Old 08-12-2020, 04:54 AM   #1
TSaanity
Drives: 2017 Fr-s
What mods needed to turbo a FR-S
Hello. Sorry if i dont know how to use the forum, i just created this account. I have a stock 2017 FR-S and i was wondering what mods are needed in order for the turbo kit to be stable inside of the vehicle, and so i can get the most use out of the kit. If anyone can give me a full list of mods needed before the turbokit, i would be very happy.
TSaanity is offline   Reply With Quote
Old 08-12-2020, 04:56 AM   #2
TSaanity
Drives: 2017 Fr-s
If there is an order for the mods to be installed, putting them in order would be very useful. Thank you so much.
Old 08-12-2020, 05:59 AM   #3
new2subaru
Weight Weenie
Drives: 15 FR-S
https://www.ft86club.com/forums/forumdisplay.php?f=78
Old 08-12-2020, 05:59 AM   #4
p1l0t
p1l0t's Avatar
Have you searched the forum yet? I can't believe there isn't a thread or 5 about this already..
Old 08-12-2020, 07:05 AM   #5
86MLR
86MLR's Avatar
And you don't always need half the things that people recommend.
Old 08-12-2020, 07:27 AM   #6
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
If you don't want close to / more than 300WHP, just buy a base model turbo kit, and something to tune it with. I would recommend ECUtek, but it sounds like you're going for the Cheap / Fast style build.
As you'll find is advised here commonly, do not take on a turbo project if you do not have a lot of money to burn.
The turbo kit is the cheap part. This is not something that can be done reliably on a budget.
If you just want to figure it out and want to start cheap, get the OpenFlash Tablet, and the SBD turbo kit. Let your tuner know that you're just looking for mid 200s and if they're sensible, they'll get you to that mark and you won't need any power supporting mods like injectors, fuel pump, clutch, nothing. The only thing you need to be mindful of is your temperatures and installation.
A turbo kit introduces a lot of possible failure points. A severe oil or coolant leak will spell death for your engine if you let it go unnoticed. An exhaust leak at the flanges will introduce a lot of fuel correction, and a tune that loads the engine up with low end torque will bend a rod quickly.
All in all, no matter your choice, budget 10k if you want to feel safe with whatever you choose. No, I'm not kidding.
Old 08-12-2020, 07:35 AM   #7
p1l0t
p1l0t's Avatar
Jebus I know these kits are pretty standard and will run on whatever handheld tune but why is everyone so against a professional tune on a dyno? I think it's worth the money just watch the pull. I am down to try almost anything parts wise but I would just rather a pro tune my car than try it myself or use some one-sized fits all approach. Then again most of my modded cars (BRZ is mostly stock) are not that standard (even for aftermarket).
Old 08-12-2020, 03:08 PM   #8
TSaanity
Drives: 2017 Fr-s
i have the money to do this project, about an extra 12k to spend. money is not much of a constraint.
Old 08-12-2020, 03:22 PM   #9
WildCard600
WildCard600's Avatar
Drives: 2020 86
It's possible they don't know any reputable shops in the area ? I have no idea where the closest non motorcycle dyno is. And judging from the cars I tend to see on the road in my area i'm not sure the dyno shop (if there is one) would even know what to do if it's not a "muh V8".
WildCard600 is offline   Reply With Quote
Old 08-12-2020, 03:22 PM   #10
pope
has a funny hat
Drives: 2014 BRZ Limited
sounds like you have the budget. K swap or LS swap, then worry about a turbo.
pope is offline   Reply With Quote
Old 08-12-2020, 03:40 PM   #11
DarkPira7e
DarkPira7e's Avatar
What kind of power would you like, then? I stand by what I said, get the JDL or SpeedByDesign Kit ( Or the Greddy 518z if you want to spend for the genuine thing), get an ECUtek license, cable/dongle and RaceRom patch (Comes to about $1,000 USD) and find a tuner after it's all installed.
If you want less than 300WHP, that should be all you need. Only datalogging and your tuner can guide you after that; nobody here can tell you if you're overheating or running out of fuel. You could get some injectors just as a precaution, but depending on your goal, they may be unnecessary. Nobody will be able to tell you what wheels/tires you should get, as your grip will be determined by the way it is tuned and the way you drive.
The only thing I'd do is get the Exedy stage 1 clutch. It drives like the stock one, but holds quite a lot of torque. I'm using it and it held my 330WHP without a problem.
Old 08-12-2020, 03:46 PM   #12
TSaanity
Drives: 2017 Fr-s
I would like to reach around 300 WHP, if that is possible with this engine.
Old 08-12-2020, 03:47 PM   #13
TSaanity
Drives: 2017 Fr-s
Sorry, im new to swapping engines but doesnt that introduce alot of problems or am i wrong? If anything i would like to put either a RB25 or a RB26 in to it. (sorry for sounding like a RB fanboy)
Old 08-12-2020, 04:13 PM   #14
DarkPira7e
DarkPira7e's Avatar
Ok. Then reference my post you just quoted, it's a perfect recipe for your goals.
Buy a basic turbo kit like one of the following-
JDL
FullBlown
Greddy 518z
SpeedbyDesign
Ptuning
Get the Exedy stage 1 clutch
Get the ECUtek dongle + Cable, get the ECUtek license, get the ECUtek RaceRom patch
Get tuned, get fast.
forged, help needed, turbo, turbo fr-s
No longer needed, mods please delete wheelsun Software Tuning 0 08-11-2016 02:17 AM
No longer needed, mods please delete wheelsun Want-To-Buy Requests 0 08-11-2016 01:11 AM
Turbo kit needed Cuztomizer Want-To-Buy Requests 0 11-30-2015 07:34 AM
Rocket Bunny V2 Bumper - Mods Needed? HachiRo Cosmetic Modification (Interior/Exterior/Lighting) 1 10-09-2015 11:33 PM
FA20CLUB turbo kit advice needed joedaniali Forced Induction 26 02-24-2014 01:25 PM
