Old 06-04-2012, 11:33 AM   #43
Matt Andrews
Matt Andrews's Avatar
Drives: race cars
Originally Posted by exmayol View Post
Ignoring fitment, weight and balance considerations, I simply don't see why a car with such power to weight ratio would ever need 9" wheels.
So there are plenty of reasons for a wider wheel (and tire) even for this weight class. Some people will disagree, but really, wider wheels and tires don't provide more grip, they provide better heat dissipation. So if you intend to run the car on track, wider wheel and tire combos are better (assuming you don't pick up so much weight that you are inhibited because of it)
A 100hp miata on 9" wide wheels with even just a 225 series tire is faster lap after lap compared to something smaller. Power only effects linear acceleration. But lateral acceleration doesn't care about power, so every horsepower level can benefit from this.
not saying this is why the original poster did it...
Matt Andrews is offline   Reply With Quote
Old 06-04-2012, 12:34 PM   #44
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Yeah, the increase to a wider wheel was all about cosmetics, since I still retained a 215-width tire on the wider wheel. My contact patch is almost exactly the same as the stock tires.
Old 06-04-2012, 01:45 PM   #45
ESBjiujitsu
MUST HAVE MORE 86 ! ! !
ESBjiujitsu's Avatar
Drives: Mazdaspeed 6 2.3 AWD Turbo
thanks for that info!
WISH LIST: Whiteout FRS- Bronze 18' race rims, Cooper Zeon RS3-S tires,
Cusco Coilovers, Cusco 6 point cage, CF Lip spoiler, CF F1 Mirrors, HKS GT-86 SC
92 carmy -> 86 corolla-> Honda S2000 -> Audi TT -> Mazdaspeed6 -> NEXT UP TOYOTA FT-86!!!!
ESBjiujitsu is offline   Reply With Quote
Old 06-04-2012, 01:47 PM   #46
DarrenDriven
NW Region Moderator
Originally Posted by Turbowned View Post
EDIT: my posts keep getting deleted. I'm not hating, but seriously, your fitment is a little off. Maybe lowering/alignment will fix. If you're cool with it, no worries.
Haha, I somehow missed your graphic, but just saw it. Yup, at the moment I am mexiflush but I will try to rectify that soon.
Old 06-12-2012, 02:56 PM   #47
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I actually love this rim but this is what I will do if I buy this rim.
Reduce the width to 8
Hike up the height to 18
Offset hike up to 35
Thanks for showing me this rim on your car so I can get tips.
SUB-FT86 is offline   Reply With Quote
Old 06-12-2012, 03:16 PM   #48
DarrenDriven
NW Region Moderator
Be careful, the narrower versions of this wheel have a convex face instead of a nice concave look. I was going to buy another set of the 17x8 and install two on the front, then sell the leftovers to another FR-S/BRZ owner but I realized that the narrower wheels look different and wouldn't mix and match well.
Old 06-12-2012, 03:38 PM   #49
SUB-FT86
86 Member
O Rly? Thanks again for that bit of info. I hate convex and it must be concave only.
Old 07-02-2012, 04:58 AM   #50
LSV8
Drives: Very fast
here's a quick-n-dirty chop for you:
LSV8 is offline   Reply With Quote
Old 07-02-2012, 11:48 AM   #51
DarrenDriven
NW Region Moderator
Ahhhh yes! That looks much better!
Old 07-24-2012, 03:30 PM   #52
DarrenDriven
NW Region Moderator
Posted in another topic...
Originally Posted by Spaztastik View Post
Rota Torques, 17x9 e30 with 215/45r17 dunlop dz101's. Lowered on Cusco Zero 3s coilovers. No camber added yet, set at 0 on the camber plates and camber bolts.
No rubbin noticed so far.
Old 07-24-2012, 10:50 PM   #53
Spaztastik
Spaztastik's Avatar
Drives: Raven Fr-s -- daily drifter
I see my car :P
But as you can see this offset isnt too crazy once its lowered and stuff. Doesnt even need much crazy camber, just what ya get from lowering this kinda suspension. I might actually suggest a lil bigger tire, like a 225/45 or 235/40 for a lil better fender clearance for the flush crowd, but for drifting at stock hp this will do me fine
Spaztastik is offline   Reply With Quote
Old 07-27-2012, 09:41 PM   #54
Entropy
Oversteer > Understeer
Entropy's Avatar
Drives: GT86
I thought the stretch was going to eat more of the height than it did, to be honest. I'll be burning through these tires quick enough and I'll probably go with a 215/45-17 and see how it looks.
Have you thought about 225/45? They add just tid bit more sidewall over stock, so you would probably end up being around stock diameter. The drop should add some camber too so it probably wouldn't rub... Just thinking out loud
I think the wheels look great!
Entropy is offline   Reply With Quote
Old 07-28-2012, 01:04 AM   #55
DarrenDriven
NW Region Moderator
Thanks @Entropy! I don't think that I have noticed you around here before... you need to post up in the NW Owners Topic!
Old 08-02-2012, 03:35 AM   #56
DarrenDriven
NW Region Moderator
Threw out my bald rear tires and swapped the front 215/50-17s to the rear, then installed some 215/40s in the front. Bolted in my D2 coilovers and cranked the front camber to max. Here is the result... same wheels, no spacers, fits nice if you like the JDM cambered look. (if not, keep it to yourself please)
FRONT:
REAR:
WEDSSPORT TC105N - 17x8.0 +42 / 17x9.0 +35mm 5x100 ~ 15 Lbs Per Wheel RavSpec Wheels and Tires 72 12-04-2012 03:58 PM
WORK Emotion Kiwami - 17x9.0 +38mm 5x100 *** BRZ/FRS Spec *** RavSpec Wheels and Tires 5 07-19-2012 06:44 PM
RAYS Gramslight 57Dr - 17x9.0 +35 *** $1399 *** / Pre Order + Group Buy RavSpec Wheels and Tires 9 07-07-2012 02:03 AM
Torque App ZetaVI Other Vehicles & General Automotive Discussions 4 12-02-2011 12:22 AM
what are your thoughts on rota wheels? VenomRush Other Vehicles & General Automotive Discussions 46 11-24-2009 03:08 AM
