Old 08-24-2020, 02:24 AM   #1
crzybrz
Drives: 2013 Subaru BRZ
Push To Start not working
I have a 2013 BRZ with 160k miles on it. Every time I push the start button, the green key light starts flashing and will only go into on/accessories mode and won't start even with the clutch fully depressed. sometimes, after pressing the clutch down and clicking the start button multiple times it occasionally starts up. I have already replaced the clutch starter switch at the pedal and it seemed to help for a little bit but after about a week it started doing the same thing and has gradually gotten worse. anyone have a similar issue and got it fixed?
crzybrz is offline   Reply With Quote
The Following User Says Thank You to crzybrz For This Useful Post:
humfrz (08-24-2020)
Old 08-24-2020, 09:07 AM   #2
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Will it start if you hold the fob to the start button?
The Following User Says Thank You to dragoontwo For This Useful Post:
p1l0t (08-28-2020)
Old 08-24-2020, 01:28 PM   #3
Welcome to the gang, there, crzybrz -
Now, tell me you have replaced the batteries in the FOB?
Tried another FOB?
Old 08-25-2020, 03:30 AM   #4
crzybrz
Tried another FOB?
I have replaced the batteries on both fobs, and have held the key to the start button as well, woke up this morning and the car started first try but every once in a while it doesnt
humfrz (08-25-2020)
Old 08-25-2020, 07:43 AM   #5
Corpseye
Corpseye's Avatar
Drives: Subaru brz 2016
Check your battery, if its worn that might be it. Should be around 13-14 volts fully charged.
Corpseye is offline   Reply With Quote
The Following 2 Users Say Thank You to Corpseye For This Useful Post:
humfrz (08-25-2020), p1l0t (08-28-2020)
Old 08-25-2020, 01:50 PM   #6
Good idea.
Welcome to ye ol forum ....
p1l0t (08-28-2020)
Old 09-08-2020, 12:50 AM   #7
crzybrz
Sorry for not replying sooner, my battery has tested fine. I’ve checked the alternator and starter and they are okay as well, it still goes to on, the accessory mode then off and I’m stumped on what it could be
humfrz (09-08-2020)
Old 09-08-2020, 01:50 AM   #8
Brz866
Brz866's Avatar
Drives: Series Blue WRB JRSC C38 HBP Flex
Clutch safety switch?
Brz866 is offline   Reply With Quote
Old 09-08-2020, 01:54 AM   #9
Maybe the start button (switch) itself is bad?
Old 09-08-2020, 01:57 AM   #10
He said in his first post he has replaced that.
Pay attention -
(jest ah messen wich ya - )
Stall/No Re-start with push button start couver Scion FR-S / Toyota 86 GT86 General Forum 11 06-26-2020 11:32 PM
FS: STI engine start push start OEM plug and play sokol Interior Parts (Incl. Lighting) 5 06-13-2019 03:12 PM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 07:06 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 03:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 04:44 AM
