the engine won't turn over with just one battery but it will turn over with two batteries but won't fire?
How many volts does the car battery read (as read by touching the battery clamps, not just the posts).
I suggest you clean the battery clamps and the battery posts.
Also, check the big fuses on top of the battery to make sure they aren't blown.
Come back.
Old 10-17-2020, 01:01 PM   #10
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Hard to crank and needs two batteries after getting overheated.
Doesn't mean your engine is seized, it obviously turns, but chances that it's very hurt are high. Get a bore scope down those plug holes. At least take the plugs out, if it doesn't crank easy at that point then consider that engine done.
Old 10-17-2020, 01:24 PM   #11
CG3TZ
We got it to bump start and it’s running fine no knocking or coolant spraying but still won’t stay alive on its own after it stops moving
Old 10-17-2020, 02:26 PM   #12
CG3TZ
https://postimg.cc/3dhTZSZb
3 codes:
P0171
P0171PD
P0451PD
Old 10-17-2020, 02:46 PM   #13
RZNT4R
System lean and purge flow. Check if you haven't melted the purge solenoid.
Old 10-18-2020, 10:05 AM   #14
CG3TZ
Is there an easier way to check other than to take the intake manifold off?
battery, starter
Car cranks but wont start yablonskiy11 Issues | Warranty | Recalls / TSB 15 01-02-2019 12:18 PM
BRZ wont start in hot weather! Coop Issues | Warranty | Recalls / TSB 3 06-28-2018 05:24 PM
Car wont start? Anyone else? ScionFrsFan Issues | Warranty | Recalls / TSB 150 06-09-2017 09:35 PM
car wont start after tune JesseTheFlash Software Tuning 7 12-17-2014 12:43 PM
Car Wont Start Up HELP !!*** ScionFR-S Issues | Warranty | Recalls / TSB 20 11-28-2013 01:01 AM
