Old 08-14-2017, 10:24 PM   #365
OND
OND's Avatar
Drives: 2023 BRZ
Originally Posted by NLS8520 View Post
Yes I have seen negative info in uoa reports.
Details?
OND is offline   Reply With Quote
Old 09-13-2017, 08:18 PM   #366
cueball89
Drives: 15 Impreza
New UOA, didnt get a chance to order the amsoil kit before changing the oil. Probably wont be doing another UOA for awhile as everything seems ok and I don't plan on changing interval length or usage.
Wix oil and air filters. The farthest right column is Pennzoil 0w-20 and middle column is the first oil change with Pennzoil Euro 0w-40.
cueball89 is offline   Reply With Quote
Old 10-16-2019, 08:37 AM   #367
ajc209
Drives: GT86 Cosworth
Miller Oils Analysis
Got my oil analysis back from Millers oil.
My car is supercharged running ~300hp
Has forester oil cooler and a low temp t stat.
water typically runs 80C and Oil 85C
Can covered 3k miles between services.
Note the 2.5% fuel dilution. Apparently the DIT version of this engine runs similar fuel dilution numbers.
[IMG]
ajc209 is offline   Reply With Quote
Old 07-17-2020, 05:53 AM   #368
vicious_cb
Drives: 2020 86 Hakone
I get that the factory fill is pretty good but for someone with OCD and the need for data would changing the factory fill at 3750 with Red Line 0w20 be a good option? since it seems to have similar Moly and ZDDP to the FF.
vicious_cb is offline   Reply With Quote
Old 07-17-2020, 06:55 PM   #369
R L Newb
Drives: LR BRZ Ltd, 06 STi
Totally forgot about this thread! There’s a lot of personal preference when it comes to oil. Going into it I knew I’d be driving an incredible amount of miles very quickly and wanted to demonstrate how stock oil holds up at stock intervals with daily driving.
Selecting the proper oil composition and weight depends on your use. If you plan on driving 90k highway miles in two years with oil changes between 7500-10k miles the stock seemed to work out ok. I did zero real performance driving with this car.
R L Newb is offline   Reply With Quote
Old 07-17-2020, 10:18 PM   #370
vicious_cb
Its mainly a DD, mostly Hwy miles and some spirited driving on canyon roads. Im not going to feed it red line for the rest of its life, that would be far too expensive. Looking at your oil analysis and composition of the factory fill it seems red line comes close to what comes from the factory.
Old 09-08-2020, 06:38 PM   #371
vicious_cb
Did my first oil change at 3000 mi and replaced it with Red Line 0w-20. Sent it out for UA waiting for a response. I planned on going longer on the FF to maybe 5k but Ive been driving around during a heat wave of over 100 deg F and smoke from the wildfires around here.
Old 09-16-2020, 06:23 PM   #372
vicious_cb
Finally got my OA back, whatever is in the new factory fill has a hell of a lot of moly compared to the other factory fills in this thread.
Old 11-04-2021, 03:49 PM   #373
qiumaoyuan
qiumaoyuan's Avatar
Drives: 2017 BRZ MT, 2009 Civic sedan AT
After comparing most of these data, seems like the OEM oil is the best..
qiumaoyuan is offline   Reply With Quote
Old 11-04-2021, 07:21 PM   #374
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It is likely because of the engine assembly lube. All engine assembly lubes I have ever seen are extremely high in moly.
Old 11-04-2021, 07:36 PM   #375
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Additives are great on the OEM fill. My 2013 did not like the 0-20 though. Much lower wear with Castrol 0-30 (European formula).
Old 11-19-2021, 10:24 AM   #376
alphasaur
friendly
Drives: 17' 86
see attached for PP 5w30. Had a track day with probably 50 laps and an autocross on this oil.
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
DIY BRZ / FR-S Oil Change RallySport Direct DIY (Do-It-Yourself) Guides 169 09-01-2018 03:42 AM
First Oil Change Jehuty77 CANADA 14 08-10-2012 12:54 AM
When to do your first oil change, and why... MrBodyMassage Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 07-17-2012 08:43 PM
Do you change your own oil? If so, why? SteelReign Other Vehicles & General Automotive Discussions 76 04-15-2012 05:44 AM
