Old 10-09-2020, 08:03 PM   #1
Loganp98
Drives: White Subaru brz
I need help with my air bags
My car was in an accident. I’ve replaced the air bags on the driver and the passenger side. I’ve also replaced the srs module. But I’m still getting codes for open circuit on driver and passenger side. Have any of you guys ran into these issues before?
Loganp98 is offline   Reply With Quote
Old 10-09-2020, 09:07 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
in other vehicles, the wiring harness needs to be replaced because airbag deployment can burn out the wires.
Old 10-09-2020, 09:20 PM   #3
Loganp98
I’ve replaced the wires in the clock spring already because they were burnt. Are you talking about the wires that lead from the srs module to the air bags?
Old 10-09-2020, 09:44 PM   #4
pope
has a funny hat
Drives: 2014 BRZ Limited
did you replace the seatbelts?
they have detonators and require replacement as well.
pope is offline   Reply With Quote
Old 10-10-2020, 12:38 AM   #5
Loganp98
Yes I’ve replaced both seatbelts, and they’re operating normally. Someone in another forums mentioned checking the fuses under the hood for the srs module. I’m going to do that tomorrow. Does anyone know if there are any connectors I could check to see if I left them unplugged? I really didn’t want to pull the dash back out of the car.
Old 10-10-2020, 03:15 PM   #6
Loganp98
I just checked the fuses, and they were good. Anymore ideas??
Old 10-10-2020, 04:20 PM   #7
soundman98
soundman98's Avatar
Yes, the main harness that's a massive pain to do.
Time to check the wires with an ohm meter
Old 10-10-2020, 10:59 PM   #8
Loganp98
Any clue where I can find a pin layout on the module? It’s pretty easy on the airbag side but when you get to the module side I can’t tell which wires I would need to probe to check for resistance.
Old 10-10-2020, 11:32 PM   #9
soundman98
soundman98's Avatar
I believe wiring diagrams are buried here somewhere:
https://demos.starbase7.net/t3Portal/
From @Ultramaroon sig
Air bags MicheleAbbate Interior Parts (Incl. Lighting) 12 07-08-2016 01:49 PM
Bags are for groceries..... Vroomin86 FR-S / BRZ vs.... 10 09-17-2015 02:10 AM
TAKATA Air Bags White64Goat Other Vehicles & General Automotive Discussions 3 05-20-2015 10:09 AM
Debating Bags _frs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-25-2014 06:17 AM
