Mountain Runner
Drives: 2013 Subaru BRZ Limited 6MT
Front endlinks possibly loose (steering popping a little)
So my end links on my front suspension might be loose, does anyone know the torque specs/ have any tips for torquing down the stock end links?
Drives: 2016 Halo FRS
I thinkkkkk its 34 ft/lbs but don't quote me. I will get back to you though with the correct specs. im just going on memory from when I put my coilovers on.
| The Following User Says Thank You to Trust86 For This Useful Post: | Keenercarguy (10-21-2015) |
ok so yea I was correct. The end link side that connects to the suspension is 34 ft/lbs. Not sure about the other side that connects to the sway bar though. I never looked at that. idk if the sway bar side has a bigger bolt/nut but I don't see why it would.
| The Following 2 Users Say Thank You to Trust86 For This Useful Post: | Bonburner (10-25-2015), Keenercarguy (10-21-2015) |
Mountain Runner
Thanks! How safe do you think I am to assume that they are the same? haha
Update! Yes, all four bolts are 34 lb/ft… found a diagram that included the specs for the sway bar side. Last edited by Keenercarguy; 10-21-2015 at 10:56 PM. |
| The Following User Says Thank You to Keenercarguy For This Useful Post: | Bonburner (10-25-2015) |
Did torquing it down solve the problem?
| Tags |
| diy, endlinks, help me, suspension |
| Weird steering popping. | mamamiaellis | Issues | Warranty | Recalls / TSB | 3 | 07-16-2015 06:07 PM |
| steering wheel coming partially loose | balci | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 03-30-2015 02:11 PM |
| OEM FRS front & rear springs, and front endlinks | VacantSky | Brakes, Suspension, Chassis | 3 | 09-26-2014 05:14 AM |
| Rattle in the Steering Column and loose key? | Thehermdawg | Issues | Warranty | Recalls / TSB | 3 | 08-07-2014 03:51 AM |
| Front Endlinks | goke186 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 08-31-2012 01:16 AM |
