Old 07-20-2020, 12:29 PM   #4299
TheRichLife
TheRichLife's Avatar
Drives: 18' BRZ tS
Looking at a set of ESR RF2 for my BRZ tS lowered on Eibach Sportlines with -2.5 degrees of camber.
I reached out to ESR and they said with18x9.5 +22 they are "pretty sure will fit the Brembos" but that they didn't have confirmation.
They also offer 18x9.5 +35. In the same wheels.
I like the aggressive wide wheels with poke but would the +22 look absolutely ridiculous? This would be my street set-up. Any autocross days will have the stock Enkeis.
Should I roll the dice on the +35?
Any info/advice would be appreciated.
Looking at 235/40 18 tires to go with the set up
18' BRZ tS 300/500 (CBS)
TheRichLife is offline   Reply With Quote
Old 08-25-2020, 03:34 PM   #4300
LatentWagen
Drives: '17 BRZ / CBS + PP
My SSR Comps clear Brembos with no spacer, at ET +48 on an 8.5" wheel. So, 9.5 would put it -13, which would be right on at +35. Spoke design, however, is what it's all about.
I wouldn't roll the dice without pics of the ESR wheels from the side, showing spoke "arc"... If it helps, I can post a clearance pic with my wheels so you can eyeball.
LatentWagen is offline   Reply With Quote
The Following User Says Thank You to LatentWagen For This Useful Post:
TheRichLife (08-29-2020)
Old 09-01-2020, 02:09 AM   #4301
Misfit714
would i need spacers to clear esr sr01 wheels that are 18x9.5 +35 ?
Misfit714 is offline   Reply With Quote
Old 09-01-2020, 05:55 AM   #4302
djezlee
Drives: 2017 BRZ Limited
I want to get some SSR Professor SPX wheels with a staggered fitment. Evasive is recommending standard concave 18x9.5 +35 in the front and super concave (SL) disc 18x9.5 +30 in the rear. Does this sound like it should fit? It sounds a little suspect to me, and I am worried about clearance issues in the rear. But I'd like a second opinion from the experts.
djezlee is offline   Reply With Quote
Old 09-01-2020, 02:00 PM   #4303
Vital
Drives: 2015 BRZ
Not if you have coilovers it will fit just fine.
Old 09-01-2020, 02:05 PM   #4304
Vital
Drives: 2015 BRZ
If you want to do this make sure you are on coilovers other wise the fronts definitely wont fit and rub the fenders. The rears will fit without issues. Also i'd avoid getting a staggered setup. It offers no benefit, this car was designed to have a square setup.
The Following User Says Thank You to Vital For This Useful Post:
djezlee (09-02-2020)
Old 09-01-2020, 03:25 PM   #4305
churchx
churchx's Avatar
Drives: 2014 GT86
Vital: in this case suggested wheel diameter and width is same, only different offset. Not exactly staggered in classical sense, kind of lesser evil. While such setup will still have some cons, but less bad then more common staggered different width wheels choice which will add lot of understeer. My own choice would still be same wheels on all four corners, and if fitment matters that much, then one can use on one axle spacers, but for some suggested also may work.
Old 09-01-2020, 03:52 PM   #4306
Vital
Drives: 2015 BRZ
Woops you're right i totally misread that. Yes, agreed this is actually better than running different sizes. I assume he/she may just want different offsets for looks so this should work it should not have any noticeable impact on driveability.
Old 09-01-2020, 09:25 PM   #4307
Misfit714
im on airlift 3p kit!
Old 09-02-2020, 01:57 AM   #4308
churchx
churchx's Avatar
Drives: 2014 GT86
Now on airlift, there might be clearance problems, not more clearance vs stock as with most aftermarket coilovers (which usually have smaller diameter springs then stock). I guess, to be on safe side, i'd probably think of not going to x9.5". Unless widebody, but then very different offsets/wheels anyway.
Vital (09-02-2020)
Old 09-02-2020, 07:31 AM   #4309
Vital
Drives: 2015 BRZ
Ah in that case, disregard what i said. Unfortunately, i cannot help with air suspension fitment. Here is a thread that might help you: https://www.ft86club.com/forums/showthread.php?t=77588
Old 09-02-2020, 10:57 AM   #4310
djezlee
@Vital & @churchx... thanks for your help!
Old 09-02-2020, 08:18 PM   #4311
Misfit714
Thanks, hopefully someone responds im wondering if my wheels/tire combo will clear !
Old 09-13-2020, 03:54 AM   #4312
tulio86
Drives: gt86 hachi-roku
Question wheel if it?
Hey guys, urgently asking you, i already bought new wheels, so the size is 9.5J ET48 front and rear, wheel it fit in front with 245/40/18 in stock car, it wil not scrub or rub smthg? or should i do 235/40/18 and 245/40/18 rear, i cannot fit 35% because of the asphalt in our city...
tulio86 is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
