Old 11-01-2018, 03:48 PM   #1
iclouhd
Drives: 2015 Hot Lava FRS
CEL/TC light code P000A
Hello all! As the title states
Was driving this morning and was at a stoplight and CEL/TC light came on, Took it to AutoZone pulled the code "P000A" then right after I left Auto zone the CEL turned off, is this a issue that will be recurring and should be maintained ASAP or am I just overreacting ..?
Thanks!
iclouhd is offline   Reply With Quote
Old 11-16-2018, 12:07 PM   #2
goku1902
Drives: 13 BRZ Manual LTD
Did it come back?
I faced the same problem. P000A came up 2 weeks ago. I dropped it off at the dealership and they replaced the Oil Solenoid Valve. Got my car back last week. Yesterday the same code came up
Do you have any mods on your car? I noticed that this issue started coming up after I installed a catback exhaust. First 2 times p0016/p0018 came up. And next 2 times p000A. All in a 6 months period(2 weeks after I installed the exhaust)
goku1902 is offline   Reply With Quote
Old 11-16-2018, 12:21 PM   #3
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
Checked your oil level?
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Old 11-17-2018, 06:00 AM   #4
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
These codes are for a SLOW RESPONSE on the VVT system. This works with oil pressure.
If you straight up want to fix this on the internet without having a professional look at it, clean the crankcase and oil system by putting seafoam in the oil, put a broomstick on the gas pedal so it keeps a 1500 rpm fast idle, let it run like that for 15 minutes, dump the oil, idle it for a few minutes with an incomplete fill (no need to waste 5+ liters, give it 3-4~ish), then dump that and change the filter for a GOOD QUALITY or OE filter.
Start your fill with 5 liters of QUALITY SYNTHETIC, run the engine until the oil is at operating temperature, park it and wait 5 minutes to check the dipstick. Add the missing splash of oil. (should be about 5.4 for a full fill hot).
Old 09-17-2020, 09:41 AM   #5
chipmunk
Drives: _
@iclouhd @goku1902
Did your problems ever get fixed permanently?
Both CEL and Slip light came on for me, and threw a P000A. Trying to make a list of all potential culprits.
chipmunk is offline   Reply With Quote
Old 09-17-2020, 05:02 PM   #6
suppjc
Drives: 2015 Scion FR-S Firestorm
https://www.ft86club.com/forums/showthread.php?t=142077
This seems to be the case for me as I found my OCVs (solenoids) are leaking into the connector and threw P000c and P000a codes. Before a hard driving one night, I had no problem driving the car, but once the code came up, the idle became inconsistent.
At the moment, I'm waiting for the solenoids to arrive and trying to avoid driving it as much as possible.
suppjc is offline   Reply With Quote
Old 09-17-2020, 05:42 PM   #7
chipmunk
Drives: _
Mine is a 2016, so I hope it has the latest revision...?
It's impossible to get the dealerships to do any work - they always wanna get away with the least amount of work they can do.
They changed my oil, drove for 20+ miles, and said it's all good. I might just pay for the solenoids myself.
By the way, with the new solenoids, is it just plug and play? Or do I need to set the plunger depth, etc.?
Sent from a potato
Old 09-17-2020, 05:51 PM   #8
suppjc
Sent from a potato
In my understanding, the solenoids are just plug and play. I'm going to disconnect the batter before cleaning the connector with an electrical cleaner just like what the post shows. To make sure your solenoids are leaking, pull out the connector and see if there is any oil sipped into the connector. 3 out of 4 of mine did.
This video will help you understand the process to install the solenoid.
Anyways, hope this will resolve my issue. When I cleaned up the connector area, the idle and everything else felt find until enough oil leaked into the connector and mess up again.
Old 09-17-2020, 06:08 PM   #9
chipmunk
Drives: _
I was just watching that video when I got the notification about your post!
Great minds...
Yea I'll definitely keep an eye on the solenoids. And on a side note, this will be my last boxer engine. Too much pain to do any major work on it!
Sent from a potato
Old 09-17-2020, 06:18 PM   #10
chipmunk
Drives: _
Hey @Ultramaroon, I got this image from your signature.
In order to test the OCVs to make sure they don't have any oil leaking or electrical shorting inside, can you check the resistance while it is mounted on the engine? Or do they need to be removed?Name:  Screenshot_20200917-181555_Samsung Internet.jpg
Sent from a potato
Old 09-17-2020, 08:36 PM   #11
No need to remove. I'm surprised that there isn't a check for internal short to ground. I'd do that out of habit. ¯\_(ツ)_/¯
ABS and Traction light- No Code neroman98 Issues | Warranty | Recalls / TSB 12 07-21-2018 06:06 PM
P000A and P0011 Riftur Issues | Warranty | Recalls / TSB 5 02-13-2017 09:32 PM
Cylinder Head Assemblies causing P000A & P000C? SoundsOfTheUniverse Issues | Warranty | Recalls / TSB 3 01-23-2017 05:37 PM
P000A AVCS check engline light? cookiesowns Issues | Warranty | Recalls / TSB 4 10-24-2015 01:48 AM
Check engine light code reader FRSCoupe Engine, Exhaust, Transmission 14 06-13-2012 05:06 PM
