Old 08-07-2020, 08:16 PM   #1
HotLavaJoe
Drives: 2013 FRS 6MT Hot Lava
OEM Piston Weight - Re-Balance?
Hi all,
I'm planning on rebuilding my 2013 FRS engine soon with all OEM parts except for pistons. I want to go with 13.5:1 compression and 87mm diameter to get a tiny bit more NA power with E85.
My question is: When I get aftermarket pistons that are a different weight from OEM (I cant find OEM piston weight info anywhere) will I have to re-balance the engine in any way?
Thanks,
Joe
HotLavaJoe is offline   Reply With Quote
Old 08-08-2020, 10:59 AM   #2
Grady
Grady's Avatar
No.
Old 08-09-2020, 02:46 PM   #3
Steveiam
Drives: 86
Why not swap out for stronger rods while everything's apart?
Steveiam is offline   Reply With Quote
Old 08-09-2020, 09:13 PM   #4
Jdmjunkie
Drives: Scion FR-S 10 Series
Not to mention lighter for maximum revs and NA goodness!
Jdmjunkie is offline   Reply With Quote
Old 08-10-2020, 02:00 AM   #5
Turdinator
Señor Member
Turdinator's Avatar
Lighter rods don't seem to be a thing for the FA20
1974 TA22 Celica
2013 86 GT
Old 08-10-2020, 12:26 PM   #6
PulsarBeeerz
Drives: JRSC BRZ SOLD
No need for stronger rods when NA and apart from one fella with custom Ti con rods the OEMs are plenty light.
If anything maybe make sure the current or new OEM rods are all of equal weight and balanced since the new pistons will be.
PulsarBeeerz is offline   Reply With Quote
Old 08-10-2020, 12:34 PM   #7
86TOYO2k17
Drives: 2017 toyota 86
Get some head work done while the heads are off. oversized valves, springs, port/polish etc... maybe even a cam. Rev her out to 7800 with the 13.5 compression, and get an ace 150 header for that top end. Maybe toss in some ITBs. you could Probably have The highest WHP non stroked NA FA20.
Old 08-10-2020, 12:45 PM   #8
PulsarBeeerz
Just throw $15k at it. NBD
Old 08-10-2020, 01:53 PM   #9
Jdmjunkie
It is only money.
Old 08-10-2020, 01:59 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That way the rocker arms come out at higher velocity
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post:
PulsarBeeerz (08-10-2020), soundman98 (08-10-2020), Tcoat (08-12-2020), WildCard600 (08-10-2020)
Old 08-10-2020, 02:12 PM   #11
86TOYO2k17
Why stop at $15k? Mortgage interest rates are at historic lows.
Old 08-11-2020, 02:21 AM   #12
RayRay88
Drives: 2017 86 860 Special Edition
Probably not worth it unless you can address oiling issues. All that money just to watch a bearing spin before your first oil change.
RayRay88 is offline   Reply With Quote
The Following User Says Thank You to RayRay88 For This Useful Post:
PulsarBeeerz (08-11-2020)
Old 08-11-2020, 02:07 PM   #13
PulsarBeeerz
Yup the only ones that seem to have it figured out are Element Tuning and after you add up all the stuff mentioned, you are well over $15k... Smarter to wait for the KMiata K24 swap in reality.
The Following User Says Thank You to PulsarBeeerz For This Useful Post:
NoHaveMSG (08-12-2020)
Old 08-11-2020, 11:28 PM   #14
Turdinator
Señor Member
Turdinator's Avatar
Originally Posted by HotLavaJoe View Post
Hi all,
Thanks,
Joe
If you are rebuilding it to gain performance, why not spend a little extra and get it fully balanced regardless?
1974 TA22 Celica
2013 86 GT
The Following 3 Users Say Thank You to Turdinator For This Useful Post:
NoHaveMSG (08-11-2020), PulsarBeeerz (08-12-2020), soundman98 (08-11-2020)
PP Brembo front rotor weight, lighter-weight alternatives? ZDan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 02-14-2022 07:03 PM
Balance d1ck Tracking / Autocross / HPDE / Drifting 25 07-28-2014 01:20 PM
Weight Reduction vs. Weight Distribution (for track use not for drag..etc) glamcem Tracking / Autocross / HPDE / Drifting 21 07-01-2014 11:38 AM
Weight Ratio/Balance Varies p/transmission? makesdrivingfunagain Scion FR-S / Toyota 86 GT86 General Forum 1 03-27-2014 10:49 PM
More on the CG and balance... Carban Scion FR-S / Toyota 86 GT86 General Forum 0 09-28-2012 07:07 PM
