Old 07-26-2020, 11:50 PM   #253
geraldjust
Drives: MR2, Sliver BRZ
Originally Posted by gcranston View Post
Chris Fix here, and today I'm going to show you how to disable your ABS using simple hand tools...
I imagined his voice in my head haha. Yeah pulling a fuse disables the abs unit as a whole. But that's including brake balancing. Not sure if you can also keep the speedo working while the abs doesn't get power. Plus people can be lazy so a car switch works for people lol. This abs feature is just a niche.
Gerald R.
Always looking to tinker with something..
geraldjust is offline   Reply With Quote
Old 07-27-2020, 05:59 PM   #254
gcranston
Drives: 2015 Subaru BRZ Limited DGM
Sure it's a niche, but a niche that get's me one classing point back for time trials.
gcranston is offline   Reply With Quote
Old 08-05-2020, 10:45 PM   #255
AllThePeat
Drives: 2019 Autox BRZ & 2021 GTI (Daily)
Wondering if anyone else is experiencing an issue when using ecutek and the tracbox where when turning the fans on, the connection to the Bluetooth dongle plugged into the OBD2 dies and any data logging is interrupted. When activating the pedal dance, I do not experience this and the dongle works normal. I’m using the below configuration...
- Pedal Dance and Fans on a switch
- EcuTek Bluetooth dongle & app to log/view data
Anyone else experience this — is it expected behavior?
2019 BRZ | Autocross focused, CSG tuned w/Jackson racing C38 & PTuning flex fuel kit
2021 GTI | Daily
AllThePeat is offline   Reply With Quote
Old 08-05-2020, 11:50 PM   #256
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I can try to test this when mine arrives since I did order the fan option.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
AllThePeat (08-06-2020)
Old 08-06-2020, 09:30 AM   #257
peaches
Drives: '14 BRZ Limited
Yes, I have this problem
peaches is offline   Reply With Quote
The Following User Says Thank You to peaches For This Useful Post:
Old 08-06-2020, 02:46 PM   #258
geraldjust
Unfortunately thats the nature of the beast. The Tracbox sends the command to turn on the fans every once in a while in the advanced OBD2 range of canbus IDs. This also happened in the original beastronix. I have taken a lot more steps to minimize data crossing. Just because to activate the fan it has to do so X amount of times per minute. So when fans are on that's what happens.
If its a issue when cooling down your car, i can see if i can prolong the period. So it would be something like 5 seconds on, 5 second off, repeat... it could relive that issue.
Gerald R.
The Following User Says Thank You to geraldjust For This Useful Post:
Old 08-06-2020, 04:19 PM   #259
peaches
Gerald R.
So far it doesn't bother me, I only use the fan to cool the car after a session. At that point, I'm not logging anything. I just noticed it while I was out testing some cooling updates.
Old 08-06-2020, 09:51 PM   #260
AllThePeat
Gerald R.
Thanks for the explanation — makes sense — appreciate it! And yea, not really an ‘issue’ (probably shouldn’t of used that word), but was curious if this was expected. Thanks for the responses — have loved the product so far!
2021 GTI | Daily
Old 08-06-2020, 11:09 PM   #261
geraldjust
I mean thing is still great feedback. If you guys think its a good idea i can modify it a bit.
Good news for anyone that also wants the ABS disable. Works in all speeds! Its scary to know ABS can be disabled and the effects on the car are. and how worse it is if you have the EBD off.
Jyn (08-07-2020)
Old 08-07-2020, 03:57 PM   #262
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Originally Posted by iLuveKetchup View Post
The tracbox will provide the +12v & GND.
Edit for clarification: The Tracbox (if ordered w/ pedal dance & fan switch capability) will have 4 leads -- 1 to pedal switch, 1 to fan switch, 1 red lead for +12v, and 1 black lead for GND.
Thanks for that. So just run the power to one of the LED 12v in, then daisy chain them all. Same for ground. What gauge wire you use? I almost never do wiring aside from some butt connectors
Jyn is offline   Reply With Quote
Old 08-07-2020, 03:59 PM   #263
Jyn
Noob
Jyn's Avatar
I had emailed you earlier about the ABS feature and just found this thread. Gonna place my order today.
Old 08-07-2020, 08:39 PM   #264
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
18 AWG will do just fine.
iLuveKetchup is offline   Reply With Quote
The Following User Says Thank You to iLuveKetchup For This Useful Post:
Jyn (08-08-2020)
Old 08-13-2020, 06:21 AM   #265
mjpa
Drives: White GT86
After a 3 month wait, thanks covid and customs, finally got mine today, the lid of the box was a felt a bit flimsy and the box itself was a bit dirty. Opened it up and the PCB (both sides) is like this...
presumably some IPA will clean it up, it doesn't just brush off and looks like somethings dried on it. Anyone else receive one like this?
mjpa is offline   Reply With Quote
Old 08-13-2020, 09:11 AM   #266
soundman98
ProCrastinationConsultant
soundman98's Avatar
that's the mark of using super glue to bond the two case halves together. superglue isn't very good at anything other than screwing stuff up, and on cuts...
WTB a Beastronix 86 Nanny unit tonylop33 Want-To-Buy Requests 0 09-25-2018 07:14 PM
FS: Beastronix 86 Nanny - SOLD Agent_D Engine, Exhaust, Bolt-Ons 3 05-09-2018 01:57 PM
Beastronix Install HoonThis Software Tuning 4 06-08-2017 10:02 PM
Flex Fuel Kit and Beastronix 86Nanny Trac/VSC Juanito08 Engine, Exhaust, Bolt-Ons 7 05-10-2017 02:20 PM
Beastronix - 86 Nanny , Speed Academy version brzaapi User/Vendor/Sponsor Reviews, Feedback, Comments 4 07-05-2016 11:17 AM
