Old 08-17-2020, 05:26 PM   #15
Tokay444
Originally Posted by norcalpb View Post
Control arm or tie or tie rod?
I checked for play in the ball joints/looseness of the nuts and didn’t find anything wrong.
Get it on an alignment rack and put a stethoscope on both. Done.
Old 08-18-2020, 03:30 PM   #16
norcalpb
norcalpb's Avatar
Now that you mention it I do feel a weakness from the front suspension. Sounds like a wooden board being smacked against the ground when I hit big bumps.
It’s $1,100 shipped in parts to replace all my front suspension components (steering rack + tie rods, wheel bearings, front control arms), so I just need to figure out how much I love this car.
Old 08-19-2020, 11:29 AM   #17
Tokay444
You need to figure out what's actually wrong before throwing parts at it.
My money is it's NOT the rack OR the wheel bearing. There's no misconstruing the sounds of a bad wheel bearing and it only gets louder with speed.
Old 08-19-2020, 11:59 AM   #18
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Opie View Post
Check to make sure all the bolts securing the metal tray under the engine are tight...if loose it makes all kinds of fun noises.
Check this as it's free....
My car was making noises like in the video although a lot less of them and only one of the bolts was quite loose, several were snug but not tight enough. Noise went away after tightening the panel.
Might not be it but considering it takes a whole 5 minutes and is free I'd certainly check it before spending any money on other parts.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Opie (08-19-2020)
Old 08-19-2020, 12:21 PM   #19
DarkSunrise
DarkSunrise's Avatar
Yeah I came in to post this as well. I was getting a similar sound after a track day, expected the worst, and found it was just the underbody panels. Probably my fault for not tightening the bolts enough after working on the header. Only made noise when loading the steering rack.
Mine wasn't nearly as loud as that video, so might not be it, but as Dave said it's free so may as well check it.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
Opie (08-19-2020)
Old 08-25-2020, 11:28 AM   #20
chipmunk
Drives: _
TLDR:
Remove all splashguards underneath the car and drive again. If the problem goes away, then great!
Long story:
My car had popping noises when turning the steering while backing up, whether in reverse or downhill in my driveway. Only happened for a few feet at very low speeds. Turned out that it was one of the splash guards. Whether they were rubbing against something, or the bolts were jumping threads - I don't know. It was just a matter of retightening the bolts for me. Might be a different case for you though.
chipmunk is offline   Reply With Quote
Old 08-25-2020, 11:48 AM   #21
ka-t_240
I have had this noise for years. I only get 1 or maybe 2 pretty solid "clicks". Primary low speed turns or coming up a angle or coming in/out of driveways.
We have nut and bolted the full car many times. Checked bearings/bushings/etc. with no luck. Its almost impossible to get it to do it like the videos in this post.
I had it on a rack once, and was trying goofy things like trying to load 1 corner and pull on bolts and got the click to come while applying torque to the steering rack bolts. But, I could not repeat after taking them out cleaning them up and retorque. The noise came back very quickly after.
ka-t_240 is offline   Reply With Quote
Old 08-26-2020, 05:48 PM   #22
norcalpb
norcalpb's Avatar
Just wanted to update this as I did (hopefully) figure out my noises.
I traded my hood with another user’s FRS and I never changed the rubber hood adjustment knobs, and they were way too low so my hood was banging around.
Also I realized I never installed grease on my TRD front sway bar’s bushings so I’m not 100% sure this is the noise, but when I get my grease in the mail I will update again.
Edit: just kidding, it is not my sway bar bushings. Noise is coming more from the wheel. Will have whole car inspected soon. I bought tie rod ends for the hell of it.
Old 08-27-2020, 09:31 AM   #23
Tokay444
Have friend do exactly that with the steering wheel while you use a long screw driver like a stethoscope. It’s ball joint or tie rod (which has a ball joint).
Old 08-30-2020, 06:45 PM   #24
warrhaslauer@yahoo.com
Drives: 2013 frs
i agree lower control arm ball joint
warrhaslauer@yahoo.com is offline   Reply With Quote
Old 08-31-2020, 05:47 PM   #25
kevaughan
kevaughan's Avatar
Drives: BMW E30, 2014 FR-S
I had this issue and it turned out to be my front end links. I had those Perrin end links but the rubber part split at the joint.
It only made creaking sounds when steering at low speeds through a parking lot for example; and I heard nothing when I was going over bumps on the road/highway. I now have whiteline front end links.
kevaughan is offline   Reply With Quote
Old 09-05-2020, 02:01 AM   #26
norcalpb
norcalpb's Avatar
Update: I solved my noise with new OEM outer tie rods. The difference is night and day.
Lower control arm ball joints are still OK after 150k miles.
Wheel bearings are indeed still ****ed, the alignment shop I took it to giggled at the amount of play.
Entering high mileage sucks.
Old 09-05-2020, 12:19 PM   #27
msaikhan
Drives: frs
I had the same noise not as loud as yours. I spent all morning and checked everything and it was sway bar bushing, it was hard and crusty, put some WD40 on it. Noise went away. Ordering new bushing. I replaced tie rod about a month ago so i know its not tie rods.
msaikhan is offline   Reply With Quote
Old 09-05-2020, 12:29 PM   #28
msaikhan
Drives: frs
You should put some grease on them. They will fail premature without grease.
The Following User Says Thank You to msaikhan For This Useful Post:
norcalpb (09-05-2020)
Popping, Crunching and Creaking Noise MyEvilMonkeys Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 07-22-2020 01:50 PM
Popping/creaking noise in hard left turns TheLaughingMan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 09-20-2019 06:01 PM
FS: Perrin Steering Rack Lockdown Kit and STI Steering Rack Long Bolts Kit neilvosko Brakes, Suspension, Chassis 3 04-10-2018 06:48 PM
Creaking from front end when turning steering wheel finch1750 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 12-05-2015 04:21 AM
Front endlinks possibly loose (steering popping a little) Keenercarguy Issues | Warranty | Recalls / TSB 4 10-25-2015 09:55 PM
