#253 | |
Drives: MR2, Sliver BRZ
Gerald R.
Always looking to tinker with something..
#254 |
Drives: 2015 Subaru BRZ Limited DGM
Sure it's a niche, but a niche that get's me one classing point back for time trials.
#255 |
Drives: 2019 Autox BRZ & 2021 GTI (Daily)
Wondering if anyone else is experiencing an issue when using ecutek and the tracbox where when turning the fans on, the connection to the Bluetooth dongle plugged into the OBD2 dies and any data logging is interrupted. When activating the pedal dance, I do not experience this and the dongle works normal. I’m using the below configuration...
- Pedal Dance and Fans on a switch - EcuTek Bluetooth dongle & app to log/view data Anyone else experience this — is it expected behavior?
2019 BRZ | Autocross focused, CSG tuned w/Jackson racing C38 & PTuning flex fuel kit
2021 GTI | Daily |
#256 | |
Site Moderator
Drives: Stuff
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
| The Following User Says Thank You to Dave-ROR For This Useful Post: | AllThePeat (08-06-2020) |
#257 | |
Drives: '14 BRZ Limited
| The Following User Says Thank You to peaches For This Useful Post: | AllThePeat (08-06-2020) |
#258 |
Unfortunately thats the nature of the beast. The Tracbox sends the command to turn on the fans every once in a while in the advanced OBD2 range of canbus IDs. This also happened in the original beastronix. I have taken a lot more steps to minimize data crossing. Just because to activate the fan it has to do so X amount of times per minute. So when fans are on that's what happens. If its a issue when cooling down your car, i can see if i can prolong the period. So it would be something like 5 seconds on, 5 second off, repeat... it could relive that issue. Gerald R.
| The Following User Says Thank You to geraldjust For This Useful Post: | AllThePeat (08-06-2020) |
#259 | |
#260 | |
2021 GTI | Daily |
#261 | |
Good news for anyone that also wants the ABS disable. Works in all speeds! Its scary to know ABS can be disabled and the effects on the car are. and how worse it is if you have the EBD off.
| The Following User Says Thank You to geraldjust For This Useful Post: | Jyn (08-07-2020) |
#262 | |
Noob
Drives: FR-S Mammogram
Thanks for that. So just run the power to one of the LED 12v in, then daisy chain them all. Same for ground. What gauge wire you use? I almost never do wiring aside from some butt connectors
#263 | |
Noob
I had emailed you earlier about the ABS feature and just found this thread. Gonna place my order today.
#265 |
Drives: White GT86
After a 3 month wait, thanks covid and customs, finally got mine today, the lid of the box was a felt a bit flimsy and the box itself was a bit dirty. Opened it up and the PCB (both sides) is like this...
![]() presumably some IPA will clean it up, it doesn't just brush off and looks like somethings dried on it. Anyone else receive one like this? |
#266 |
ProCrastinationConsultant
that's the mark of using super glue to bond the two case halves together. superglue isn't very good at anything other than screwing stuff up, and on cuts...
| WTB a Beastronix 86 Nanny unit | tonylop33 | Want-To-Buy Requests | 0 | 09-25-2018 07:14 PM |
| FS: Beastronix 86 Nanny - SOLD | Agent_D | Engine, Exhaust, Bolt-Ons | 3 | 05-09-2018 01:57 PM |
| Beastronix Install | HoonThis | Software Tuning | 4 | 06-08-2017 10:02 PM |
| Flex Fuel Kit and Beastronix 86Nanny Trac/VSC | Juanito08 | Engine, Exhaust, Bolt-Ons | 7 | 05-10-2017 02:20 PM |
| Beastronix - 86 Nanny , Speed Academy version | brzaapi | User/Vendor/Sponsor Reviews, Feedback, Comments | 4 | 07-05-2016 11:17 AM |
