#15 |
Drives: GR86
Indeed I think your comment on temps is valid based on many readings that show when synthetic oils break-down. https://www.waynesgarage.com/tips/mo...0under%20loads.
The important part to consider is ensuring oil pressures remain good at those high temps. I'm not sure how engine parts and surrounding parts like to be at high temps like 270F for extended periods of time, but I'm getting convinced that the oil wouldn't be the weak point here. |
#16 |
Drives: Halo 860
Right, as I understand it oil breakdown is not the concern with our engines running hot. It's more so the tendency for oil pressure to drop approaching redline when combined with oils thinning out at higher temps, regardless of whether the actual integrity of the oil is compromised.
#17 |
Drives: 2016 Scion FRS
I have a '16. I was running the Toyota 0w20 stuff and was having issues going into limp mode with a slow cam response CEL at pro solos (you hot lap 4 autocross runs at a pro solo) during summer events. I switched to 5w30 and that seems to have cleared up that problem.
| The Following User Says Thank You to steverife For This Useful Post: | gcmak (07-13-2020) |
#18 |
Drives: 2016 Scion FRS Release Series 2#439
5W20 and now 0W20 are specified to meet EPA demands.
Your EPA could care less how long your engine lasts. Only how little fuel it burns. When asked about these light-weight oils a few years back, a local engine re-builder said he would recommend 20W50 for anyone interested in maximum engine life. I wonder if the oil galleys of the latest engines can flow such heavy oils. 5W30 full synthetic only for my 2016 and the others in my fleet as well. |
| The Following User Says Thank You to Muskoka800 For This Useful Post: | Tokay444 (08-25-2020) |
#19 | |
Drives: 2018 Subaru BRZ Limited with PP
#20 |
The Fail Boat
Drives: CWP S.B.
According to @humfrz you use heavy weight oil when your car starts to leak.... which is what i'm gonna be doing in future starting next oil change.
*yes it has a tiny leak from the engine bottom end/valve cover.... engine out job..
| The Following User Says Thank You to chaoskaze For This Useful Post: | humfrz (08-25-2020) |
#21 | |
| The Following User Says Thank You to humfrz For This Useful Post: | WildCard600 (08-25-2020) |
#22 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Sawdust in the transmission and differential make those a lot quieter too.
Balsa, fir or oak ... hmm. Teak. Yeah that's the ticket!
"I gotta rock." -- Charley Brown |
| Tags |
| engine oil, oil weight |
| What has changed in the exhaust from 2016 to 2017? (GReddy revolution) | edwardl | Engine, Exhaust, Transmission | 11 | 05-10-2019 03:12 PM |
| 2017 Toyota 86 : Optional equipment parts numbers | trueno86power | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 11-27-2016 02:15 PM |
| WHO KNOWS? Engine component weights & dimensions? | justatroll | Engine, Exhaust, Transmission | 8 | 08-27-2016 01:08 AM |
| FA-20 engine and transmission weights | seant2h | Engine, Exhaust, Transmission | 0 | 07-24-2016 10:04 AM |
| Changed Air Filter caused check engine light | Buellr | DIY (Do-It-Yourself) Guides | 10 | 01-13-2015 05:55 PM |
