Old 08-07-2020, 10:40 AM   #1
curbybrz
Bad creaking/popping from front, steering rack?
The popping has been happening for a while but yesterday it started to creak pretty bad now. It mainly happens at low speeds and turning. I've been doing some reading and maybe has something to do with the steering rack bolts loose?
curbybrz is offline   Reply With Quote
Old 08-07-2020, 10:52 AM   #2
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Could also be suspension related if something is binding or worn out.
Year and mileage? When is the last time it was inspected?
Old 08-07-2020, 11:06 AM   #3
curbybrz
It is 2013 with 90k on it. It was inspected 2 months ago. It wasn't happening with enough frequency to get the mechanic to hear it. I can push down on the corners of the car and doesn't make the noises if that matters. Also don't notice it on bumps. I can make it happen parked and just turning the wheel from side to side.
Old 08-07-2020, 01:12 PM   #4
Hi ya, curbybrz and welcome to our group -
Are you sure the sound is coming from the front?
If so, you might try turning it from side to side driving it down the road to see if a front wheel bearing is going bad.
I would suggest you take your car into a shop and have them inspect the front end.
Old 08-07-2020, 01:31 PM   #5
curbybrz
Thanks and I'm almost positive it is from the front. Sometimes I can hear a similar pop coming from the front right. The majority of the noise you are hearing in the video sounds like it is coming from the front left. I had my coworker listen to it a little while ago and he seems to think it is coming from more toward the middle of the front. I may just have to take it back in and see what the mechanic thinks now that the sound is more prominent.
The Following User Says Thank You to curbybrz For This Useful Post:
humfrz (08-07-2020)
Old 08-07-2020, 01:43 PM   #6
Yep, best have a shop look at it.
Let us know what was wrong with it.
Old 08-07-2020, 05:32 PM   #7
norcalpb
norcalpb's Avatar
Man I got the same issue going on. I’m leaning towards the rack being bad.
Old 08-07-2020, 05:44 PM   #8
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Could it be the Electronic Power Steering (EPS) coupler?
FRS/BRZ EPS Motor Coupler Replacement (Rattle Fix)
Old 08-17-2020, 12:05 AM   #9
CTB727
Drives: 2013 Subaru BRZ
I had this issue about 2 years ago, at around 75k miles. Dealer ended up replacing the steering column. Got it covered under warranty because the noise started happening shortly after a short block replacement.
CTB727 is offline   Reply With Quote
Old 08-17-2020, 11:59 AM   #10
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Check to make sure all the bolts securing the metal tray under the engine are tight...if loose it makes all kinds of fun noises.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 08-17-2020, 01:04 PM   #11
norcalpb
norcalpb's Avatar
Mine is most likely wheel bearings (both my fronts have some play) I can only hear it when at a dead stop. OPs sounds like upper strut mounts, that noise will come through the firewall at any speed.
Old 08-17-2020, 02:33 PM   #12
Tokay444
That's a ball joint.
The Following User Says Thank You to Tokay444 For This Useful Post:
Takumi788 (08-27-2020)
Old 08-17-2020, 02:35 PM   #13
Tokay444
It's definitely not a wheel bearing.
Old 08-17-2020, 02:40 PM   #14
norcalpb
norcalpb's Avatar
Control arm or tie or tie rod?
I checked for play in the ball joints/looseness of the nuts and didn’t find anything wrong.
Popping, Crunching and Creaking Noise MyEvilMonkeys Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 07-22-2020 01:50 PM
Popping/creaking noise in hard left turns TheLaughingMan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 09-20-2019 06:01 PM
FS: Perrin Steering Rack Lockdown Kit and STI Steering Rack Long Bolts Kit neilvosko Brakes, Suspension, Chassis 3 04-10-2018 06:48 PM
Creaking from front end when turning steering wheel finch1750 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 12-05-2015 04:21 AM
Front endlinks possibly loose (steering popping a little) Keenercarguy Issues | Warranty | Recalls / TSB 4 10-25-2015 09:55 PM
