Old 02-13-2020, 08:22 AM   #15
ka-titties
Drives: 2013 BRZ Limited 6MT
Originally Posted by prandelia View Post
Well, the Cusco coils are in, heavy duty heat-shield has been applied to key areas (in addition to my dual sided cera-coated headers), and a Beatrush vented underpanel has been employed.
If this don't give me mis-fire free operation, and better coil life, I give up! LOL.
First test will be at NCM in just a few weeks!
See you there
ka-titties is offline   Reply With Quote
Old 02-13-2020, 01:55 PM   #16
Jrwilliams
Jrwilliams's Avatar
I thought E85 engines run cooler?
Jrwilliams is offline   Reply With Quote
Old 02-13-2020, 05:59 PM   #17
prandelia
Drives: 2015 FRS
I think it's more of a case of heat soak with the coils being sandwiched between the block and the frame rails, after you stop the car. I def. wasn't allowing for airflow through there after a race/session, which certainly didn't help coils which were probably already on the edge of their ability to keep up with the demand based on my power/tune. I plan to have a fan/generator running to push airflow through the bay after every time I come off track.
If it's still misfiring after these new coils, then it's clearly something else, and I'll start digging into the fueling system and perhaps see if its something internal like a bent valve prior to me buying the car.
After building this car, it's clear the chassis is phenomenal, but it's clear you can't sell a mass produced, inexpensive sports car without cutting some fat. There are a lot of things on this car that are "just good enough". We cracked open an axle this week to rebuild them and pack them with high-temp CV joint grease, and the OE lube looks like water. No clue how it lubricates. No wonder people blow axles all the time.
Only way to find out is get out and run some flyers!
'15 FRS - GLTC spec
YouTube channel race vids: https://www.youtube.com/channel/UClU...phsppnA/videos
prandelia is offline   Reply With Quote
Old 02-17-2020, 10:21 PM   #18
prandelia
Drives: 2015 FRS
Needed to do a quick systems check prior to taking it to the track. Also had a newly rebuilt/upgraded tranny, along with a lower 6th gear ratio installed, so wanted to see how that felt.
There are some deserted backroads where I store my trailer, so was able to do a few hard acceleration runs. I didn't have any active (flashing CEL), or stored (CEL staying on) misfires on acceleration runs, and I ran the car to almost the top of 6th gear to 130mph. In the past, the car would misfire on acceleration around the top of 4th, and in 5th or 6th gear. Sometimes you could feel it, other times you couldn't, but the CEL was still flashing, and would stay on after. The good news is that I didn't see any on these acceleration runs, but won't claim victory until a full weekend on-track test is completed without misfires. Car felt super strong though.
One thing I did see though, atleast I think I did, as it happened so fast, was a the CEL flash quickly just a couple times on a massive deceleration/braking phase after a run to 125mph. I was bedding in some rear rotors so gave it a good hard stop and thought I saw the CEL flash.
I'm wondering if this could be due to the massive forces on the crank, and it's sensor readings due to deceleration? I have a Fluidampr harmonic damper, and it's a viscous type, so it's forces may change a bit with crank speed I would imagine. I'm guessing that it's possible and not an ignition related CEL/misfire, since it's in deceleration. I know Subie motors are sensitive to crank position, so I think it might be related to harmonic damper/flywheel. Any thoughts?
My plan is that if I have any non-ignition type misfires or flashing CEL's at the track, then I'll swap the OE harmonic damper back in and see if it makes any difference.
'15 FRS - GLTC spec
Old 02-18-2020, 12:25 AM   #19
CSG Mike
CSG Mike's Avatar
@prandelia do you have a log?
Old 02-18-2020, 08:51 AM   #20
prandelia
Drives: 2015 FRS
I didn't have my Ecutek Bluetooth interface on me to plug-in, so I don't have any stored files on it, unless there are some still stored in the ECU that could be downloaded.
I guess I could just go run the test again with data, since it will be another 3 weeks before I'm on track.
'15 FRS - GLTC spec
Old 04-09-2020, 07:53 AM   #21
knucklehead
Drives: FRS
I just confirmed I'm one of the unlucky early 2015 models with the "old" wiring harness from '13-14. I thought all 2015 models got the new ignition parts, not so much....so first things first, I need to swap that entire harness and coil setup for the new one, then see how things fare.
Hi, how were you able to confirm this? I am looking to buy a used engine and just wanted to make sure of the year model that I am getting and I figure that the coilpacks and wiring was a good inicator that the engine is a 2015/2016.
knucklehead is offline   Reply With Quote
Old 04-09-2020, 09:33 AM   #22
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
2013-2014 coils have a flat 3 prong electrical connector. mid-2014+ have a triangular 3 prong connector.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 04-09-2020, 07:09 PM   #23
knucklehead
Drives: FRS
Thanks Takumi!
Old 09-07-2020, 07:47 PM   #24
Chriswongbrz
Drives: 2015 brz
@prandelia Any updates?
Chriswongbrz is offline   Reply With Quote
Old 09-21-2020, 10:39 AM   #25
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Another data-point here, I too am struggling with on-track only misfires at the top of 4th. 2017 BRZ w/ ~48K miles, FBO E85.
Really hoping to hear if the coilpacks solves the issue.
Also, looks like Delicious Tuning has a set as well: https://www.delicioustuning.com/node/959
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
Old 09-21-2020, 10:53 AM   #26
jflogerzi
jflogerzi's Avatar
I wonder who the oem is for DT.
2013 Series 10 FRS #553
Old 04-05-2021, 09:23 PM   #27
jflogerzi
jflogerzi's Avatar
Did you ever solve this. I picked up a couple of used coils as I got the P3051 this past weekend at the very top of 4th bouncing a bit off rev limiter. CEL only.
Old 04-05-2021, 11:46 PM   #28
Goingnowherefast
Honestly, no I never have. To be honest, I think the fix would be a set of coilpacks like this: https://www.delicioustuning.com/node/959
In my head, coilpacks getting overheated is the issue. Having a ceramic coated or wrapped header may help this issue. (I'm still searching for a JDL 4-2-1). If i have more issues this year, I'm just gonna get those coilpacks and then report back!
Ignition system explaination? radroach Engine, Exhaust, Transmission 4 05-09-2016 06:03 PM
Fuel System upgrades protpibe Forced Induction 5 07-11-2014 12:07 PM
BRZ keyless entry/ignition and auto climte control system how-to video ayau BRZ Photos, Videos, Wallpapers, Gallery Forum 26 11-21-2013 01:58 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 0 08-21-2012 05:03 PM
Aftermarket Push Button Ignition Smart Entry System zAnSh1n Electronics | Audio | NAV | Infotainment 75 08-19-2012 02:23 PM
