Old 08-30-2020, 12:31 AM   #15
glhs386
Drives: 2014 FR-S Monogram
Originally Posted by Randoman5 View Post
My 94 trans am came with 245s on 8 inch wheels. I switched to 275s on 9 inch wheels (also a factory offering.) I don’t know why people are telling you 245s won’t work. 235 is an oddball size and selection of tires will be limited.
The tires on your Trans Am had taller sidewalls. The taller the sidewall, the narrower the recommended wheel width range will be for a given tire width. For a 245/40/17, the allowed wheel width range is typically 8 to 9.5 inches. So while it will technically "work" on an 8 inch wheel in the sense that it will physically mount, it's pinched down on narrowest wheel possible which is not optimum for handling. The same 245 would be much happier mounted on a 9 inch wheel, which is why it's such a common setup in STX.
glhs386 is offline   Reply With Quote
The Following User Says Thank You to glhs386 For This Useful Post:
ZDan (09-02-2020)
Old 08-30-2020, 06:31 PM   #16
mrg666
pessimistic skeptic
mrg666's Avatar
I don't know either
245 width is within industry specs for installing on 17x8 wheels. And, I have been driving 245s since last three years on 17x8 wheels. Even Toyota service technicians said it is perfectly fine Plus, 245/40-17 is the closest tire size to stock diameter of 215/45-17.
Old 08-30-2020, 06:40 PM   #17
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
I would go 245 40 17. So many tire choices and there will always be an option if you run in to an emergency.
The Following User Says Thank You to Summerwolf For This Useful Post:
mrg666 (09-02-2020)
Old 09-02-2020, 02:08 PM   #18
ZDan
ZDan's Avatar
Drives: '23 BRZ
see glhs386 response above ^^^
Measuring rim width for a 245/50-16 is 7.5", an inch narrower than 8.5" measuring rim for a 245/40-17.
Rim width range for 245/50-16 is 7" to 8.5"
Rim width range for 245/40-17 is 8" to 9.5"
For a *handling* intensive fitment, you kinda want to be on the wide end of the rim width range.
17x8 is not a good wheel width for a 245/40-17 IMO. It is the narrowest allowed for that tire size. I'm running 245/40-17s on 9" wheels for street/track.
The Following 2 Users Say Thank You to ZDan For This Useful Post:
mrg666 (09-02-2020), Randoman5 (09-02-2020)
Old 09-02-2020, 03:37 PM   #19
mrg666
pessimistic skeptic
mrg666's Avatar
We are talking about personal preferences within allowed industrial standards. I went with lighter 17x8 wheels on 245/40-17. I don't see any handling problem either. One can also argue about the advantages of lighter wheels. I don't even like the looks of a stretched tire or super flush setups. Plus, practically, there is much larger chance of curb rash with 245s on 17x9 wheels. Furthermore, 17x9 will most probably rub stock suspension or require coilovers, if it is not a super tight fit .......
I pass, thanks. But, I am happy that your setup works for you.
The Following 2 Users Say Thank You to mrg666 For This Useful Post:
Vital (09-03-2020), ZDan (09-02-2020)
Old 09-02-2020, 06:14 PM   #20
ZDan
ZDan's Avatar
Drives: '23 BRZ
Yeah, it's within spec, I agree it can be down to personal preference... I've never been a fan of the super-stretched look anyway... But for me my street wheels/tires are also sometimes track time-trial wheels/tires, so to optimize grip from a 245, a 9" or 9.5" is the way to go.
Street only, a bit of sidewall pooch isn't necessarily a bad thing and can act as more of a "rim-protector". I still prefer staying in the middle of the recommended rim width range but it's not a huge deal.
mrg666 (09-02-2020)
Old 09-03-2020, 07:50 PM   #21
jflogerzi
jflogerzi's Avatar
Car looks good. Running 245 on a 17x8 rim. No issues for me either. It's got a nice meaty look.
2013 Series 10 FRS #553
Old 09-07-2020, 10:21 PM   #22
TytheToyotaGuy
I'm running 245/40R17 RE71Rs on track on a 17x8 wheel, no issues.
Every tire is a little different though, so confirm the brand you're going with that 8.25 is in their acceptable range, this information is usually on tirerack under the specs for the different sizes, but generally speaking 235 or 245 should be fine on a 8.25 wheel.
TytheToyotaGuy is offline   Reply With Quote
Old 01-22-2022, 07:21 AM   #23
Gilbz
Drives: Frs
So rubbing?
Originally Posted by tracerit View Post
Here's how my car stands now with 235/45/17 MPSS and XXR 527 17x8.25 on Eibach Pro Kit springs. Unsure of the alignment numbers.
So how much did you lower the car? And just to confirm, you ARE rubbing? The fit looks so dope, it suck if that's the case :/
Gilbz is offline   Reply With Quote
Old 01-24-2022, 01:03 PM   #24
Vital
Drives: 2015 BRZ
Eibach ProKit lower the car 1" and i highly doubt hes rubbing. If he is it might be on the fender since those tires a little taller than OEM specs. But like i said im pretty sure he is not rubbing because of that offset and and width. 17x8 +35 will give a flush fitment if you plan to lower your car 1"
ESM 004 size questions- And 17x8 pic requests newports Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-02-2014 02:19 AM
Tire size TofuAE86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-10-2014 12:03 AM
Tire size for 17x8.5 +32 +42 giraffee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-06-2013 08:17 PM
Which tire size for 17x8.5? giraffee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-11-2013 07:26 PM
Tire Size help! J-Money Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-04-2013 12:04 PM
